Radiator Fluid Leak
Old Dec 19, 2013 | 01:12 PM
Morganinaboat's Avatar
Morganinaboat
Radiator Fluid Leak
Came out Tuesday morning to find a mysterious puddle right at the very front of the car. Parked in a different space last night and voila another puddle appeared. Was finally able to track it back to a drip from the radiator area. Checked the overflow tank and it was nearly bone dry. Not sure if I'm going to need a new radiator or if I can give some of that liquid metallic radiator leak stuff a try. Any suggestions? Not happy. Haven't had the lil girl for even a week and already this...my fault...didn't have a PPI and bought it "as is" but come on!!!
Old Dec 19, 2013 | 02:13 PM
mrbean's Avatar
mrbean
Don't use the magic in a can crap. Repair it properly. Find the source of the leak and replace the necessary parts (probably the radiator, not a very difficult job on these cars).
Old Dec 19, 2013 | 02:18 PM
Sounds like a leak from the radiator at the neck possible. If its the neck you will have replace the whole thing most likely. Do you have a pic of the leak?
#1 on the diagram.
Dont know which model Gen 1 MINI you have but here are both of the:
R53 / R52 Cooper S version. Auto and manual.
Aluminum Radiator Part # 17117570489
http://www.ecstuning.com/Search/SiteSearch/17117570489/
"Justa" Cooper which needs the R50 / R52 (Non - S ) version. Auto and Manual.
Aluminum Radiator Part # 17117570821
http://www.ecstuning.com/Search/SiteSearch/17117570821/
Old Dec 19, 2013 | 06:29 PM
DJDUPONT's Avatar
DJDUPONT
Just went through this, don't bother with a stock unit pick up a Mishimoto. Damn thing is warranted even if the car gets in an accident. Its a bit more expensive but full aluminum "no fail plastic like OEM' and it fits like a glove.
Old Dec 19, 2013 | 06:32 PM
Morganinaboat
How much does a Mishimoto set you back compared to a OEM?
Morganinaboat
#1 on the diagram.
Trying to identify the source. I have a 2003 R53 6sp.
Old Dec 19, 2013 | 06:37 PM
DJDUPONT's Avatar
DJDUPONT
pretty sure a true OEM is $225-250 marked down from $300. I paid $300 for the Mishimoto to my door. Its really nice and worth the extra $$.
Old Dec 19, 2013 | 07:09 PM
Morganinaboat
Was able to catch a picture of the leak point. Refilled the overflow tank and let the car warm up. Within a few minutes, i had zeroed in on the leak at the top left of the radiator. Was leaking about one drop per 10 seconds.
Old Dec 20, 2013 | 05:53 AM
Its looks like that top corner of the tank, at the neck, unless you can see something else. Currently our picture of our Cooper S radiators are upside down but it would be that lower corner in our pic, where the necks connects to flange.
For the MINI Cooper S R52/ R53 . That what you need and if you decide to go with the Mishimoto one its in the link at the bottom and a direct fit.
Old Dec 20, 2013 | 11:13 AM
mblotto's Avatar
mblotto
Wow, exact same leak just started on my '02 MCS! 2nd rad that's only 2 years old, too.
I'm going to attempt to get the neck off on Monday and see if there's an o-ring or seal that needs replacing. Anyone happen to know what size the ring is and if it's possible to get from the dealer? I somewhat doubt they would have it as dealer MO is always to do full replace.
Old Dec 20, 2013 | 11:32 AM
There is no MINI part number for the O-ring. Might be able to match it up, there was a couple guys who tried the O-ring fix and reseal it and then leaked again.
Thanks and good luck.
Old Dec 20, 2013 | 01:11 PM
Morganinaboat
Took it to my normal mechanic and they pressure tested the system. Looks like I need a radiator entirely. I'm going to let them work on it and not take it to the euro-car mechanic in the next town over. We'll see how it goes. I've used these guys for years with good success so I hope it holds try for the Tardis.
Old Dec 20, 2013 | 01:48 PM
ZippyNH's Avatar
ZippyNH
Was the "new" rad that failed an oem or a cheap replacement?
You can get new ones for about $100 on rockauto...same brands as the auto zone, etc for half the cost....simple swap if I recall from changing out my radistor fan....
Old Dec 20, 2013 | 03:01 PM
JAB 67's Avatar
JAB 67
I bought a Behr from ECS for about $200. Indistinguishable from original.
Old Dec 20, 2013 | 03:32 PM
noodlesandsam's Avatar
noodlesandsam
Careful behr 'service' is not oem behr. Two different product lines. The quality is not the same.
patsum
26
May 29, 2021 06:29 PM
Sep 10, 2015 03:36 PM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
