07 "S" with P115c Code
Old Sep 18, 2013 | 11:40 AM
Mskminifan's Avatar
Mskminifan
I have a 2007 cooper S that appears to run just fine... but the check engine light is on. That points you to the MAF sensor which I purchased a second one and installed but did not make any difference. When driving the car with the scanner connected the fuel trims remain almost 100 percent on with little change. That tells me that it's not a vacuum leak, but I had it checked anyhow and no leaks were found.
Odd that the car seems to run fine (perhaps just a minor miss at low idle) but can't make this blooming light go out...
HELP...
Old Sep 18, 2013 | 11:45 AM
InjectedGT's Avatar
InjectedGT
Is the code coming back on? Because if everything seems well other than the light not going off, have the code cleared with a scanner, or disconnect the battery for a few minutes. Should clear the code so you can see if it comes back on for the problem still bein there, or if i t just never reset.
Old Sep 18, 2013 | 03:10 PM
Mskminifan's Avatar
Mskminifan
Correct... it clears with the scanner and then if you drive with the scanner connected you can see it shows a pending code... after shutting off the car and re-starting the code is thrown again and the check engine light comes on once again...
Old Sep 18, 2013 | 06:45 PM
InjectedGT's Avatar
InjectedGT
What kind of air filter are you using? what had you done to the car before the code got thrown? I've been reading that cleaning the maf fixed this code for a few people. One of which got the code after a new intake or filter was installed and it was just excess filter oil gumming up the maf.
Old Jul 22, 2014 | 08:41 PM
Blazermaniac's Avatar
Blazermaniac
I went through this problem. The dealer first tried to replace the Mass Airflow Sensor. That didn't work. Then they said it was the Vanos unit. Light came back on almost immediately. Then they replaced the Turbo. Still no. By this point I was about to pop a blood vessel I was so mad. Finally, they replaced the throttle body. BINGO. That did the trick. The light hasn't come on since.
Old Jul 22, 2014 | 09:11 PM
Diego Morales's Avatar
Diego Morales
Any news on the throttle body? Still holding up?
Old Jul 24, 2014 | 04:41 PM
wac's Avatar
wac
I got this too, long time.
Old Jul 31, 2014 | 08:50 PM
Yakatak's Avatar
Yakatak
I'd like to know also. P115c keeps coming back. Absolutely no leaks. Replaced MAF. I do have a foam air filter, but run it very dry and it's been there for a couple of years with no problem.
Old Jul 31, 2014 | 09:01 PM
DRoc7822's Avatar
DRoc7822
This is the 2nd time Ive seen that the throttle body was the cause of the code. And that once it was replaced the code went away. Might as well try it. I have the same code. Been told it was the MAF... the turbo inlet...the valve cover...and now the throttle body.
Old Aug 2, 2014 | 03:21 PM
Blazermaniac
Still working fine. No more engine light.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
