Cooling fan
Old Apr 17, 2013 | 05:27 PM
jeffsun21's Avatar
jeffsun21
Cooling fan
2003 mini s , I have recharged the ac to get the compressor to engage hoping to get low speed fan on still no luck, all relays and fuses good and hi speed fan works,what next,do I replace fan or resistor pack on fan housing
Old Apr 17, 2013 | 05:39 PM
xsmini's Avatar
xsmini
Is the clutch engaging?
Nik
Old Apr 17, 2013 | 06:02 PM
Eric_Rowland's Avatar
Eric_Rowland
Personal preference thing. For a little less work, there are a few options for splicing in a new resistor, or just go whole hog and replace the assembly (that's what I did.)
Does your AC work? Did you do a DIY recharge, or pro? I experienced the typical failure - low speed fan goes, then AC overheats at low speed and compressor burns out. Had to replace both. :/
Old Apr 17, 2013 | 06:06 PM
jeffsun21's Avatar
jeffsun21
AC is engaging but hot air, did a home recharge,it did add enough to get the compressor to engage,which I was hoping would turn the fan on. Can you supply more info on the splice in resistor,I saw a post about how to. Get to. It but don't want to. Go thru the work without being sure.
PsychoRallye
21
Feb 17, 2019 06:08 AM
monkiboy
Oct 16, 2015 09:58 AM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
