What does this warning mean?
Old Jun 11, 2012 | 05:10 PM
Beau M's Avatar
Beau M
2009 MCS. When I start it, I get this warning light and the little exclamation point next to the trip odometer. I looked through the owners manual, didn't find anything.
Thanks!
Old Jun 11, 2012 | 05:22 PM
Baker555's Avatar
Baker555
Could it mean that you have a light out?
Old Jun 11, 2012 | 05:25 PM
Beau M's Avatar
Beau M
Is that an upside down light, or a grenade?
Old Jun 11, 2012 | 05:28 PM
ZippyNH's Avatar
ZippyNH
You must have the james bond 007 option!! It is telling your handgrande is ready for use!!
Good luck!! Somehow it seems if the car can flash a symbol, it could alternate a code/key word. Some of these things get harder to deciper everyday!!
Old Jun 11, 2012 | 05:30 PM
shiznight's Avatar
shiznight
looks like a lamp out warning, turn on your lights and harzards and walk around the car, then have someone step on the brakes. if none of these are an issue check your front and rear fog lights. liscence plate lights and interior lights. that is if that's a lamp out light which it does look like
Old Jun 11, 2012 | 05:33 PM
Clubman S Turbo's Avatar
Clubman S Turbo
Thats a lamp-out warning. Should be repaired but nothing scary. Its when the engine and or/trans symbols start popping up that the sweat trickles down your temple ...........
Old Jun 11, 2012 | 05:34 PM
LittleWing's Avatar
LittleWing
That is a lamp out warning.
I got one last week.
Scared me to death because it's very similar to the transmission warning.
In my case it was a front daytime running light.
As I had a new lamp on hand it only took moments to replace and the warning light went out immediately.
Hope that helps!
Old Jun 11, 2012 | 07:47 PM
Beau M's Avatar
Beau M
Yep, brake light. Thanks!
Transmission warning just sounds bad. Do these transmissions break easily?
Old Jun 11, 2012 | 08:51 PM
LittleWing's Avatar
LittleWing
I don't know the answer, but I hope it is "no."
I just know that I don't want a warning light for the transmission coming on.
The lamp out light made me jump out of my skin.
Old Jun 12, 2012 | 09:02 AM
schatzy62's Avatar
schatzy62
2009 Manual - Indicator and Warning Lamps - starts on page 128 and runs thru page 138.
On page 137 - 5th section down shows that exact symbol:
Cause: Bulb of exterior Lighting System Failed
What to do: Have exterior lighting checked as soon as possible
I.E. start car and check all light bulbs. Find the one that is out and replace it. Instructions are in the manual how to do change most of them
Old Jun 12, 2012 | 09:33 AM
GigglesMcMini's Avatar
GigglesMcMini
That's funny. I picked up my Mini on January 30 last year, and the first time the temp dropped below 37 and the warning chimed and the snowflake popped up I about died. Totally didn't expect it. Thought my Mini was yelling at me for taking a turn too fast(which I did)
Old Jun 12, 2012 | 05:23 PM
jessicaledw's Avatar
jessicaledw
It happened to me last week too. The body shop failed to hook up one of the tail lights correctly, the first of many problems, and so the light and warning gong sounded. It scared me too. I see that someone posted the page number above. I had to hunt through the symbols to find it.
Giggles, that snowflake freaked me out too! I immediately pulled over and looked through the owners' manual to find out what it meant. I'm glad I'm not alone!
Old Apr 17, 2013 | 12:43 AM
fobos's Avatar
fobos
Bulb-out warning with a perfectly fine bulb
It began irritating me to see that warning sign every time I start my Mini. I was able to figure out which light bulb had caused the warning light to come out and even bought the replacement bulb. However, when I removed it from the socket, the bulb was just fine. I screwed it back in and the warning light disappeared....only for an hour or two. The bulb sits tightly in the socket and the socket is not loose when in the light assembly. It is a p21w bulb and it's a parking light (the top one in the taillight assembly). I drive 2007 MCS and was wandering if anyone else have had this issue in the past? Thanks
Old Apr 17, 2013 | 01:36 AM
esfreerider's Avatar
esfreerider
A couple days after I picked mine up it did the same I freaked out until I figured out what it was, the beep sounded just like the one my fiance's passat did right before it went into limp home mode a couple weeks before.
Old Apr 17, 2013 | 06:40 AM
pmsummer's Avatar
pmsummer
This is the one you want to be worried about, the dreaded "Engine Bottom-End Grenade" warning.
Old Apr 17, 2013 | 05:23 PM
omgjcw's Avatar
omgjcw
If you don't see any lights out, smack the side of the front bumpers near the parking light bulbs in the "fog light" assemblies. If the message doesn't go away after cycling the key on and off after jarring the parking light bulbs in their sockets, there is a software update for many earlier cars (pre late '10) for an erroneous light out message. The car thinks it has rear fog lights out when in fact the car doesn't even have them installed. The fault description will even state the fault is for an E90.
Old Apr 24, 2013 | 06:12 PM
BGKY-Mini's Avatar
BGKY-Mini
I had a front parking light that was bad and caused that symbol to come on. Strange thing was it would sometimes show and other times it wouldn't. I could not find which light was out as the break in the filament was hairline and would fuse back together once it got warm. A rough bump finally caused it to go out and replaced it. The snow flake was an interesting one first time it popped up for me as well.
Old Apr 24, 2013 | 09:22 PM
boOst spIKe's Avatar
boOst spIKe
This.
Old Apr 25, 2013 | 10:05 AM
ashchuckton's Avatar
ashchuckton
It's an idea light. Gives one the idea to check for burned out bulbs. There may be something about this in the owners manual.
randeez
Oct 5, 2015 09:23 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
