Oil residue on top of engine?
Old Mar 21, 2012 | 09:24 PM
Bmont82's Avatar
Bmont82
Oil residue on top of engine? *FIXED*
Has anyone ever noticed an oily residue on top of there engine? Specifically right around the area where the spark plug wires enter the engine. I removed the wires and inspected the spark plug areas and they were clean and dry as a bone. Also no evidence of any other leaks...
I wash my car weekly and always open up the hood and wipe down in there to keep it clean, I've never noticed oil there ever. It was clean, then I took a drive to Vegas for a weekend then when I returned to LA to give it a wash I noticed the residue. Below is a picture.
http://imageshack.us/photo/my-images/13/oilb.jpg/
*UPDATED*
So I took my 08 MCS to the dealer because it is still under warranty. They fixed it as it was a leaky valve cover assembly. The exact wording was "found oil leak from valve cover vent valve, installed new valve cover assembly".
Old Mar 22, 2012 | 12:23 AM
hbSean's Avatar
hbSean
Does it look anything like this
Old Mar 22, 2012 | 08:44 AM
Bmont82's Avatar
Bmont82
Yes I think so but not quite as bad, see my pic...
Old Mar 22, 2012 | 08:52 AM
drsimmons's Avatar
drsimmons
It's hard to tell from the picture.
I always have a little bit but I don't see
any leaking going on. I check my oil regularily.
Plus, just had my gasket replaced awhile back.
Are you sure it's oil and not condensation?
Old Mar 22, 2012 | 08:54 AM
Bmont82's Avatar
Bmont82
I guess I'll clean it off and see if it comes back. I keep an eye on my oil, haven't seen it go low. It's not condensation for sure...
Old Mar 22, 2012 | 08:58 AM
drsimmons's Avatar
drsimmons
That was weird, originally when I pulled your post the link wasn't
there and then all the sudden it was there.
Anyway, I answered but I don't really have a good explanation.
Old Mar 23, 2012 | 03:49 AM
themarques's Avatar
themarques
I believe it's leaking from the cover that has mini logo forgot name. It's heat sealed so the oil is probably leaking from there. I had the same problem I removed it and applied some heat resistant plastic steel and closed it. Perfectly fine now.
Old Mar 23, 2012 | 05:41 AM
drsimmons's Avatar
drsimmons
^^^Good piece of info to have. I'll do that if I ever get the leak.
Old Mar 23, 2012 | 07:40 PM
Bmont82's Avatar
Bmont82
Fixed
Old Mar 24, 2012 | 03:59 AM
drsimmons's Avatar
drsimmons
Originally Posted by Bmont82
Fixed
So, how did you fix it. Just tighten cover or remove and apply some seal?
Old Mar 24, 2012 | 04:58 AM
teamrubixcube's Avatar
teamrubixcube
Old Mar 24, 2012 | 08:24 AM
Bmont82's Avatar
Bmont82
I had updated my original post...
"So I took my 08 MCS to the dealer because it is still under warranty. They fixed it as it was a leaky valve cover assembly. The exact wording was "found oil leak from valve cover vent valve, installed new valve cover assembly"."
Old Mar 26, 2012 | 04:23 PM
slimjimtell's Avatar
slimjimtell
Mine leaked and smelled like oil every time I pulled in my garage.
It was the PVC hose on the right hand side. There was a crack on the fitting it slides on to.
Dealer fixed it.
Old Mar 26, 2012 | 04:41 PM
Bmont82's Avatar
Bmont82
I'm happy it was a free fix and no damage was done but the new valve. Over assembly they put on doesn't have the mini emblem on it. They said that's what the new ones look like but still... I'll have to buy an emblem and glue it.
Kimolaoha
Jul 5, 2023 01:04 PM
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
danraabe
Aug 18, 2015 09:32 AM
