roll call, have you replaced your thermostat housing .
Old Apr 13, 2016 | 03:00 PM
  #351
Herleman's Avatar
Herleman
Once again, thanks for a quick response -- I'm hoping to get the little car back on the road quickly. I've been very frustrated with the lack of OEM (Semper Fi) parts, but the Bremen looks to be of very high quality. So far the most difficult part seems to be getting all of the electrical connectors moved out of harm's way.
Old Apr 14, 2016 | 02:04 PM
  #352
Nashvillejcw's Avatar
Nashvillejcw
so im leaning towards this issue, took a 4 hour round trip adventure and came back out after it being parked for about 3 hours to find a puddle of oily/coolantish liquid under the car. the liquid had no smell at all which was weird and had all the signs of a Thermostat housing issue. am i on the right path or does it sound like something else?
Old Apr 14, 2016 | 06:59 PM
  #353
Herleman's Avatar
Herleman
I just finished mine. It's really not all that bad a job. Getting the clip back on the main water pipe that goes across the back of the motor is the only part that will make you say bad things. The rest is fiddly stuff but not hard.
Once agai, I have to give a shout out to the folks at ECS who supplied the Bremen replacement (BMW/Mini parts have been in spotty supply since last November). Overall, I spent about $125 for parts and new coolant. It took about four hours. I could do it again in less -- and keep in mind I'm nearly 70 years old so I don't do nuttin quickly. The Bremen part appears to be identical to the Mini unit that I took off.
But I just returned from a 50 mile test run. No leaks, and the temp varied between 216 and 221 degrees. I can cool it down to 180 real quickly by hitting the "Max" button on the A/C. Back to normal.
If the Bremen part holds up, this will have been a very minor repair. If you're any kind of car person, you can do it.
Old Apr 19, 2016 | 05:32 AM
  #354
Welcome, Thanks for the order. Congrats on the fix.
Old Apr 22, 2016 | 04:29 PM
  #355
MDPACKER1's Avatar
MDPACKER1
at 36K, my 2012 Mini check engine light came on indicating the thermostat and housing needed to be replaced.
It took several attempts from the garage to get the correct housing and the correct wire harness.
They tried to charge me double what the parts would have cost were I able to get them from the Mini dealer! I know garages mark up parts but 100% was a bit much. Finally they called the Mini dealer and they gave me the parts price. Still it cost $465 plus I had no car for 5 days.
If anyone hears of a recall, please let me know.
Happy motoring - still love my Mini!
Old Apr 27, 2016 | 12:45 PM
  #356
Nashvillejcw
i didnt have a CEL, but mine leaked anyway
Old May 30, 2016 | 10:00 AM
  #357
w2ec's Avatar
w2ec
P0128-still!!
Originally Posted by w2ec
I'm at the point where I am concerned it may be my ECU that is screwed up. I know the first two housings were actually mechanically bad, the first had a thermostat stuck wide open. The second appeared to be defective from the factory, the gasket between the housing and thermostat was twisted out of position allowing coolant to flow around the thermostat flange. These problems could be visual seen with the housings removed. To have the ECU defective at the same time seems unlikely, but I'm getting desperate to find the cause of this. Yes, I had tested my car when first purchased and it was in the 200f-215f range. However, I had never driven my car in cold weather before, it is always put away for winter and never driven until the roads were clear of snow and temperatures are at least in the 60f's. This was an unusual year, no snow and clear roads so I've had my Mini out early, but it's been colder than I had ever driven the Mini before. So I had never tested the coolant temperature in such cold weather to know if it actually got up to the 200f's like it did in the summer time.
Since the temperature is not getting much above 180f, I wonder if the ECU, for whatever reason, is "thinking/reading" 180f as 220f instead, and sending the signal (heating the resistor) to cause the thermostat to open at the 180f point. I would love to find a obd II pid for that sensor (if one exists) to see what the ECU is reading, and also a pid to track what the ECU is sending back to the thermostat housing to cause the resistor to heat and the thermostat to open so I can determine if that is the cause of failing to get above 180f.
Totally frustrated with Mini at this point. The P0128's came back again after the third (in just a few months) replacement of the complete thermostat housing. Response from Mini was "Must be your thermostat housing is bad". OAT (Outside Air Temperature is now 85-90F yet my Mini STILL won't get up much over 170f degrees, and once moving settles in around 165f. Once again, a NEW MINI thermostat housing was installed (makes four new housings in four months) and the P0128 are back again. There obviously is some other cause, yet Mini's solution is, wait for it: replace the thermostat housing. Someone somewhere must have a better idea as to what can cause this problem. A new wrinkle is that now with the much warmer outside air temperature in the 80f's and 90f's, I finally turned on my air conditioner, only to find that also is not functioning. I see that failure has been listed as one possible side effect of the coolant temperature not getting up high enough (ie the P0128 code). I still think there may be something wrong with the ECU, either reading from or sending to the thermostat, the wrong data, but either there are no Mini service tools that can read that data to show it is in error, or the data is correct and they have no other idea what can cause the problem. An unresolvable problem on a car with less than 36,000 miles sure doesn't have me standing in line to buy another Mini. Once more, does anyone have any other ideas as to what can cause this problem (P0128), after the thermostat housing has been replaced 4 times and the problem reoccurs within 3 days of each replacement? At a minimum it's time to check out other Mini dealers. Currently each trip is 150 miles one way. Next closest dealer is nearly 200 miles but I guess I don't have a choice but to move on.
Old Jun 1, 2016 | 05:07 PM
  #358
Richieb0y28's Avatar
Richieb0y28
my coolant was leaking in March and took it to a local shop and it turned out to be the thermostat housing. Set me back $450, but they got it done in 2 days.
Old Jun 1, 2016 | 09:11 PM
  #359
guspi76's Avatar
guspi76
It started consuming coolant and saw that it was wet on top of the transmission. Hard to pin point at first. Took me about 4 hrs to do myself. It was frustrating but I think it would've gone smoother with a six pack. LOL
Old Jun 3, 2016 | 03:47 AM
  #360
perryinva's Avatar
perryinva
Replaced mine myself on my '08 MCCS a few months back @48k miles. The Peugeot engine cooling system is a piece of crap. The whole water pump, rear pipe ($80 bucks for a tube of plastic!) , Tstat housing debacle is an embarrassment and I can't believe Mini will not own up to it and do a recall with improved parts. And lets not talk about the turbo oil return li es and carbon build up on the intake valves. I like so many things on the Mini, but after I get my BMW based engine MCC, I'll be glad to see the old one go. Zero confidence in long term reilability.
And how hard is it to design a freaking sun visor lighted mirror door that doesn't break, and if it does, doesn't cost $130 it plastic to replace!!
My problem is the wife loves the cars, and just says "Fix it please...."
Old Jun 14, 2016 | 08:33 AM
  #361
Snipely's Avatar
Snipely
A good way to spend a Monday night?
I didn't think of breaking out some ice cold Pilsner Urquell for this! Four hours for me also on 2007 Justa, about 85K miles. It helps to have the right tools and not shitty channel locks for all the clamps needed. The one for main lower coolant drain was especially nasty to get back into position. What's with the lack of coolant drain valve? Also, long nose vise grips are useful to get the metal clip off and on under the intake manifold.
Shout out to Brian Eslick and How to Automotive on the youtube video that helped me immensely.
Old Jun 19, 2016 | 09:27 PM
  #362
cargusjoh's Avatar
cargusjoh
2012 Justa clubman P0599 heater control circut 23k miles replaced under warranty
Old Jun 20, 2016 | 12:46 AM
  #363
Mini Mania's Avatar
Thermostat
Handy dandy tutorial
Old Jun 20, 2016 | 05:04 AM
  #364
Duddie10's Avatar
Duddie10
Just had my thermostat housing go yesterday on my 2010 mcs. Going home after work to order the housing and pick up some antifreeze. Thank god for having the bike as a backup vehicle
Old Jun 20, 2016 | 05:06 AM
  #365
cargusjoh's Avatar
cargusjoh
Thank you for the tutorial Mini Mania
Old Jun 20, 2016 | 02:11 PM
  #366
netma1000's Avatar
netma1000
80K miles.
Old Jun 21, 2016 | 03:11 PM
  #367
Mini Mania's Avatar
Thermostat
Welcome!
Old Jun 21, 2016 | 09:16 PM
  #368
scubus's Avatar
scubus
Okay, here is a related question:
I am going to be replacing my houseing shortly. I am awaiting the replacement from ECS.
In the meantime I have been researching which coolant to purchase and reading about Mini versus some others and the topic of Dex-Cool. So I go out to look at my coolant in the overflow tank. When I had the timing chain replaced I had the water pump replaced and the shop said they used BMW coolant. Unfortunately, the coolant in the tank looks like a mix of red and blue (no, it isn't really purple, it is kind of black actually but the sides of the tank are red.)
So, I am wondering if this could be the cause of my failed thermostat, and, how much damage could have been done to the rest of the cooling system at this point, and, can I flush out any of the evil "goop" DEx-Cool seems to create, assuming it is in there?
Thanks!
Old Jun 21, 2016 | 10:02 PM
  #369
scott13's Avatar
scott13
Just drain as best as you can and replace with the MINI coolant
Old Jun 22, 2016 | 05:01 AM
  #370
Thanks!
Thanks for the order. Flush it out as best you can, it may take multiple flushes to get it all out if it solidified. Then replace with MINI Blue Coolant , mix 50 / 50 with distilled water.
Old Jun 22, 2016 | 05:06 AM
  #371
scubus's Avatar
scubus
Would using a commercial flush be a good idea, or just water? Also the current housing is not cracked or leaking, the thermostat is just wide open. Should I flush it before I replace the housing?
Old Jun 22, 2016 | 05:15 AM
  #372
Most just use water, but in your case the additional gunk from non MINI Blue coolant might be best at releasing from the old location with an additive. I hope that stuff is not logged too bad, you dont know till you open it up and flush it. Do it in both directions on the flush a couple times.
Old Jun 24, 2016 | 06:07 PM
  #373
All4mini's Avatar
All4mini
2012 Mini R60 - 22K miles. CEL came on and indicated P0597. Contacted Mini Dealer, they stated under warranty, but don't drive it here (350 miles) have it towed. CEL went out, I cleared the code and now it is back as pending. What say ye? Have it towed and let Mini take care of it or wait for the CEL to come on again?
TIA
Old Jun 24, 2016 | 06:21 PM
  #374
scubus's Avatar
scubus
Thanks!
Old Jun 24, 2016 | 06:24 PM
  #375
scubus's Avatar
scubus
TIA
I can only tell you what I'd do, and that is if Mini said don't drive it, don't drive it! Especially under warranty. You don't want to make any additional problems that they refuse to repair.
Unless you are sure that the thermostat is open, you could overheat the car and cause more problems or get stranded somewhere between home and the dealer.
Just one man's opinion
