My engine wants to stall ...
Old Feb 4, 2012 | 04:15 AM
choupette's Avatar
choupette
When it's cold outside and I brake hard,the engine wants to stall for a second and shakes violently and then goes back to normal idle,any idea what could cause that,I have no idea,thanks guys !
Old Feb 4, 2012 | 08:21 AM
bluefox280's Avatar
bluefox280
Need some more information on really what going on.
First, year of car, how many miles, and what recent maintenance have you completed?
Automatic or manual transmission? Any CEL / warning lights?
Have you scanned to see if there are any fault code present in the ECU's memory?
The braking action is helped by a vacuum pump that's attached to the camshaft of the engine.
I'd check to see if the brake line from the pump to the master cylinder has a crack or loose connection.
Does it only do this when it's cold?
- Erik
Old Feb 4, 2012 | 11:25 AM
choupette's Avatar
choupette
Details on the car for my little issue
It's a 2005 auto with steptronic,112,000 km or 70,000 miles. I did my last oil change a few months ago and no major service eversince. It's doing it mostly on cold days,it's winter here in canada,and seem better as the engine warms up but it takes about 15 minutes or so. I have no codes so I didn't plug a decoder,no lights in the dash,everything else works fine,anymore ideas,thanks
- Erik
Old Feb 4, 2012 | 12:03 PM
bluefox280's Avatar
bluefox280
With a 2005, you're in the wrong sub-forum; this is the 2nd-Gen (2007+) subforum.
You'll want to either have this post moved or repost in the correct 1st-Gen subforum.
The 1st-Gen owners will be able to provide better assistance; good luck!
- Erik
Old Feb 4, 2012 | 03:33 PM
choupette's Avatar
choupette
Wrong sub-forum
Will repost,thanks Eric
- Erik
Markbett
Jul 3, 2016 04:28 PM
cornfly888
Aug 24, 2015 09:57 AM
dscott90000
Aug 23, 2015 08:21 PM
Lt. Dan
Aug 10, 2015 12:46 PM
