2011 Oil Leak
Old Jun 3, 2013 | 05:34 PM
  #51
yeba's Avatar
yeba
It was making a squeaky noise whenever I hit a hump. Put electrical tape as a workaround but I want MINI to fix it. They'll probably replace the latch, Ill post an update once its fixed.
Originally Posted by NintenTom
What kind of fix was needed for the rear seat latch? What kind of sound was it making?
Old Jun 3, 2013 | 05:36 PM
  #52
NintenTom's Avatar
NintenTom
Interesting. Did it make this sound even with your rear seats removed? Could it be your sway bar bushings instead of the latch?
Old Jun 3, 2013 | 06:50 PM
  #53
yeba's Avatar
yeba
It only makes a noise when rear seat is latched. Putting electrical tape around the rod removes the noise.
Old Jun 6, 2013 | 12:32 PM
  #54
yeba's Avatar
yeba
Update on my oil leak:
Dropped off my Mini at the dealer, will be fixed.
Old Jun 7, 2013 | 10:03 AM
  #55
DooBahDoo's Avatar
DooBahDoo
Noticed oil on the garage floor so I took my '12 MCS in this morning. Oil solenoid is bad and wicking into wiring harness. They've ordered the parts and will replace everything 6/21. Looks like more than a few and numbers increasing...they expect to have it at least one day.
How long did they keep your cars?
Old Jun 7, 2013 | 10:06 AM
  #56
bmx045's Avatar
bmx045
they had the harness in stock at my dealer, the solenoid, harness, and a new windshield took about 5-6 hours. picked it up same day.
Old Jun 7, 2013 | 10:16 AM
  #57
DooBahDoo's Avatar
DooBahDoo
Thanks BMX. The SA said something about they couldn't use a gasket on the oil pan when they put it back together and they would be using a caulk-type solution that needed that much time to cure...didn't give me the warm & fuzzy but oh well.
Old Jun 7, 2013 | 10:20 AM
  #58
bmx045's Avatar
bmx045
they'll be using RTV, it's just as good if not better at sealing for a long period of time.
Old Jun 7, 2013 | 10:26 AM
  #59
DooBahDoo's Avatar
DooBahDoo
Cool...sounds better than caulk. That's why I love this forum...thanks again.
Old Jun 10, 2013 | 10:15 AM
  #60
yeba's Avatar
yeba
Got my car back. Looks like mini updated some parts because the dealer had to replace the thermostat housing also to fit with the updated parts. Unfortunately SA mentioned that there is no recall yet on the oil leak as there is no permanent solution. Will have to continue monitoring the solenoid.
Old Jun 10, 2013 | 10:36 AM
  #61
bmx045's Avatar
bmx045
Got my car back. Looks like mini updated some parts because the dealer had to replace the thermostat housing also to fit with the updated parts. Unfortunately SA mentioned that there is no bulletin yet on the oil leak as there is no permanent solution. Will have to continue monitoring the solenoid.
Well that's a lie, there is a bulletin (TSB). Heard it directly from the tech.
Old Jun 10, 2013 | 10:41 AM
  #62
yeba's Avatar
yeba
Do you have tsb # by any chance?
Old Jun 10, 2013 | 10:44 AM
  #63
bmx045's Avatar
bmx045
http://www.automd.com/tsb/bulletin_b336812/
Old Jun 10, 2013 | 11:11 AM
  #64
yeba's Avatar
yeba
Thanks. I guess the TSB is not updated, my 2012 MINI (10/2011 build) isnt shown as affected.
My bad, I checked the paper work, the SIM 11 01 12 was referenced. I guess the SA was referring to a recall.
Old Jun 10, 2013 | 11:36 AM
  #65
cjm's Avatar
cjm
For info, my build date was 11/2011 and my 2012 N18 MCS was bought in Feb. My car qualified for the oil solenoid fix under warranty without any quibble from the dealer.
I, too, think your SA ought to re-check or you ought to ask another dealer to verify his decision (or ask to speak to his supervisor).
I had to give my VIN, not my build date, to qualify for the solenoid fix.
Persevere; it needs to be fixed!
Old Jun 17, 2013 | 09:49 PM
  #66
nebulosity's Avatar
nebulosity
I had a similar issue, twice. The first time it was the tensioner adjustment bolt & seal at 10500mi. Noticed a leak again at 12000mi, this time it was from an oil solenoid and a warped oil pan. All replaced courtesy of MINI USA.
Old Oct 13, 2013 | 10:03 PM
  #67
pepperwhiteknight's Avatar
pepperwhiteknight
Very slow leak on passenger side. Dealer repaired promptly with no hassle. Tech notes stated leak was caused by failure of solenoid/hydraulic valve for oil pump. Solenoid and injection harness replaced. Oil and filter change done too. All under warranty.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
Devoman
R55 :: Clubman Talk (2008+)
Aug 25, 2015 10:59 AM
ShadyCoop
Aug 24, 2015 06:05 AM
azntaiji
Aug 13, 2015 03:24 PM
