valve cover replacement? Plugged PCV valve?
Old Jun 7, 2017 | 08:27 AM
  #26
Lex2008's Avatar
Lex2008
wow so you cleaned the entire thing out? hmm...I think that the springs which actuate the valves wear out. Its not simply a matter of clogging.
Old Jun 7, 2017 | 08:37 AM
  #27
sikamini's Avatar
sikamini
Originally Posted by Lex2008
wow so you cleaned the entire thing out? hmm...I think that the spring's which actuate the valves wear out. Its not simply a matter of clogging.
I would think eventually yes. I'm on my second or third valve cover depending on the count. I'll replace it if it needs to be replaced. I do suspect the hose going to my intake manifold might be contributing to the leak. I just might need to replace that first. But, it would be nice if there was a maintenance procedure that put off buying one by at least a year or so.
Old Jun 7, 2017 | 08:40 AM
  #28
sikamini's Avatar
sikamini
I might have my original cover that was replaced because the mechanic damaged it. Looks bad physically but might be a good backup and test if I start fooling around with the hose.
Old Jun 7, 2017 | 08:41 AM
  #29
Lex2008's Avatar
Lex2008
sikamini,
Change the hose. Its super easy assuming you can get under your car easily. I did mine when I did the cover. Its like $23. But pull yours first and check it. Mine was ok. Not clogged nor cracked.
I just put on the second valve cover (plus the one that came on the car) at 150k miles. Crazy waste of money.
Old Jun 7, 2017 | 08:42 AM
  #30
DneprDave's Avatar
DneprDave
An ultrasonic cleaner full of hot water and a splash if Citrikleen will clean anything spotless.
Old Jun 7, 2017 | 09:42 AM
  #31
sikamini's Avatar
sikamini
sikamini,
The hose is pretty easy to get to. I'll see if they have one in stock at the dealership and if they're overpriced I'll look online. There's o-rings on that hose and they typically wear out too.
Old Jun 7, 2017 | 02:20 PM
  #32
csmara@yahoo.com's Avatar
csmara@yahoo.com
PCV is clean
My PCV filter is clean but the engine coverage has one valve inside the inlet that goes in turbocharger and this valve stays in bloc position. The air cannot enter to equal the pressure.
Old Jun 8, 2017 | 10:57 AM
  #33
Gabe3's Avatar
Gabe3
is it possible to get to the orange membrane thing? theres a russian site that sells them: http://bersa-tools.ru/goods/MINI-N14
can also get them on ebay from russia. http://www.ebay.com/itm/Peugeot-EP6-...JWGiyE&vxp=mtr
apparently these are serviceable on the n12 engine which I think is in this video they replaced it:
my valve cover is making the air sound so I need to either try cleaning, buy one of these membrane things. or get a new valve cover. I have an n14.
Old Jun 8, 2017 | 12:08 PM
  #34
csmara@yahoo.com
I think is done
I think is resolved.
I opened again the small coverage and I have to wait 1-2 hours till the adhesive will get tight.
So, actually there are 2 circuits between turbo inlet and admission inlet.
One - direct circuit but the red flap do not permit the air to use this root.
Secund circuit is under the small coverage glued. See the picture in first post. The red flap direct the air here and mine wasn't quite clean. This is normal flow of air. Fresh air comes from filter (outside), enter in engine and then it is suked with unburn gas into the second valve(one way) and then in admission.
Seems yesterday I cleaned the direct circuit.
inside engine coverage there is NO FILTER or something else. Just some channels - if I can say like this.
Old Jun 8, 2017 | 12:39 PM
  #35
csmara@yahoo.com
it works - at least now
Seems the pressure is ok. We'll after few miles.
I have to mention that I removed the round cone highligt in picture, to let more space for air.
Usually it has some spaces around. But, because the coverage is not new, I chose to remove it.
Old Jun 9, 2017 | 01:10 AM
  #36
csmara@yahoo.com
It works!!
Seems PCV valve is working fine. I don't see any reason why it should not work.
You have to open the glued small coverage of the valve and clean inder the small coverage. This is the flow of the air.
I'll try to put a small movie on youtube, maybe it can help.
Overall the price of this valve is hugeeee. 400$ for a plastic with 2-3 channels inside is too much.
Old Jun 9, 2017 | 04:01 AM
  #37
sikamini's Avatar
sikamini
Keep us posted.
Old Jun 9, 2017 | 05:15 AM
  #38
We have it for about low $300's plus free ship. If the valve cover is cracked itself and hissing (CEL) or leaking oil then you have to replace the whole cover anyway. But if everything is fine and its just the cover, then that's a quick fix. They did update the cover part numbers over the years, what I dont know is if the cover internal material changed. Seems like 2007-2010 era covers had the most issues.
What type of glue are you using to reseal? I like the idea or the carbon flush.
Old Jun 9, 2017 | 10:50 AM
  #39
Gabe3's Avatar
Gabe3
was your valve cover making this sound?
after cleaning it now its not making the sound? please make a video. I want to avoid buying a new valve cover. what glue should be used to reattach it? seems like some type of thick glue should be used like RTV silicone to create a waterproof seal.
what about soaking the pcv side portion of the valve cover in a degreaser like maybe purple power overnight? what I want to know is if I need to remove the glued on top or can I leave it on?
Old Jun 9, 2017 | 02:44 PM
  #40
itscreature's Avatar
itscreature
I am also with the issue in the video that Gabe3 posted
I want to know if cleaning the valve cover worked/is a good option. Also is forking over the 427$ for a new one at mini dealer or can i found one on ebay?
Old Jun 9, 2017 | 02:49 PM
  #41
We have it here for ~$300 and free shipping.
https://www.ecstuning.com/News/MINI_R56_R55_R57_R58_MINI_Valve_Cover_Kits_21869/
Old Jun 10, 2017 | 05:04 AM
  #42
sikamini's Avatar
sikamini
The necessity to remove the little cover or not is of interest to me also.
Old Jun 10, 2017 | 05:09 AM
  #43
sikamini's Avatar
sikamini
How would this be done? Is there an ultrasonic cleaner that one can fit the cover into? Not that familiar with what is available.
Old Jun 11, 2017 | 09:57 AM
  #44
DneprDave's Avatar
DneprDave
I have one at work that holds twenty gallons of water, it would be expensive to buy for the home garage though.
Old Jun 11, 2017 | 06:11 PM
  #45
Gabe3's Avatar
Gabe3
well I soaked my valve cover in purple power degreaser for 18 hours, then washed the two holes out with water and put my finger in to keep the valve flaps open while I flushed it out. water came out the orange valve on the bottom side of the valve cover too. I drained the water completely till I heard no more sloshing around inside. I sucked air with my mouth on that bottom valve and blew on the far right hole too. air seemed to flow and the valve flaps open and closed depending if I blew or sucked. I put everything back together tonight and didn't fix it. still sucks air and the oil cap is stuck on while the car is running.
before and after I put it in degreaser, I checked the two valve flaps and they open and close easily just by gravity. so those possibly being stuck wasn't the issue.
it was worth a shot, but I guess I have to buy a new valve cover.
Old Jul 11, 2017 | 05:58 AM
  #46
1277375's Avatar
1277375
Help
Hay guys.
I need some help
Can anyone tell me how to take the small top cover off where the pcv valve is located?
I'm trying to get to the pcv diaphragm to see if it needs to be replaced. I found the pcv diaphragm for sale on eBay from Russia.
Please let me know how it's done, I tried to pull it off but I'm not sure I was doing it right. Haha.
Thank you.
Old Jul 11, 2017 | 08:59 AM
  #47
Lex2008's Avatar
Lex2008
Its not serviceable. You need to buy another entire cover.
Even if you could see the diaphragm, you wouldn't necessarily be able to diagnose it. The spring keeping it closed may be weak and that's not easily diagnosed.
Old Jul 11, 2017 | 11:08 AM
  #48
Gabe3's Avatar
Gabe3
Originally Posted by 1277375
Hay guys.
I need some help
Thank you.
the top can be pried off with enough force I think, then you would have to glue it back on. the diaphragm is enclosed under the top, theres no way to get to it without cutting it's own cover off.
ebay will be your best bet for a new valve cover. this is the seller I got mine from: http://www.ebay.com/itm/Mini-Cooper-...UAAOSwGJlZFF9K
I paid $259. its the latest revision.
Old Jul 11, 2017 | 11:14 AM
  #49
Lex2008's Avatar
Lex2008
Thats cheapest Ive ever seen BUT make sure its the latest design or you just wasted $260. That's a new EBAY seller. He may be selling old stock.
I wouldnt risk it. Go to ECSTuning.
Old Jul 11, 2017 | 11:31 AM
  #50
Gabe3's Avatar
Gabe3
why do you think hes a new seller? he's been a member since 2011. Im not sure if theres a model number on the cover itself. I saw some numbers on the under side of my old and new cover, but they didn't look like the model numbers I've seen online, I think they were serial numbers. do you know? the original valve covers still last at least 30k miles, so not exactly a waste. especially if you don't plan to keep the car that much longer.
I know the newer revisions have writing on the right side of the valve cover. it says megalast or something I never actually read it, lol. so thats how I knew it was a newer revision than the one I had.
