Error code P2270 & P0137
Old Jul 28, 2011 | 01:49 AM
Monza760's Avatar
Monza760
Is this a simple rear 02 sensor replacement or should I dig a little deeper? Nothing wrong with the car's performance and at idle. Has anyone experienced these two codes before? Should I go with OE or aftermarket direct fit sensor?
Thanks!
Old Aug 8, 2011 | 06:55 AM
Minipeddler's Avatar
Minipeddler
More specifics????
I just failed an emissions test here in Massachusetts with those same 2 codes, P0137 and P2270. The garage wasn't much help in diagnosing or even pointing me in the right direction, and I am not experiencing any physical problems with my 02 Mini. If you have had any luck in getting an answer anywhere, your experience would be appreciated. I will probably start with replacement of the 02 sensors without any other direction.
Old Aug 8, 2011 | 02:45 PM
Monza760's Avatar
Monza760
Wow....there are real people on this forum. I couldnt find an exhaust leak or vac leak. I changed out the rear 02 sensor so Im waiting to see if the codes pop up again. Before I did the 02 swap, I only got error code P2270 the second time around. I will let u know what happens.
Old Aug 14, 2011 | 07:24 PM
90intherain's Avatar
90intherain
The 2270 is rear. Have u changed ur header out? Mods?
Old Aug 14, 2011 | 09:35 PM
Monza760's Avatar
Monza760
Stock 04 R53 58k miles. Swapped out the rear 02 sensor and so far so good. No codes popped up all of last week. I would first look for any vac leaks and exhaust leaks. If those check out then its more than likely a bad rear 02 sensor.
Old Aug 15, 2011 | 03:37 PM
MiniTS-05's Avatar
MiniTS-05
02 sensor (rear) if you have a OBII reader you can reset it. I got my 02 sensor from advance a year ago or so not aftermarket, it was $168 or so.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
