Which radiator fan?
Old Jul 9, 2011 | 07:05 PM
micromini234's Avatar
micromini234
Which radiator fan?
Ok, guys so im looking to replace my radiator fan with an aftermarket fan. I have an 03 and all this this 2 pin ps plug stuff is confusing me so i was hoping someone could point me in the right direction. All i know is the relays are on are on the fan. I'd look on the car but i guess the failure of the fan and the constant use of the a/c caused cylinder 4 to crack somewhere releasing coolant in to it (its at a garage) Yeah haha lucky me
Old Jul 9, 2011 | 07:09 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We get them by VIN number to make sure we get the right one.
Also I don't advise aftermarket fans. We've had several problems with aftermarket fans. I've gotten several that wouldn't even plug in without modifying the connector, then I've also had them fail about 2 months after install. Not worth the savings over the OEM to have to replace it again.
Old Jul 9, 2011 | 07:38 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The two different fans are:
up to and from 03/03. But over the years I have seen different variation depending on where your MINI was on the assembly line during production. And even sometimes the VIN can send you astray, but 90% more accurate.
While I prefer OEM. Paying some 360 dollars for a plastic fan and shroud seemed bit over the top. So I replaced mine with a TYC brand for 80 dollars from these guys: VP Parts Warehouse It arrived with free shipping and a life time warranty.
I even called them once when "I thought" the fan was not working. They were awesome folks to talk to on the phone and said if mine wasn't working it would have been the first in the 100's of those sold. Turned out I was wrong and it was working just fine.
So I referred this company to a friend of mine with a MINI repair shop, some two-three years ago. He services some 250 MINI's in the New England area. Since then I bet he has sold and installed this same TYC brand fan to about 100 Mini owners....and with great success.
Old Jul 9, 2011 | 08:52 PM
micromini234
Was it a plug and go or did you have to mod it a little?
Old Jul 10, 2011 | 03:17 AM
-=gRaY rAvEn=-
Moderator
It was plug and play
Old Jul 11, 2011 | 07:42 PM
micromini234
Well, i did a little research, and its production date was 2002 / 10, So this is kind of a stupid question, but does that mean im looking for a 03 fan assembly or a 02 assembly?
Old Jul 11, 2011 | 08:01 PM
Rich.Wolfson's Avatar
Rich.Wolfson
If it has two plugs with the relay on the fan assembly, then you have the older one. If you have one plug then you have the later one.
///Rich
Old Jul 12, 2011 | 05:20 PM
micromini234
///Rich
so Rich its the old version, which one did you go with stock or after market to replace it?
Old Jul 12, 2011 | 07:19 PM
ZippyNH's Avatar
ZippyNH
I have a TYC fan too....
No issues....going on 3 years I think...
Old Jul 12, 2011 | 07:50 PM
micromini234
Really? where did you find it, im having a hard time finding a tyc, for a technically 02, i've looked at rock auto and have been searching ebay.
OutMotoring
Mar 3, 2017 06:29 AM
JAB 67
Sep 29, 2015 01:34 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
