r56 Battery Replacement Help
Old Oct 8, 2015 | 04:11 PM
  #101
Anldyxp_R56's Avatar
Anldyxp_R56
Installed the Sears battery today. The car started up fine, just had to reset the clock. I hope the IBS thing won't cause any issues.
Old Oct 12, 2015 | 04:58 PM
  #102
Gearheadaddy's Avatar
Gearheadaddy
Register the battery with the ecu?
Old Oct 12, 2015 | 06:17 PM
  #103
Anldyxp_R56
I didn't. Is that something I can do myself?
Old Oct 12, 2015 | 08:01 PM
  #104
Gearheadaddy
You can if you have an OBD2 adapter and an app like Torque Pro.
Old Oct 13, 2015 | 07:40 AM
  #105
miniwpbear's Avatar
miniwpbear
I didn't see this in the torque pro documentation.
Is there a web link for torque pro details on resetting the battery after install?
Carley app is too expensive for this one feature so hoping torque pro can do it.
Old Oct 13, 2015 | 08:12 AM
  #106
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Look at figure 12 here for some info on how to register your new battery IF your R56 requires it.
888.280.7799 | 6am - 5pm PST
Old Oct 25, 2015 | 09:23 AM
  #107
Anldyxp_R56
Thanks! I was looking at the bentley manual and it looks like mine isn't equipped with the IBS. Everything seems to be working fine too.
Old Oct 26, 2015 | 08:16 AM
  #108
PelicanParts.com
Vendor
You're welcome and good to hear!
Old Oct 26, 2015 | 01:48 PM
  #109
Yes, you will be able to tell the difference if you have that module and wire there on the terminal.
Old Oct 30, 2015 | 02:01 PM
  #110
thesilkiest's Avatar
thesilkiest
$270 installed here in Canada at the Mini Dealershop. Just picked one up for $130 taxes in and installed it myself. Took about 20 minutes to get that cowl back on snug.
Easy to do and there's $140 I'm gonna allocate elsewhere. Maybe some new hockey gear.
One piece of info I couldn't find on posts... The battery that came with my Mini OEM was about 8 inches in length. BUT FYI the area where the battery sits can accommodate a longer battery. I did not measure it but I would say that it could accommodate a 10-11 inch long battery. 47N H5 is the recommendation but I believe an H6 could fit. Interesting because H5s were hard to come by in my area.
Old Nov 2, 2015 | 11:03 AM
  #111
bbailey_33's Avatar
bbailey_33
On a related topic...
After replacing battery my cowl pieces have become so dry-rot from sun exposure, they are cracking and ugly as hell.
I have ordered new ones from ECS and also the clip that fits on bottom of windshield that the cowl pieces also clip into from.
I needed this part too because mine is loose and moves when trying to clip cowl piece down into it.
see: https://www.ecstuning.com/Mini-2009-...4B16A/ES92845/
How does this attach to bottom of window??? friction? epoxy ?
Old Nov 2, 2015 | 09:26 PM
  #112
Anldyxp_R56
Is this the gooey part (at least on mine, sun baked?) That seals the cowl/apron to the windshield? I'd like to replace mine too.
Old Nov 3, 2015 | 04:56 AM
  #113
We have an answer here also.
https://www.northamericanmotoring.co...lp-please.html
And the windshield cowl kit : 51132751210
https://www.northamericanmotoring.co...ield-cowl.html
Old Nov 3, 2015 | 06:51 AM
  #114
bbailey_33's Avatar
bbailey_33
Yes... after calling SafeLite, they told me it is held firmly to windshield via friction only
Old Nov 3, 2015 | 07:55 AM
  #115
thesilkiest
I went with friction and pushed the cowl firmly into the windshield while tightening.
I hope I'm not wrong. It didn't seem like it sealed well enough and I noticed when I put the cowl back that it sat a millimetre lower as indicated by the dust line.
Old Nov 3, 2015 | 08:17 AM
  #116
bbailey_33's Avatar
bbailey_33
I wonder a small bead of epoxy would be suggested ??
Old Nov 3, 2015 | 09:01 AM
  #117
thesilkiest
IMO epoxy is too permanent. You'd have to be able to remove and replace for battery work. Some type of silicon gel might be better.
Old Nov 3, 2015 | 09:04 AM
  #118
bbailey_33's Avatar
bbailey_33
I was meaning just on the channel that touches the glass
Old Nov 3, 2015 | 09:21 AM
  #119
Yea, its would hold it in place, I would use a clear and easy to remove all weather silicone and dab it on.
Old Nov 13, 2015 | 09:54 AM
  #120
GettingIt's Avatar
GettingIt
Where to buy battery vent plug?
Hello,
I had misplaced the battery vent (small black plastic) plug after taking it off the old battery for my MC.
Can you point me to what that part is called (or if there's a Mini reference document that I can look up) and where to buy it from?
Thx.
Old Dec 2, 2015 | 01:08 PM
  #121
EliasBruce Minaise's Avatar
EliasBruce Minaise
More Info
Hello all,
I will be needing to change my battery soon so I was doing some research on the whole Battery Reset process and found found some info explaining the reasons for having to run the Battery Registration (Link Below)
http://atlanticmotorcar.com/tech-tip-bmw-and-mini-battery-registration-replacement-2/
an excerpt: "The electrical system in late-model Minis and BMWs is quite sophisticated, in that it tailors charging as closely as possible to both the type and age of the battery. The Engine Management computer also controls the alternator output. When replacing a battery, this computer needs to be informed if you’ve replaced the battery or updated the vehicle from a conventional Lead Acid battery to an Absorbent Glass Mat (AGM) type; it charges the AGM differently than a traditional battery."
Seems legit to me, but very expensive.
Does anyone know if the need to do this is lessened my replacing with an identical battery?
Old Dec 2, 2015 | 02:18 PM
  #122
Its a chance, most of the time it will need re-flashed by MINI if you have the IBS system in your MINI by looking for the extra connections at the terminal.
Old Dec 2, 2015 | 04:52 PM
  #123
ammodave's Avatar
ammodave
One of your previous posts indicated you owned a 2012 Countryman; isn't it still under warranty?
Old Dec 3, 2015 | 04:59 PM
  #124
Gearheadaddy
Originally Posted by EliasBruce Minaise
Hello all, I will be needing to change my battery soon so I was doing some research on the whole Battery Reset process and found found some info explaining the reasons for having to run the Battery Registration (Link Below) http://atlanticmotorcar.com/tech-tip-bmw-and-mini-battery-registration-replacement-2/ an excerpt: "The electrical system in late-model Minis and BMWs is quite sophisticated, in that it tailors charging as closely as possible to both the type and age of the battery. The Engine Management computer also controls the alternator output. When replacing a battery, this computer needs to be informed if you’ve replaced the battery or updated the vehicle from a conventional Lead Acid battery to an Absorbent Glass Mat (AGM) type; it charges the AGM differently than a traditional battery." Seems legit to me, but very expensive. Does anyone know if the need to do this is lessened my replacing with an identical battery?
You MUST HAVE IT RESET. As long as you have a Mini with that system. I do on my Mayfair (2010) . It is known by the extra positive connection on the battery terminal. Get it reset. The need is NOT LESSENED by replacing with an identical battery.
Old May 28, 2016 | 02:21 PM
  #125
ophale's Avatar
ophale
Time for a New Battery...
Sorry to bring up an old thread, but I have a few questions regarding battery replacement.
1. How do you tell if you have a regular Lead battery or AGM battery?
My 2011 MINI Cooper Clubman S has a VARTA 61 21 7 567 386, with the following specs 55Ah, 480A, 90RC, and 480CCA.
2. Has anyone used BMWLogger to register their battery?
This is a free tool that I used to register my 328i E91 battery two years ago. Wondering if it will work for the MINI. Seems to be able to pull the DME codes...
3. Clarification, if the positive terminal has two wires, it means you have IBS system?
Thank you for any wisdom you can share with me!
Aloha
