Passenger seat occupancy sensor SRS light? No more!!!!
Old Feb 10, 2015 | 06:33 AM
  #151
ptkacik's Avatar
ptkacik
Old seat mats just don't work
The problem is that old seat mats are bad and that is why you are having problems. If you buy one off of eBay it may work or may not. But it is not a long term solution.
Solution one is to buy the seat mat from Mini (my price was $2,000).
Solution two is to reprogram the control to do away with the seat mat control. The two negatives are it is no easy thing to do and you must have the OBDII connector referenced above. Others just don't work.
Reprogramming also makes the airbags fire in a collision even if nobody is sitting in the right seat (the reason the mat is there in the first place).
I reprogrammed mine. BTW, you can reprogram other things while you're at it, such as one touch sunroof).
Old Feb 11, 2015 | 11:45 AM
  #152
justawatcher's Avatar
justawatcher
Exactly... Note that R53's and R56's have different sensors and different ways to reprogram the module. When I reprogrammed my '09 R56 certain airbag(s) enabled/armed when the belt was plugged in and others stayed armed. I don't remember which and results will likely vary from Model/Year to Model/Year.
Airbag systems are not trivial to program and one should always verify the effects of programming (determining whether bags are active/not active) to ensure safety.
Hope this helps..
best,
Old Feb 13, 2015 | 11:01 PM
  #153
scoopy's Avatar
scoopy
bought an emulator for my r53 from srsdrive. my car r53 is an 1/2006 built. no more lights for me for now
Old Feb 14, 2015 | 05:27 PM
  #154
bavmotors's Avatar
bavmotors
You have a link to purchase?
Old Feb 14, 2015 | 06:41 PM
  #155
dannyhavok's Avatar
dannyhavok
Interested in this as well.
Edit, here's the R50/53 one. Would love to hear more feedback before I buy one.
http://www.ebay.ca/itm/Bypass-Mini-C...item258dc5f898
Old Feb 15, 2015 | 07:23 AM
  #156
scoopy's Avatar
scoopy
thats the same. they also include the passenger seatbelt module that you will tap so that it will not churp hehe.. though didn't install it eyt hehehe
Old Mar 24, 2015 | 05:07 PM
  #157
MiniGirl23's Avatar
MiniGirl23
Is anyone remotely near Western Mass who has the software and skills to recode my Mini?
I JUST bought it last week...guy casually mentioned, as I was driving away, that the "passenger airbag light sometimes flickers". I got 50 miles before it came on....and it's stayed on.
Now, of course, I can't get it inspected. It doesn't qualify for any Lemon Laws (2005, too old), and I have called the guy to threaten small claims and he has avoided my calls. Three hours away or I'd go sit on his doorstep. I don't have $1500 right now to get the seat replaced.
I bought the C110 scanner, and it will read the code as "71 - Seat Occupancy Detector". It was supposed to be able to clear it as well, but doesn't, even trying several times in a row.
I'll try the bypass as well, but not convinced it will solve my issue and the shipping is going to take several weeks.
Old Mar 25, 2015 | 03:39 AM
  #158
GoThingNC's Avatar
GoThingNC
Glad I live in NC, airbags are not part of the safety inspection.
Old Mar 25, 2015 | 04:17 AM
  #159
Gusting's Avatar
Gusting
It might be quicker for someone to recode it just to pass inspection (btw you might be able to get a temporary waiver or extension), but replacing the mat isn't as awful as it sounds.
The hardest part is finding a seat on eBay or from a junk yard with a working mat.
FWIW, both of the mats failed were made in France, the working and seemingly revised mat was made in Germany.
Old Mar 25, 2015 | 08:05 AM
  #160
minibx's Avatar
minibx
Originally Posted by Gusting
It might be quicker for someone to recode it just to pass inspection (btw you might be able to get a temporary waiver or extension), but replacing the mat isn't as awful as it sounds. The hardest part is finding a seat on eBay or from a junk yard with a working mat. FWIW, both of the mats failed were made in France, the working and seemingly revised mat was made in Germany.
I wasn't aware that there was ever a revised mat, as far as I know the problem went on and on with 1st Gen MINI's
Old Mar 25, 2015 | 08:12 AM
  #161
Gusting's Avatar
Gusting
The two mats that failed were the 65.77 6989299-02 from France, and the 65.77 6989299-03 from Germany was still working.
I assume there would be a -01 as well.
Something changed, but I have no idea what.
Attached Thumbnails Passenger seat occupancy sensor SRS light?  No more!!!!-img_0333.jpg
Old Mar 25, 2015 | 08:24 AM
  #162
minibx's Avatar
minibx
The two mats that failed were the 65.77 6989299-02 from France, and the 65.77 6989299-03 from Germany was still working. I assume there would be a -01 as well. Something changed, but I have no idea what.
interesting thanks for the great info
I PM the OP with the info of the person that coded mine off hopefully he can get someone in MA to help the OP
You wouldn't have the step by step guide for the coding do you? I had a print out that I gave to my guy when he did mine and it was of great help. Thanks
Old Mar 25, 2015 | 11:11 AM
  #163
Gusting's Avatar
Gusting
I didn't go the software route as there isn't any evidence that I've seen on how the airbag would actually behave in a crash.
Old Mar 25, 2015 | 05:48 PM
  #164
MiniGirl23's Avatar
MiniGirl23
Good to know about the mats. I'm not bothered by replacing the seat, but of course finding a decent used one is still several hundred dollars and this needs to get on the road ASAP. Sold my prior daily a few weeks ago, and have been dailying my 8.1L truck on my 45 mile commute. Ouch!
Minibx emailed me with his connection, so I'm going to get in touch.
Plan for this weekend is to just strip down the speedo and either pull the bulb, or paint/tape over it! :D Desperate times, desperate measures and all that..
Old Mar 29, 2015 | 12:43 PM
  #165
madmike007's Avatar
madmike007
MINI replaced my seat sensor matt in 2010 with the 65.77 6989299-03. Light stayed off for three years, but came back on a little over a year ago. Recently replaced with a used matt (didn't check the number) and the light came back on after three weeks.
MINI needs to rectify this problem once and for all.
Old Mar 30, 2015 | 11:53 AM
  #166
armando95's Avatar
armando95
Has anyone been able to purchase the eBay bypass and then use the computer/coding stuff (which I'm clueless about) to verify if the airbag is actually still operational as if someone occupied the seat all the time? I want to do this but am worried about a passenger if the airbag is disabled...
Old Mar 30, 2015 | 02:31 PM
  #167
armando95's Avatar
armando95
Or how about these:
http://new.minimania.com/part/NMI870...2-53-Cooper--S
I wonder if they carry any sort of warranty...anyone bought one of these? How difficult is it to simply swap the seat bottom?
Old Mar 30, 2015 | 03:34 PM
  #168
rkw's Avatar
rkw
Originally Posted by armando95
It's the same OEM seat bottom a dealer would use. That vendor would order the part from MINIUSA, and you can purchase the same thing at a dealer parts counter.
The whole point of this thread is to avoid buying the expensive, new OEM replacement part.
Old Mar 30, 2015 | 03:45 PM
  #169
armando95's Avatar
armando95
That's what I thought, though it seems strange that people get quoted $1,500-$2k or one person even $4k for a seat. Is the labor THAT crazy high?
I got quoted at $888 from an indy shop for a replacement of the seat cushion to fix the broken sensor. I figured they were getting the part for like $600 and the rest was labor. While it sucks, I could stand to pay $650 and do the replacement myself as I'm fairly handy.
Old Apr 18, 2015 | 10:31 AM
  #170
rkw's Avatar
rkw
An official NHTSA safety recall has been issued. Shame on MINI/BMW for delaying years on a known safety issue.
http://www-odi.nhtsa.dot.gov/owners/...tsa_ids=15V205
Report Receipt Date: APR 06, 2015
NHTSA Campaign Number: 15V205000
Component(s): AIR BAGS
Potential Number of Units Affected: 91,800
All Products Associated with this Recall
Vehicle Make Model Model Year(s)
MINI COOPER 2005-2006
MINI COOPER CONVERTIBLE 2005-2008
MINI COOPER S 2005-2006
MINI COOPER S CONVERTIBLE 2005-2008
Manufacturer: BMW of North America, LLC
SUMMARY:
BMW of North America, LLC (BMW) is recalling certain model year 2005-2006 MINI Cooper and Cooper S vehicles manufactured January 5, 2005, to November 28, 2006, and 2005-2008 MINI Cooper Convertible and Cooper S Convertible vehicles manufactured January 5, 2005, to July 31, 2008. Due to manufacturing, installation, and exposure issues, the front passenger seat occupant detection mat may not function properly and, as a result, the front passenger air bag may not deploy in a crash.
CONSEQUENCE:
An improperly functioning mat may cause the passenger frontal air bag to be inactive when the seat is occupied, and in the event of a crash, the air bag will not deploy, increasing the passenger's risk of injury.
REMEDY:
MINI will notify owners, and dealers will replace the front passenger seat occupant detection mat, free of charge. The recall is expected to begin May 1, 2015. Owners may contact MINI customer service at 1-866-825-1525.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Old Apr 18, 2015 | 03:29 PM
  #171
bavmotors's Avatar
bavmotors
Bout time, soo happy they are finally fixing this.
Old Apr 19, 2015 | 06:06 AM
  #172
skimmilk's Avatar
skimmilk
Frustrating for those of us who own 09 with same issue but no recall
Old Apr 19, 2015 | 07:42 AM
  #173
Gusting's Avatar
Gusting
Years too late. A least we were only out $300 and the better part of a day.
Old Apr 19, 2015 | 10:58 AM
  #174
madmike007's Avatar
madmike007
I was about to come and post this, but I see the good news has already spread.
Anybody know when can we bring our MINI's into a dealer for this recall?
Old Apr 19, 2015 | 11:41 AM
  #175
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Per the bulletin: "The recall is expected to begin May 1, 2015. Owners may contact MINI customer service at 1-866-825-1525."
