Common Problems
Old Apr 16, 2011 | 03:53 PM
Precise's Avatar
Precise
Common Problems
All,
I have a few questions about the common issues people see with the R56s.
1. Are the timing chain and tensioner issues directly related to the "cold start problem"? If so, the 2011s are supposedly cured of this?
2. What are the symptoms of the "carbon build up" that I have been reading about? How do you know if/when you have this problem?
Thanks!
Old Apr 17, 2011 | 05:08 PM
oldsbear's Avatar
oldsbear
Thanks!
The cold start rattle was timing-chain-related. The 2011's don't have a timing chain, so we assume the problem is solved.
I can't help you with the carbon build-up question; haven't experienced it.
Old Apr 17, 2011 | 06:33 PM
ThumperMCS's Avatar
ThumperMCS
....uh, ?
Old Apr 17, 2011 | 08:14 PM
IMAMINI's Avatar
IMAMINI
No timing chain?
Then the 2011 engines have a belt?
I prefer the chains. The problem was to do with the tensioner that allowed the chain to loosen and stretch out requiring replacement. I have mine replaced at 15,000 miles.
Old Apr 18, 2011 | 04:50 AM
oldsbear's Avatar
oldsbear
Originally Posted by IMAMINI
No timing chain?
Then the 2011 engines have a belt? ...
The 2011's use BMW's Valvetronic/Vanos system in place of the normal timing setup. It uses neither a chain nor a belt.
Old Apr 18, 2011 | 05:37 AM
slinger688's Avatar
slinger688
I am confused: this is a link to the 2011 double vanos on the bmwusa site
http://www.bmw.com/com/en/insights/t...ble_vanos.html
It certainly looks like a chain to me.
Old Apr 18, 2011 | 06:02 AM
MCS Fever's Avatar
MCS Fever
How could any engine not have the cam(s) connected to the crank......
Old Apr 23, 2011 | 07:04 AM
swopey's Avatar
swopey
havent you seen the harry potter version of the mini?
http://www.westseattleherald.com/201...r-making-appea
Old Apr 23, 2011 | 08:15 AM
lovemymini07's Avatar
lovemymini07
Let me just say I have a 2011 loaner MCS w/8500 mi. and I can hear the chain rattle at start up and idle So did they fix the problem
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
Sep 2, 2015 09:05 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
mdorn98
Aug 11, 2015 08:49 AM
