Just a Mini engine light on 2 codes P0113, P0342 any ideas?
Old Mar 22, 2011 | 05:31 PM
Jared1010's Avatar
Jared1010
Yesterday my 2007 regular Mini Cooper Automatic check engine light came on a start up. The RPMs was a little high at 1500 and bouncing around a little. It usually runs at 900-1000rpm at a stop. I drive it around a little bit and it's rpms were still a little high coming in to stops. So I took it to Autozone for they could read the codes. Later the light went off and this morning no issues but later in the afternoon it came on again. Any body have these issues or any idea what it could be? Thanks in advance. Codes are below it came up with.
Code 1 P0113:Intake air temperature circuit high
Code 2 P0342:CAMSHAFT POSITION SENSOR NO SIGNAL OR LOW SIGNAL
Old Mar 27, 2011 | 01:44 AM
Jared1010's Avatar
Jared1010
If anybody cares about the outcome of this problem, I took the car to the dealer and they replaced the camshaft sensor and it seems good now.
Old Mar 29, 2011 | 03:25 PM
djDK's Avatar
djDK
how much did the dealer charge you?
Old Mar 30, 2011 | 08:43 AM
Jared1010's Avatar
Jared1010
No charge as it was still under warranty.
Old Feb 27, 2014 | 02:10 PM
renminis's Avatar
renminis
solution?
Old Mar 3, 2014 | 11:50 AM
bmx045's Avatar
bmx045
Originally Posted by renminis
solution?
read post #2 again
Old May 16, 2015 | 10:39 AM
MiniShield's Avatar
MiniShield
Which one?
My CEL is on and doing a scan I come up with the same code of P0342 Camshaft Position Sensor "A" Low. I see that there are 2 sensors. How do I know which one to replace? At close to $100.00 a piece I hate to replace the wrong one. Thanks.
Old May 16, 2015 | 11:45 AM
cerenkov's Avatar
cerenkov
I'm guessing that "A" camshaft is the intake cam (toward the rear side of the engine).
Old May 16, 2015 | 01:20 PM
MiniShield's Avatar
MiniShield
That's what I was thinking also, just wanted to know if anyone knew for sure.
Thanks!
Old May 23, 2015 | 01:45 PM
MiniShield's Avatar
MiniShield
OK. I got the new sensor. I was wondering, when I replace it, do I need to clear the code or will it go out on its own?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Dec 23, 2015 10:36 AM
Lt. Dan
Aug 10, 2015 08:23 AM
quality_sound
Aug 7, 2015 09:36 AM
