Door wont unlock/open from inside? It -might- be as simple as this.
Old Mar 11, 2011 | 10:50 AM
toxictv's Avatar
toxictv
Three bolts on Y, one under reflector, pop panel off. Three clips that hold the cable in place, right in front of you. Is one missing or broken? Replace it with something.
Door wont unlock/open from inside? It -might- be as simple as this.-fdu7l.jpg
Door wont unlock/open from inside? It -might- be as simple as this.-qjvdb.jpg
Door wont unlock/open from inside? It -might- be as simple as this.-55kim.jpg
Door wont unlock/open from inside? It -might- be as simple as this.-8g56d.jpg
Old Mar 11, 2011 | 02:29 PM
steve20607's Avatar
steve20607
Wish it was as simple as that, maybe it cured the problem in your case, but it's most likely issues causing it:
https://www.northamericanmotoring.co...-problems.html
After we discovered the cable piece came out of the plastic holding piece, we did duct tape the loose cable along the interior door panel.
Southern Marylander
Jan 14, 2019 06:05 PM
BRracing
Dec 22, 2015 09:25 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
coachvminis
Aug 17, 2015 01:42 PM
