My cupholder swings like a monkey in a tree
Old Mar 1, 2011 | 05:21 PM
Loony2N's Avatar
Loony2N
Hello, all. Not that this has anything to do with the post, but, for those of you who remember, I used to be LynnEl. Allas, the Lynn & the El have parted company. I have also returned to the ranks of MINI owners, albeit, this time its just a Cooper. Well, anyway, now to the point of my post: The car is equipped with the Mini add-on cupholder. You know, that monstrosity attached to the right center console post, that looks like a kiddie potty. It's loose. It swings left and right with every turn. Is there any way to tighten the damn thing??? It looks like there is some sort of screw holding the cupholder to the bracket, but it facers down and I can't tell if there is a screw of some sort holding it on. Can anyone help. I'm about ready to just rip the damn thing off.
Old Mar 1, 2011 | 06:12 PM
stevendoll's Avatar
stevendoll
Is it the OEM one (has chrome cage) or is it all plastic? If all plastic, it may be the minifini one (although does not usually swing much) if pushed all the way into bracket.
Old Mar 1, 2011 | 06:32 PM
dannyhavok's Avatar
dannyhavok
I had the same one in my '06, I know what you are talking about. It sucks, I couldn't get it to stay put either, so I just ripped the damn thing out. I don't drink and drive anyway
Also, welcome back! Nice Cooper!
Old Mar 1, 2011 | 09:40 PM
Fly'n Brick's Avatar
Fly'n Brick
I removed ours because when it swung to the left it would push climate control buttons at random. I simply removed the top and bottom rubber parts and spread the rods and removed the metal parts from the mounting. Easy peasy.
I wasn't worth a dang holding anything anyway, on a hard turn either direction whatever was in it would fly across the cabin. Worthless add on in my opinion.
Old Mar 2, 2011 | 07:06 PM
Loony2N's Avatar
Loony2N
All plastic
It's all plastic. It appears to be all the way in. It swings around easily enough to be essentially unuseable. Is there any way to tighten it? Anyone? I may just get rid of it, too. Thanks for the welcome back.
Old Mar 3, 2011 | 12:11 AM
Eric_Rowland's Avatar
Eric_Rowland
It's a friction fit - my (uninstalled) unit has significant detents. Best bet would be to shove a rubber plug into the bottom of the pivot arm to give it more contact with the detents. Unless it's worn them down from swinging back and forth...
You can remove the cup portion by squeezing the bottom of the cup pivot and lifting up to check the condition of the detents.
Attached Thumbnails My cupholder swings like a monkey in a tree-img_0012.jpg
Old Mar 5, 2011 | 07:54 AM
OCKOLBY's Avatar
OCKOLBY
glue it
Old Mar 5, 2011 | 05:44 PM
Checkmate_2006's Avatar
Checkmate_2006
hated the cup holder and sold it...
Kimolaoha
Jul 5, 2023 01:04 PM
elverado
Jan 18, 2022 02:51 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Suspension Products
Sep 10, 2015 11:46 AM
honderpilot
Aug 24, 2015 09:25 PM
