Can I prevent valve build up?
Old Feb 9, 2011 | 07:14 PM
phantasms's Avatar
phantasms
Fellow Mini lovers,
I'm picking up a new JCW this weekend.
Are there any preventative measures I can institute so I don't have to go seafoming things down the line?
Thank you!,
Gene
Old Feb 9, 2011 | 07:56 PM
ThumperMCS's Avatar
ThumperMCS
Install an oil catch can....bout the best and only thing you can do to prevent it
Old Feb 10, 2011 | 01:16 AM
czar's Avatar
czar
Originally Posted by phantasms
Fellow Mini lovers,
Thank you!,
Gene
The very best way to prevent and control carbon build up is to fit a water/meth injection kit, not only will it prevent carbon build up (if used regularly) it will also give you a performance gain too!
Old Feb 10, 2011 | 09:00 AM
MINIdave's Avatar
MINIdave
Why are you convinced you'll have it?
There are a few posters here that have the problem, now how many people own 2nd gen MINIs?
What does that tell you?
I would not worry about it.
Old Feb 10, 2011 | 09:09 AM
DneprDave's Avatar
DneprDave
+ 1 on the oil catch can, it also keeps oil out of the intercooler (its original purpose)
Dave
Old Feb 11, 2011 | 07:27 AM
minirab's Avatar
minirab
Run it like you stole it. It will stay clean.
Old Feb 12, 2011 | 10:42 AM
phantasms's Avatar
phantasms
What is the logic behind this? As I run the hell out of my cars I shouldn't have to worry if what you say is true. However based upon what I know about the original problem, I'm uncertain why running it hard would prevent the issue.
Thanks!
-Gene
Old Feb 12, 2011 | 10:45 AM
phantasms's Avatar
phantasms
Because most people don't exactly look at their valves every day. This is not just an issue with Mini's but all direct injection automobiles. The tech was released to the public before it was made perfect. I'm sure most older R56's have the issue...it's just not always obvious as the effects creep up slowly and often don't result in a check engine light (the thing that sadly tells most people there's a problem these days)
-Gene
sempaipaul
Oct 26, 2015 05:56 PM
GregoryK
Sep 10, 2015 10:54 AM
Sep 10, 2015 10:52 AM
kjd186
Sep 9, 2015 10:02 AM
Sep 2, 2015 09:05 AM
