Oil change DIY...can't get bolt off
Old Jan 9, 2011 | 01:38 PM
MC2005s's Avatar
MC2005s
Followed the guide I found on here on how to do the oil change, everything was pretty clear, except I went back to try and get the bolt off with the 13mm wrench and nothing--it won't move. I don't want to try it too much or else it'll strip. I already bought the mobil1 synth oil, so what do you guys recommend I do? should I just take it into the german auto repair shop and give them the oil i bought and have them do it, or should I take it into an evans tire shop and have the guy who we know do it there.
I am confused as to why this screw is so tight I wanted to do this on my own. any suggestions on how to get this thing off???
Old Jan 9, 2011 | 02:06 PM
Vollgas's Avatar
Vollgas
I had the same problem the first time I changed oil on my Mini.
A lot of techs use air wrenches when doing repairs and don't pay attention to the proper torque specs.
At this point you will probally need a new drain plug.
Make sure to get a magnetic one.
You will also need the copper washer for the drain plug.
I got a set of Irwin Bolt Sockets.
It was the only way to get the plug out.
Old Jan 9, 2011 | 02:19 PM
HRM's Avatar
HRM
Wrench may be just too small. I used a 1/2 drive socket and it was still tight. Just make sure you have a good fitting 6 point socket and it will go with a long enough arm.
Old Jan 9, 2011 | 02:33 PM
Eric_Rowland's Avatar
Eric_Rowland
First, make sure you can loosen the oil filter canister!
For low tech/low arm stress, use a low slung jack, put wrench on bolt, put jack under end of wrench and give it a pump or two - voila! Note: Make sure you're turning it the correct way - wrench should be on passenger/left side when looking from front of car.
Old Jan 9, 2011 | 02:37 PM
Agarwaen's Avatar
Agarwaen
Since the drain plugs are disposable, When I changed my oil I used an Easy-out. It ruins the head but no chance of problems with grip.
I've read that putting a small amount of anti-seize on the plug can help the next time. Personally, I'm paranoid it will work its way into the oil. So I don't do it.
Old Jan 9, 2011 | 02:40 PM
Capt_bj's Avatar
Capt_bj
many threads on this ... a good lesson in additional research b4 you begin even something this easy.
Search in the GEN1 area . . .
for example https://www.northamericanmotoring.co...rain-plug.html
I'm cornvinced the culprit is the built-on plastic washer of the OEM plug. Never saw a bung like that b4 and never had problems with stuck bung b4. Buy a Fumoto and say good bye to the problem and end up with a neater and faster job to boot!
(Gen1 doesn't use a copper washer, but we know this is a GEN1 cuz we're trying to use the 13mm recommended wrench. A mistake on its own . . .)
I always get 'em out first time now. A good 1/2 inch socket and a breaker bar. And anyone who asks me for help leaves with a Fumoto.
Old Jan 9, 2011 | 02:52 PM
ballandchain's Avatar
ballandchain
Put a little *** behind it. Just don't put that much on it when you put it back on....
Old Jan 9, 2011 | 02:59 PM
JAB 67's Avatar
JAB 67
Just get a Fumoto and never worry about it again.
Capt_bj's Avatar
Capt_bj
with a cheap 13mm you'll end up with a rounded off bung . . .
with a 1/2 you'll get it off
I've had to get on my back and use my legs to press a 18" breaker bar
Old Jan 9, 2011 | 04:53 PM
MC2005s's Avatar
MC2005s
Thanks for all the advice....found a 1/2 socket and pulled like a mother...got it off and changed my oil for the first time. Pretty easy
Old Jan 9, 2011 | 04:54 PM
Professor's Avatar
Professor
yea I see them on there to tight all the time.
Old Jan 9, 2011 | 05:02 PM
ballandchain
See what a little *** will do for ya? And oil changes on the MINI are easy but not as easy as my Jeep Wrangler with 8" of lift.
Old Jan 9, 2011 | 08:58 PM
vIPkOhH's Avatar
vIPkOhH
Had this problem when I changed oil on my R50...I just simply sprayed some WD-40 on the bolt.
Old Jan 20, 2011 | 12:28 AM
vIPkOhH's Avatar
vIPkOhH
[quote=vIPkOhH;3189812]...............................................
Last edited by vIPkOhH; Jan 20, 2011 at 12:31 AM. Reason: replied to my own post+_+
Old Jan 20, 2011 | 02:03 AM
NightFlyR's Avatar
NightFlyR
+ 1. makes it a snap
Old Jan 21, 2011 | 07:53 PM
SHaFT7's Avatar
SHaFT7
I had to use a boltout on mine. Destroys the head of the bolt, but removed it.
I then went to O'Reillys and their replacement had a 17mm head on it. now it works fine.
Then I changed to the Fumoto valve with the 90 bend to clear my PS fan shroud. Now I'm even more happy.
Old Jan 24, 2011 | 10:08 PM
Fizzyx's Avatar
Fizzyx
Guess it's a common enough problem - mine wouldnt come off with regular hand tools either.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
panerai21
Aug 18, 2015 02:15 PM
ludedude
Aug 10, 2015 07:16 PM
