Power Steering Fan duct replacement
Old Jan 24, 2011 | 07:14 AM
Greg_Dr's Avatar
Greg_Dr
2006 MCS 6 speed - I just finished replacing the fan with a SPAL fan from A1. I added the duct kit to hopefully extend the life of the fan. I was able to confirm that fan kicks on as it should, but I am not sure it is "blowing" the right way. I can feel the air exiting the new vent in the under body panel. Is this correct?
Thanks.
Old Jan 24, 2011 | 10:24 AM
Eric_Rowland's Avatar
Eric_Rowland
It would make more sense for the fan to pull from the vent in front - cool air, rather than pulling hot air from above the PS motor where the engine and exhaust are.
Old Jan 24, 2011 | 01:38 PM
thulchatt's Avatar
thulchatt
Thanks.
Just went the A1 site, which fan did you get?
Old Jan 24, 2011 | 02:09 PM
Greg_Dr's Avatar
Greg_Dr
I ordered A1 #30103018 and I checked that the SPAL part number had an "A" at the end. It is possible that the fan was mislabeled, or I misread it, or somehow the wiring got switched, but before I start troubleshooting all of that, I wanted to confirm that it was indeed blowing the wrong way.
I agree with Eric that intuitively it makes sense that it should be sucking up the cooler air under the car, but I thought it might be possible that due to aerodynamics or air flow under the hood, or some other reason, it might be working as designed. I am just looking for confirmation, one way or the other, how it is working for other owners.
Old Jan 24, 2011 | 05:11 PM
MINI33342's Avatar
MINI33342
It blows onto the pump.
Old Jan 25, 2011 | 12:24 AM
Greg_Dr's Avatar
Greg_Dr
That's what I thought. When I was removing the bad fan, I broke the tab off the wire connector, so I think I may have reconnected it backward. I am pretty sure I have the right fan, but I will check that too. I will jack it up and take a look this weekend. It isn't supposed to get above 36 F this week where I live so I am not worried about it overheating before then.
Etrain
16
Aug 5, 2024 04:37 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
