Brake pad wear sensor light issue (Search was used, need advice)
Old Oct 20, 2010 | 07:20 PM
MINIsotaS's Avatar
MINIsotaS
So to start off I have been researching all night on the internet and this forum with nothing working so please assist if you have any advice.
I am in the process of trading my mini in and i had my brake pad wear sensor light on. The dealership wanted to know what it was and i told them it was the wear sensor but the brakes are all brand new (I forgot to replace the sensor when i did the brake job, but had the new sensors in the garage). They stated it was state law that they were hooked up and working properly so i said i would install them and it would be fine.
After installing a new rear sensor (which was the one that got tripped) I could not get the light to go off, so i replace the front as well. Still the light would not go out.
I tried the turn key 2 clicks and wait 30 seconds (actually waited minutes with no luck)
I tried the trick of pushing the tire pressure sensor button to reset it and that did not work
I disconnected the battery for a good 5 minutes with no luck
I also found a thread on resetting the ecu or gauge cluster via the trip button and followed that procedure as well.
If anyone can think of something i missed or recommend something new i would really appreciate it. I do not want to incur another large bill from the ealer ship to fix this issue. Please help!
Old Oct 20, 2010 | 09:29 PM
hsautocrosser's Avatar
hsautocrosser
If you don't solve it here, ask the dealer for suggestions. The sales manager isn't going to let the service department drive you away.
Old Oct 21, 2010 | 12:20 PM
quikmni's Avatar
quikmni
Sounds like you tried the normal things to reset the light.
Are you sure there still isn't an open circuit in one of the two sensor wires somewhere? Things to check:
Check the wires for any damage, all it takes is a little nick in the wire to open the circuit and cause the light to come on.
Check the connection of the sensor wire to the vehicle wiring harness, make sure it is correctly connected.
Check the sensor to make sure it is not already broken. If you have a test meter or test light disconnect the sensor wire from the harness and verify that there is continuity through the wire and sensor. The sensor can stay in the pad for this test.
With the sensor wire disconnected, short out the two leads at the vehicle wiring harness (connect the two wires together to close the circuit). If the light goes out it is the sensor that is still bad.
Old Oct 28, 2010 | 10:49 AM
Jeddi's Avatar
Jeddi
I've been told that only the dealer can turn it off.
Could be wrong. But it may be a computer reset thing.
Old Oct 28, 2010 | 12:53 PM
ZippyNH's Avatar
ZippyNH
Lots of BAD ADVISE HERE...PLEASE KNOW HOW SOMETHING WORKS BEFORE OFFERING ADVISE!!
On a GEN1 MINI, once the brake sensor is tripped, the sensor...one on the front, and one on the back, must be replaced to get rid of the warning.
The "sensor is just a hunk of wire...when the pad wears down and the wire makes contact with the rotor, the circurit is broken, and the light goes on.
One simple way to fix it...just find the wire for the sensor (the replaceable part) and cut it...then twist the ends together...The light will be out shortly. This was once the ONLY way to get rid of the light, since many pads for a long time did not have the cutout for the sensor.
State law...LOL...NO STATE LAW REQUIRES BREAK WEAR SENSORS!!
Just a sales man talking out is butt.
http://www.waymotorworks.com/brake-pad-sensor.html
Anytime you replace your R50 R52 R53 MINI Cooper or MINI Cooper S brake pads, you need to replace the sensor that turned the light on in the dash. These sensors you'll find in the left front and right rear inner brake pads. As they contact the rotor they break and cause the dash light to come on. Replace this sensor each time you replace the pads to keep the warning system functioning.
Old Oct 28, 2010 | 12:56 PM
ZippyNH's Avatar
ZippyNH
See the above post...on a gen1 MINI, the is no need to go into the computer....just replace or trick the part...and a few cycles of the computer later, it will go out on a GEN1 car.
Old Oct 28, 2010 | 01:06 PM
quikmni's Avatar
quikmni
ZippyNH,
The original poster stated that they had replaced both sensors and still could not get the light to turn off.
Old Oct 28, 2010 | 01:31 PM
Crashton's Avatar
Crashton
This is a timely thread for me. Yesterday I had that blasted brake nanny light go on. Funny thing is at about 6,000 miles I replaced the OEM coal dust pads & tied the sensors up out of the way hoping that I would never be bothered with them again.Most likely road debris has taken one out. This weekend I'll find the broken wire & use my soldering iron.
Old Oct 28, 2010 | 04:14 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by quikmni
ZippyNH,
True, and good point!! But careful reading says he bought them, but forgot to install/bring them to install....
One thing to add....the sensor is not really a "sensor" in the truest sense of the word, just a wire, than when broken will turn off the light. Restore the circuirt...maybe the sensor was bad, a wire got pinched on install, or it is grounding out...but as long as you complete the circurit, the light will go out in a couple minutes/engine cycles....he has done that part, so the loop is still open..the most likely culprit is a loose plug, or the sealant on the wires where it clips to the pad was thin, and it is grounding out...simplest fix, cut the sensor wire, bypass the sensor, and monitor pad life like 75% of the cars on the road...
Old Oct 28, 2010 | 04:38 PM
MINI33342's Avatar
MINI33342
And yes........some states req that ALL SAFTEY WARNING SYSTEMS be in good working order before they can pass inspection. This includes any warning/failure lights on the dash. This is indeed a sensor as it will trip a warning light when triggered, nothing different from the TPMS/tire pressure warning.
As you stated, please know what the facts are before posting.......shheesh
Old Nov 19, 2010 | 01:08 PM
Bulydog's Avatar
Bulydog
brake pad sensor
Is the sensor hard to replace? How do you do it? I had my pads replaced and no sensor available where I am, so thought I would do it when I can, or is it something a mechanic has to do?
Old Nov 19, 2010 | 02:27 PM
Crashton's Avatar
Crashton
If you can replace brake pads you can replace a brake sensor.
Old Nov 22, 2010 | 06:39 AM
Bulydog's Avatar
Bulydog
Very good.
Old Feb 8, 2014 | 11:01 AM
Sidewalksam's Avatar
Sidewalksam
yes back from the dead anyone know at what level of pad wear that the sensor triggers the light? Mine just came on and I measure 5mm + left of pad and the rotors are in great shape.
seems pretty premature to me
Old Feb 8, 2014 | 11:33 AM
markjenn's Avatar
markjenn
Don't have a precise spec but I recall the sensor was exposed with about 2mm left on the pad.
Two likely possibilities: 1) Where you're measuring pad depth isn't the same as where the sensor is; or 2) the sensor has failed, become dislodged in the pad, wiring has failed, etc.
- Mark
Old Feb 8, 2014 | 11:44 AM
Sidewalksam
- Mark
Thanks I was measuring with the rear wheel off using a digital caliper I could see the sensor seem to still be nestled within the pad
I know the pic sucks but here is where I was looking. I changed the fronts last year and they are looking great. I am clearly at 5mm so if you are correct on the 2mm I am confused.
Old Feb 8, 2014 | 11:50 AM
markjenn's Avatar
markjenn
Hard to tell from the picture but it looks like the side of the pad with the sensor is more worn than the other side.
These pad sensors are not precision instruments.
- Mark
Old Feb 8, 2014 | 11:53 AM
Sidewalksam
- Mark
I know I am a terrible person with a camera
I agree that these sensors are not fancy. I am honestly looking for any excuse to not change my brake pads in my very, very, very cold garage.
I think I will just wait off a few weeks and revisit when it's warmer.
Old Feb 9, 2014 | 10:56 AM
Eric_Rowland's Avatar
Eric_Rowland
You should be fine for a few weeks, or months. Especially on the rears, which don't get much use. As long as you've done a visual, you're good. My OEM rotors needed replacing when the pads went anyway.
Old Feb 9, 2014 | 11:19 AM
ZippyNH's Avatar
ZippyNH
2007 hardtop has a DIFFERENT SYSTEM!!
not just a wire like a gen1
BUT a sensor...and a computer with software that estimates break-wear...
try a post in the gen2 section...
Old Feb 9, 2014 | 11:20 AM
ZippyNH's Avatar
ZippyNH
PS you are likely fine till spring....the gen2 computer tends to turn on the light very early...
Old Feb 9, 2014 | 03:37 PM
Sidewalksam
Thanks Eric I am hoping they will last up until March when I hope we can get some better temperatures.
Old Feb 9, 2014 | 03:39 PM
Sidewalksam
Sorry I am on a Gen 1 but thanks
Old Feb 9, 2014 | 08:43 PM
markjenn's Avatar
markjenn
Many of us find that the rears wear faster than the fronts.
I agree you should be fine for a month or two though.
- Mark
Old Feb 9, 2014 | 09:06 PM
ZippyNH's Avatar
ZippyNH
Missed the droptop...lol...glanced at the Sig...thought you said hardtop!!
Toolman
Jan 20, 2016 06:50 AM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
massmini03
Aug 12, 2015 11:19 AM
