Auxiliary / Cigarette Lighter Broken
Old Aug 22, 2010 | 06:03 PM
teleautomata's Avatar
teleautomata
Hi,
I just bought a 07' R56. I noticed that my cigarette lighter isn't working. I checked the fuse (F42?), and it was fine. I also checked the auxiliary in the boot, and it isn't working either. Is there anything else I should be looking for to try and solve this issue? Thank you.
Old Aug 22, 2010 | 11:00 PM
jdmef8's Avatar
jdmef8
See if they're disconnected behind the console. Or try plugging in a different accessory and see if it powers up.
Old Aug 22, 2010 | 11:59 PM
teleautomata
Thanks for your reply. I forgot to mention that I've already tried to disconnect, and reconnect the lighter from its wire harness on the console. I also tried several different accessories (ipod / gps )on the console, and boot, but have had the same result.
Old Aug 23, 2010 | 12:21 PM
jdmef8's Avatar
jdmef8
do you have access to a volt meter? You can use it to check for any blown fuses.
Old Aug 28, 2010 | 04:29 PM
teleautomata
Checked the fuses with a volt meter, and everything was fine. I took it into the dealer, and had the problem fixed in 1 minute. It turns out that the luminous orange ring was broken.
Old Aug 28, 2010 | 09:33 PM
kukaepe's Avatar
kukaepe
I know you have probably already checked this and it's inconsistent with no blowing fuses, but thought I would share my experience with the Cig lighter in my '07MCS. It kept eating fuses...can't remember the fuse number. I finally looked down into the socket and what I saw was a dime...yes a $0.10 piece. It kept grounding the power at the bottom to the outside of the socket. It was actually difficult to fish out but after I did all was well. Just thought I'd mention it.
Old Sep 1, 2010 | 08:24 AM
teleautomata
Thanks for the suggestion. Checking for spare change that may have accidentally fallen into the lighter was actually one of the very first things I tried to solve the issue. I eventually took it to the dealer, and the issue was fixed by replacing the luminous ring. It's #2 in this diagram: http://realoem.com/bmw/showparts.do?...37&hg=61&fg=35
The previous owner of the car may have accidentally pulled the entire cigarette lighter unit out of the console, thus damaging the orange ring.
pglgp1292
Aug 9, 2017 12:45 PM
Fordgt4
Oct 10, 2015 10:42 AM
B1mm3r101
Oct 1, 2015 06:22 AM
daviday
Sep 25, 2015 01:31 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
