supercharger
Old Jun 24, 2010 | 05:05 AM
MariaChick's Avatar
MariaChick
supercharger
My 02 Mini supercharger is failing lots of noise,where can i find a used or rebuilt S C .
Old Jun 24, 2010 | 05:12 AM
cmt52663's Avatar
cmt52663
try this...
use http://www.google.com
type in "site:www.northamericanmotoring.com supercharger replacement" without the quotes
the expression "site:www.northamericanmotoring.com" tells Google to only look at content from these forums
happy browsing -- there are several vendors discussed, and much experience
cheers,
Charlie
Old Jun 24, 2010 | 05:28 AM
Burno's Avatar
Burno
http://www.superchargersonline.com/repair/
Old Jun 24, 2010 | 07:21 AM
ZippyNH's Avatar
ZippyNH
Several vendors, like WayMotorWorks keep A rebuilt SC in stock, and have relationships with folks that know the mini's unique SC (some places do not rebuild the water pump pto correctly, or they just glue in seals, rather than replacing them ).
If you choose to send your SC off for rebuilding, it can take a few days minimum, to several weeks depending on the work that needs to be done, so unless you don't need to drive your mini, most folks do an exchange. Be very careful, one e-bay seller sells very cheap rebuilds, that may or may not last (feeling lucky?) with a good warrenty and glued in seals. A few folks have had good luck, but a few shops that installs them have had several failures, and considering the amount of work to remove and replace a SC, I would reccomend that you pay a bit more and do it once!!
You can sometimes find low mile used SC on e-bay, that may be good to install outright, or may be useable as a core to have rebuilt.
Many different options, just depends on you timeframe, $$, and risk tolerance level.
Old Jun 24, 2010 | 07:22 AM
jimz68's Avatar
jimz68
http://www.stiegemeier.com/minicooper.html
Old Jun 24, 2010 | 08:54 AM
moreorless's Avatar
moreorless
Originally Posted by cmt52663
try this...
cheers,
Charlie
So that's how you use Google search on forums!?!?
How about that!
You just taught this old dog a new trick.
Thanks Charlie!!
...Les
Old Jun 24, 2010 | 02:13 PM
kenatminimania's Avatar
kenatminimania
Here's another site that can rebuild your s/c: http://psesuperchargers.com/.
ken
Old Jun 24, 2010 | 02:47 PM
syn3rgy's Avatar
syn3rgy
I recently had mine rebuilt. Call Dustin from autoxcooper.com, great service, better then a new OEM from dealer (and much cheaper).
You can see my thread here: https://www.northamericanmotoring.co...ater-pump.html
NYMADMINI
Dec 14, 2016 02:33 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
patsum
Sep 30, 2015 02:10 PM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
