Rotational Noise at 50mph
Old Jun 9, 2010 | 05:14 PM
narib2001's Avatar
narib2001
Hello,
2 weeks ago i picked up a 03 mini cooper s used.I love the car however i have a rotational noise that occurs at 50 mph and slowly dissapates until 70mph.I started thinking it was the left rear wheel bearing and i changed that....No difference.I then decided it was my tires...So my friend let me put on his wheels which are new runflats.The noise seems to better but has not dissapeared.The only thing i can think of is that it is another wheel bearing. If i turn the car sharply to the right while it is happening the noise goes away...Any other ideas?Is a low decible noise that the average persone would probably not hear.However it drives me crazy
Old Jun 9, 2010 | 05:54 PM
minitech829's Avatar
minitech829
it sounds to me like you replaced the wrong wheel bearing unless i am missing something. because if the noise goes away when you turn sharply to the right, then i would diagnose it as a bad passenger side rear wheel bearing. because when you turn sharply to the right, the pressure is being taken off the right and put on the left side of the car.
Old Jun 9, 2010 | 06:02 PM
narib2001's Avatar
narib2001
I totally agree man...Its just that i swear the noise was coming from the left rear....However a driver will be biased as they sit on that side.When i swapped the wheels today i took off the right rear and the bearing looked very old and rusty compared to the one i took off yesterday(when i replaced it).I still have the old left bearing.Im gonna swap it and see it goes away.
Old Jun 10, 2010 | 03:15 PM
narib2001's Avatar
narib2001
Put car on a lift today.Right front side is making noise...Not sure if its a wheelbearing or something else.Anyone else have any idea's?
Old Jun 10, 2010 | 06:00 PM
Cadenza's Avatar
Cadenza
Bearing noise usually indicates a bearing falling out of spec (too much free play). Sometimes you can tell by holding the wheel by 12 and 6 o'clock and wiggle it (while the vehicle is raised). It should be tight.
The front wheels are bit more tricky to diagnose because they're attached to axles whose CV joints which sometimes make noise. But CV joints are more likely to sound "click, clunk" than a hum.
Old Jun 11, 2010 | 03:18 PM
narib2001's Avatar
narib2001
Update...put car on lift and the noise was there from 50-70....Locked one wheel and the noise happend.This was the passenger side...Locked the passenger side and no noise from the drivers side.Replaced right front wheel bearing....Noise is still there....Anyone else have any ideas?Im all out of ideas...
Do these diff's make slight noise?Will changing the tranny fluid help this?
Old Jun 11, 2010 | 03:45 PM
Cadenza's Avatar
Cadenza
My 6-sp ('06 MCSc) doesn't have diff noise but some cars do. My '01 VW automatic has a diff whine at 40-45mph and 70-75mph since new.
Old Jun 11, 2010 | 04:48 PM
narib2001's Avatar
narib2001
Well im not sure if its a diff noise....It sounds like the tires are chopped from 50-70 or so...My girlfriend says im just being over critical.However if you were to daily drive the car it would drive anyone crazy....
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Miniwaukee
Sep 29, 2015 09:22 AM
