HELP: Spontaneous engine bay fire
Old Jul 25, 2010 | 11:32 AM
  #51
Carlisle's Avatar
Carlisle
Originally Posted by freeman727
I also had the same problem with the burned auxillary water pump! Here is a quote from my receipt:
TEST DME FAULT CODE 2F37 AUXILLARY WATER PUMP FOR TURBO CHARGER ACTIVATION FAULT CURRENTLY PRESENT. CHECK AND FOUND AUXILLARY WATER PUMP FOR TURBOCHARGER BURNT, CONNECTOR AND WIRES ALSO BURNT. REMOVED FRONT BUMPMER REPLACED AUXILLARY WATER PUMP FOR TURBOCHARGER, REPLACED CONNECTOR, REPLACED PIN AND WIRES THAT WAS BURNT CHECK AND FOUND POWER AND GROUND AT AUXILLARY WATER PUMP AFTER REPAIRS - BLED COOLANT SYSTEM REINSTALL FRONT BUMPER RESET ADAPTATION AND CLEAR FAULTS
I feel bad starting a new thread about my engine fire experience since this one already existed. Does anybody know is this an engineering problem that could cause MINI to have a recall?
Make sure you contact MINI USA and tell them about this problem. I'm on a first name basis with the one of the gentlemen that works at MINI Canada. An engineer from BMW/MINI was sent to examine my car on July 7th I believe. I am still waiting to hear what she/he discovered.
Old Jul 25, 2010 | 12:19 PM
  #52
tvrgeek's Avatar
tvrgeek
As burning down a car seems to be a safety issue, and this is not an isolated incident, I think MINI or NTSB should be doing something about it. Be sure both know about it.
Just looking in the very tight spaces, I think I see the cable in question and it sits right against a sharp edge. A bit of plastic loom would fix it right up but I can't reach it. That does not explain a burnt motor. A fried motor should blow a fuse. Either case, sounds like a safety design fault.
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
