I have a serious problem.
Old Dec 12, 2009 | 06:14 AM
Fatandre's Avatar
Fatandre
I let my mom use the car and when she drove out of the garage I found this!!!
What is it????
Old Dec 12, 2009 | 08:08 AM
MINIdave's Avatar
MINIdave
Hard to say for sure, but looks like it could be anti-freeze. If you taste it and it tastes sweet, that's what it is.....
WordIsBorn's Avatar
WordIsBorn
I think your mother may have been so excited to drive your Mini, that she pissed herself!
03BRG's Avatar
03BRG
My guess its antifreeze
Old Dec 12, 2009 | 08:09 AM
03BRG's Avatar
03BRG
funny 3 replys same time P.S. don't taste it!
Old Dec 12, 2009 | 08:10 AM
Fatandre's Avatar
Fatandre
why would it be leaking? The leak is on the middle of the floor.
Old Dec 12, 2009 | 08:12 AM
03BRG's Avatar
03BRG
leaking by the water pump if its a S- Have read its a common place to leak
Old Dec 12, 2009 | 08:13 AM
Fatandre's Avatar
Fatandre
how can I fix it?
Old Dec 12, 2009 | 08:17 AM
NightFlyR's Avatar
NightFlyR
check your overflow tank and look at the bottom of the hose, see if it is wet.
03BRG's Avatar
03BRG
Need to find the leak first- maybe a easy fix but till you can pin point it we really can't help
Old Dec 12, 2009 | 10:19 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
My antifreeze is blue, not sure what that is; has the coolant system been flushed before by someone other than the dealer? What year is the MINI?
I would also check the brake/clutch fluid and look at the bottoms of the calipers to see if they are wet as well; if your MINI is an 02 or 03 and brake/clutch fluid is like coffee, the caliper seals could have worn due to rust in the line/calipers.
Just a guess.
Was the oil changed recently? I know it looks a bit watery, but it does have the color of clean oil; maybe a leak around the drain plug or cannister o-ring?
Old Dec 12, 2009 | 10:43 AM
Fatandre's Avatar
Fatandre
Just a guess.
The mini is a 2005
Old Dec 12, 2009 | 10:51 AM
rkw's Avatar
rkw
Mine too. Look at your coolant overflow reservoir. If the fluid there isn't the same color as the leak, it isn't antifreeze/coolant. Another common coolant leak for MINI is at the thermostat.
Where exactly? Under the engine compartment? Left or right side?
Old Dec 12, 2009 | 10:55 AM
Fatandre's Avatar
Fatandre
I dont know. My mom was driving out of the garage.
Old Dec 12, 2009 | 11:04 AM
lawmann's Avatar
lawmann
I've developed the thermostat leak and it was a blue fluid...both times. The 05 MINIs used the blue fluid, my wife had an 05 cabrio and the antifreeze in it was blue too.
As suggested here, check:
overflow tank
thermostat housing
calipers/hoses/clutch slave cylinder
oil drain plug
oil cannister
I would think one of these items would be wet with fluid.
Please let us know what you find.
Old Dec 12, 2009 | 11:07 AM
Fatandre's Avatar
Fatandre
The main problem is that I just bought the car and it has never had any maintenance done except oil change. I am working on all that now. Have changed the Oil 3 weeks ago, new belt, ordered new filters, new wishbone bushes.
Old Dec 12, 2009 | 11:14 AM
Fatandre's Avatar
Fatandre
Just talked to a friend and he said it was antifreeze and said it was normal.
I am confuzed
Old Dec 12, 2009 | 11:18 AM
lawmann's Avatar
lawmann
I am confuzed
Leaking antifreeze is not normal, I would trace the leak down and fix it as soon as you can.
I would go to a nearby parts store and invest in an inspection mirror and flashlight and look for that leak.
Old Dec 12, 2009 | 11:22 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
Clean it up quick.
Not only should you not taste it, if you have any pets you need to clean it up ASAP.
It's poison to pets in the smallest doses.
Old Dec 12, 2009 | 11:26 AM
Fatandre's Avatar
Fatandre
he said that when there makes pressure in the there it lets loose some fluid to get rid of the pressure
Old Dec 12, 2009 | 11:28 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Is your MINI an S or not? Does/did it feel like oil or water when rubbed with fingers?
Old Dec 12, 2009 | 11:30 AM
Fatandre's Avatar
Fatandre
The car is a 2005 Mini Cooper S
It felt like water.
Old Dec 12, 2009 | 11:38 AM
AutoXCooper.com
Should be BLUE and if not it will cost you GREEN
overflow tank
thermostat housing
oil drain plug
oil cannister
Lawmann is right. Read this link http://www.popularmechanics.com/how_...e/1272436.html
BMW MINI uses BLUE for a reason and not running BLUE, yes it costs more then many others, but what you or the last person thought they were saving could cost you big time.
I'd get it to a indy BMW Shop ASAP and have the WHOLE system inspected and change whatever needs to be changed and then get the BLUE stuff in there and make sure they get all the air out of the system too.
PS, don't let that MINI overheat. If you see the temp gauge climb up to 75% pull off the road where you are, turn the car off, open the hood and call a flatbed. Over heating it will cost you much more then a tow.
Old Dec 12, 2009 | 11:42 AM
Fatandre's Avatar
Fatandre
so you are saying I am running not a blue antifreeze?
Old Dec 12, 2009 | 11:45 AM
AutoXCooper.com
based on the pics and above text I'd bet you are not running blue. The only other stuff that could leak from that part of the car is oily.
