Broken Control Arm Bushing... How is this affecting me?
Old May 10, 2009 | 01:01 PM
staz87's Avatar
staz87
Gary Gray at BMW Nashville told me this wasn't a safety issue, but is it a performance issue?
How does this affect my driving experience?
Also, I was quoted $850 to fix, does this sound right?
Thanks!
Old May 10, 2009 | 08:28 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The toe for that wheel will be all over the place under nearly all conditions.
For $850 they better be doing the bushings on both sides, unless that includes the part too.
Old May 24, 2009 | 12:55 PM
staz87's Avatar
staz87
It feels like the wheel jerks sometimes, is that the result fo the broken bushing?
If I was to AutoX it would this be a dealbreaker?
Old May 24, 2009 | 02:09 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The longer you run with a bad bushing the more tires you'll eat monthly and "safety" is the dealers CYA statement. $850 is a little high, check out http://www.autoxcooper.com/control_a...e_service.html for the DIY deal . You will also need an alignment to bring everything back to spec that's another $100 +/-. I'd do them sooner then later but not at the dealer if you can find a local performance shop to do it.
Old Jul 22, 2009 | 11:02 AM
agranger's Avatar
agranger
I was quoted $500 to $550 (Including parts... not including the alignment) for this replacement.
Old Jul 22, 2009 | 11:08 AM
AutoXCooper.com
What parts?
Old Jul 22, 2009 | 11:57 AM
agranger's Avatar
agranger
Good question! Stock OEM bushing. Powerflex would be an additional expense.
This was from a solid tuner shop in the Dallas area.
Old Jul 22, 2009 | 12:01 PM
AutoXCooper.com
if you don't want the OEM rubber bushing check out http://www.autoxcooper.com/control_a...e_service.html and have the shop do the labor. I bet the upgraded bushing service is about same parts price as the OEM that will fail again.
Old Jul 22, 2009 | 01:43 PM
Capt_bj's Avatar
Capt_bj
I found an independent BMW shop that did this replacement - with PowerFlex - for half what the dealer wanted. The GEN1 front was very similar to the small BMWs it seems. He had no problem doing it and had a tool so he could also do it without dropping the sub-frame.
Sorry - this was in Norfolk tho ....
67morris
Dec 1, 2015 12:53 PM
ej
Nov 17, 2015 09:21 PM
Norton70
Sep 7, 2015 05:06 PM
Sep 3, 2015 12:24 PM
Suspension Products
Sep 3, 2015 09:41 AM
