Augh! My passenger side door is warped. :x
Old Sep 14, 2003 | 06:25 PM
Nicky's Avatar
Nicky
Old Sep 14, 2003 | 08:18 PM
Moorlockx's Avatar
Moorlockx
Hopefully it'll just turn out ot be the door is out of adjustment. That should be a pretty easy fix. (he said crossing his fingers for luck!)
Old Sep 17, 2003 | 03:09 PM
MG-BGT's Avatar
MG-BGT
>>:xI noticed a whistling coming from the passenger side. The door appears to not to be closed all the way. It seems to be secure so I am not too worried. I have yet to take it to the shop. I am hoping it is an easy fix. I will be sure to post an update.
Could it be the window (glass) only, or have you seen that the metal part of the door is agap? If the window dipping function quits (which it does more or less often, depending on car), then the glass is too high up in teh frame and will overlap the roof-lip, possibly resulting in the whistling. Check the glass and door to see, and if this is the problem try the dip-reset:
close door, roll window all the way down, and then again all the way up and hold switch in up position for 8-10 seconds.
M.
Old Sep 19, 2003 | 12:48 PM
BMWNA's Avatar
BMWNA
I’ve sent you an email offering our help. If you prefer, you can call us at 866-ASK MINI.
Old Sep 23, 2003 | 04:43 PM
Nicky's Avatar
Nicky
Well, it was an easy fix. I picked up my car from the shop yesterday. They adjusted the door striker. But my car is back in the shop...
She is getting graphics put on. I had to get the door straight or the graphics would have looked all jacked-up. I will be sure to post some pic's.
Old Sep 23, 2003 | 05:20 PM
MG-BGT's Avatar
MG-BGT
Glad you got your car fixed!
Let's see those pics!
I'm getting ready to add some graphics to mine as well, but as magnetics first to see if I like it.
Will post pics soon.
Old Sep 24, 2003 | 09:56 PM
Yeagy's Avatar
Yeagy
How much was it to fix? I have the same problem from my door being almost shut with my leg in the way, now the bottom half is like 1/2inch out and the top is tucked in 1/8th of an inch...i can see it from 5-10 feet away and it looks like ***....any suggestions would be nice...i went for an est. and they said a little under a grand...i said thanks and walk away...
-yeagy
sevin
May 2, 2026 06:11 AM
boostedhaze
Jan 2, 2018 07:26 PM
RACEnSK8
Aug 31, 2015 01:08 PM
Lex2008
Aug 31, 2015 12:12 PM
polotska
Aug 23, 2015 03:03 PM
