6000RPMs, Limping, Check Engine, EML, DCS lights.
Old Aug 2, 2008 | 08:24 AM
syfted's Avatar
syfted
Here's the skinny. My MCS has 56,000 mi on it, running 93 octane, though I don't know what the previous owner ran.
Should I get my MCS up to 6000 rpms (Which I'm assuming isn't too-too high, though I know I'm getting close to the redline), the car throttles back and I have to limp to the side of the road. Check Engine, EML, and DCS lights all switch on.
If I turn her off and back on, my Check Engine light stays on, but my EML/DCS lights turn off. She runs fine- until you try and get her to 6000rpms again. The Check Engine light eventually turns off hours later.
I know I need to get the code read. Any ideas in the meantime?
Old Aug 2, 2008 | 09:05 AM
Warped1966's Avatar
Warped1966
Autozone stores usually will pull codes for free but I don't know if they have the right equipment for Minis. It's worth a shot. Post what the code(s) are here and I'm sure someone can give you an idea of what's wrong. Hope this helps!
Old Aug 2, 2008 | 12:00 PM
AliceCooperWA's Avatar
AliceCooperWA
+1 for that. No one will be able to help too much with out details on the codes. Go to an autozone and get it read for free.
Old Aug 3, 2008 | 06:39 AM
techtipz's Avatar
techtipz
The codes will give you a better answer but im thinking possibly a by-pass valve. Take a peak at it and see if anything is hanging it up. Have you had any work done recently?
Old Aug 3, 2008 | 08:45 PM
syfted's Avatar
syfted
No, I just bought this car used from a dealer. I just discovered, she doesn't limp out on me if I hit 6000RPMs in 1st gear... only in 2nd gear (or higher, I'm assuming, but I don't have enough open road out here to test 3rd gear). I'm going to check the codes tomorrow.
Old Aug 3, 2008 | 08:52 PM
Haggardsk8er's Avatar
Haggardsk8er
Doesn't sound like bypass valve... That shouldn't throw it into limb mode...
I am puzzled since you are running 93, detonation seems like it shouldn't happen either... what mods does it have if any???
Old Aug 3, 2008 | 09:20 PM
syfted's Avatar
syfted
Nothing. She's your stock 03 Cooper S, single owner, clean carfax. This is worrying me a fair bit. It's really, really odd that she wouldn't limp in first gear, too.
Old Aug 3, 2008 | 09:28 PM
Haggardsk8er
Yes is it... thats what got me...
Pull those codes asap and go from there... hopefully it'll be something simple...
Old Aug 4, 2008 | 11:44 AM
syfted's Avatar
syfted
OKAY, so the error code I'm getting is the common P1688.
Also... if I turn DSC off... sometimes she bonks on me... sometimes she doesn't. Strange...
Old Aug 4, 2008 | 12:12 PM
Haggardsk8er
Thats the only code???
Old Aug 4, 2008 | 12:14 PM
syfted's Avatar
syfted
Yeah. That was it. Came up twice.
Old Aug 4, 2008 | 12:18 PM
Haggardsk8er
P1688 should be "Electronic Throttle Control Monitor Level 2/3 Mass Air Flow Calculation", yes?
Old Aug 4, 2008 | 12:19 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Just did a quick search on p1688 and by everyone who posted about that code it seems to be the bypass valve.
Old Aug 4, 2008 | 12:20 PM
Haggardsk8er
I did as well... that quote i threw up was from another thread on a car that was a non S..... so which one is correct?
Old Aug 4, 2008 | 12:21 PM
Haggardsk8er
BPV shouldn't throw it into limp mode...
Are you seeing any signs of yo-yo???
Old Aug 4, 2008 | 12:33 PM
syfted's Avatar
syfted
I don't think I'm seeing any signs of the yo-yo, no...
Old Aug 4, 2008 | 12:39 PM
syfted's Avatar
syfted
"Electronic Throttle Control Monitor Level 2/3 Mass Air Flow Calculation" is the P1688 code. All of the Mini's I've read about which throw that code have a bypass valve issue, and it usually does throw the car into a limp.
http://www.motoringunderground.com/f...ead.php?t=4149
...but I'm not certain it's the bypass valve. Thoughts?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
miniuy
Oct 7, 2016 12:09 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
