How to fix sunroof rattle
Old May 13, 2008 | 11:53 AM
dLiTaz's Avatar
dLiTaz
by any chance any one has found a way to fix the sunroof rattle?
the noise seems to be coming from the rear sunroof, the one corner (right rear) doesn't seem to close completely and is causing the noise.. if the sunroof is slightly opened, the noise is gone..
just wondering if any one has a fix for it, if I can avoid a trip to the dealer that will be nice..!!
thanks,
Old May 13, 2008 | 12:57 PM
Oxybluecoop's Avatar
Oxybluecoop
WD-40
Old May 13, 2008 | 03:48 PM
jimmiejo's Avatar
jimmiejo
My rattle is in that area too, but its coming from the plastic frame. When it starts rattling I reach back and press it a little and it stops. I tried stuffing some small pieces of felt strips between the frame and headliner and thought it was fixed but it started again today. Does anyone have a good fix for this ?
Old May 17, 2008 | 10:56 PM
ScottSellersUNR's Avatar
ScottSellersUNR
new owner here, but i didnt even know the back sunroof opened?? mine isnt electric anywyas.. how does it open?
But its my front sunroof that rattles.. id love to get it fixed
Old May 17, 2008 | 11:02 PM
byhsu's Avatar
byhsu
If you have an R56, both panels will tilt but only the front will slide back.
Old May 18, 2008 | 02:12 AM
ghosthound's Avatar
ghosthound
You probably just dont look back when its open... they both tilt to the "vent" position but only the front one slides back.... funny question my friend had... "why doesnt the back one open up also?" then i asked him, where did the front panel go? RIGHT ON TOP OF THE BACK ONE!! then he was like... oh... i guess that makes sense haha.
anyway, i had a problem with my sunroof as well. The back panel would make a vibrating noise when it was open but the front one was fine. I brought the MINI in for this and another problem and they tried adjusting it but nothing worked. They had to eventually change out the sunroof cassette which solved the problem. The bill would have been 2200 bucks!!
luckily its all under warranty.
Old May 18, 2008 | 09:41 AM
Minidrivr's Avatar
Minidrivr
My sunroof were completely silent. Then the dealer installed the rubber stops to keep the sunshades from sliding back on their own. After this, my sunroof had a very annoying rattle when hitting any kind of bump (sport suspension, runflats). Later when I had the car back to fix a paint issue, I had them check out the rattle. It turned out to be a washer on a screw that wasn't fully tight. When they installed the rubber stops, they remove the glass from the top. They missed fully tightening one of the screws. You might want to make sure all the screws you can find up there are tight. I'm not really sure which one it was or I would post a picture. Just something else you guys might consider.
I get the same dash "creaking" over rough roads. You can kind of push/squeeze the outside vents and make it creak more. It's kind of funny in a modern car they can't seem to get the dash panels to not make noise. It tend to refer to it as "my car is being British" today whenever I hear this type of noise. I've pulled apart some of the dash and think they just don't use clips that are tight enough compared to removing panels in other brands of cars.
Old May 18, 2008 | 02:05 PM
ScottSellersUNR
my back one does not tilt when i tilt or open the front one.... maybe its broken..lol but its silent and i dont really need it open so it wont matter to me.
Old May 18, 2008 | 02:23 PM
Striped Toad's Avatar
Striped Toad
This fixed the rattle i had:
take 2 rubber bump stops (i think any hardware store or electronic store should have em, they are about a 1/4 inch with an adhesive back), put one on either front wind screen-the side that faces back when they are up (youll have to move around the placement for what works for you, this worked for me). Havent had a single rattle since. Beats stuffing things up there to baffle it!
Hope it works!
Old May 18, 2008 | 02:32 PM
NYCrooner's Avatar
NYCrooner
Is this a problem on all Mini's w/sunroof?
Old May 18, 2008 | 02:44 PM
Striped Toad
dnt knw, but have heard of several that are near me.
Something else to add, you can try tightening the torx screws located throughout the sunroof as well.
Old Nov 13, 2008 | 10:49 PM
leevitup2god's Avatar
leevitup2god
I found a detailed website offering photos and step by step instructions on how to fix the sunroof here's the link http://zippeegear.com/documents/blog..._id=1215268800
Old Nov 13, 2008 | 10:55 PM
leevitup2god
Old Nov 14, 2008 | 02:11 PM
MrTIer's Avatar
MrTIer
Don't get one in the first place!
Sorry, not trying to be mean, but this thread was 50% of the reason I didn't get one. Cost = other 25%. Can't block out the sun totally = 25%
Old Nov 14, 2008 | 02:48 PM
Browser_23's Avatar
Browser_23
I did not get one because I don't use them. last 3 cars over 8 years have had them and I can count on one hand how many total times in those 8 years I opened the sunroof. No sunroof on Jade.
Old Jan 23, 2009 | 04:44 PM
pepegrande008's Avatar
pepegrande008
I wish i didnt have one, all the extra sun in the car sux. has anyone used those blackout things they sell on ebay for the slider shades?
Old Jan 23, 2009 | 05:25 PM
leevitup2god
You should check out the Zippee Shade website
Here is their website http://zippeegear.com/documents/products.html. I've got one in my Mini and I love it. I was debating on either tinting it or putting a piece of cardboard in it and thank GOD for this item. Cheers....
Old Feb 11, 2009 | 08:11 AM
jjsherlock46's Avatar
jjsherlock46
I love my sun roof - had it tinted "limo" and that takes care of the sun blast. Great ventilation cracked open and the extra light makes me happy. Mine has an annoying rattle that is fixed by opening or closing the sliding "sunscreen" - can't remember which way to move it, but moving it ends the squeak coming from that area.
Old Feb 11, 2009 | 11:16 AM
Perihelion's Avatar
Perihelion
I've had sunroofs in my last 2 cars and both times I loved having it. I use them all the time despite living in a place where 8 months of the year its cold. However, when I ordered my MINI, I though about all the sunroof threads I saw on NAM and decided against it. Also, I didn't want the extra weight right at the top of the vehicle and the MINI's sunroof isn't exactly small...
Old Feb 11, 2009 | 07:01 PM
pilotart's Avatar
pilotart
Have had mine for nearly ten months now, never the first rattle or squeak.
I usually have it open, but when closed, it is silent and completely sealed.
I use an 1800 PSI Pressure Washer to clean and it has never leaked a drop.
Without that great sunroof, I would never have bought the MINI Coupe.
Old May 4, 2010 | 11:01 AM
mike1327's Avatar
mike1327
fixing sunlight problem
buy a piece of vinyl (oversized) from your local signage shop. they are the only place to find vinyl wider than 24". i think you need at least 40".
slap it on, and enjoy no sunlight when closed. also, i got white to match my white roof, and it looks awesome.
should only cost about $25 - $50 total.
Old May 4, 2010 | 06:32 PM
strobeyprobey's Avatar
strobeyprobey
My sunroof has been adjusted a few times at the dealer, the last time, it was sooooooo squeaky and thunky I was going crazy. Upon venting the noise went away entirely. The dealer did fix for me. Also, they fixed a very common loose trim ring inside that upper console.
ToyCar
Nov 19, 2023 05:20 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 8, 2015 11:37 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
