Dislocated Shifter Knob
Old May 11, 2008 | 09:20 AM
KTrout's Avatar
KTrout
Dislocated Shifter ****
Anyone else have their shifter **** come off during heavy acceleration? I had this happen a couple of weeks ago, and found it very disconcerting. It slipped right back on, but geez, I'll never hold onto it quite that firmly again. :-)
Old May 11, 2008 | 09:24 AM
Floridabob's Avatar
Floridabob
Mine too. I ended up glueing it in.
Old May 11, 2008 | 09:35 AM
FLKeith's Avatar
FLKeith
Mine three - how did you glue it in?
Old May 11, 2008 | 10:27 AM
Robin Casady's Avatar
Robin Casady
A plastic flange inside the **** holds the stock shift **** goes into a groove on the shift lever to hold it in place. Gluing it may be a bad idea as the dealer may need to remove it to perform some repairs or service.
http://www.robincasady.com/ShiftKnobs/Installation.html
If you want a **** that is held in place more securely, get one of my wooden *****, or Doug Whalen's stainless steel *****. Both use a stainless steel adaptor machined by Doug.
Old May 11, 2008 | 12:09 PM
Krafty04's Avatar
Krafty04
Those are covered under warranty.
KTrout, your car is like 2 weeks old, take er' in!
Old May 11, 2008 | 12:45 PM
tdm156's Avatar
tdm156
Ruling the curves
You could always get a Whalen Shift Machine and take care of that problem
Old May 11, 2008 | 03:41 PM
Floridabob's Avatar
Floridabob
FLKeith,
I just used a light duty glue, works fine and can removed easily if necessary by anyone. If you are under warranty, have service dept fix it. No need to buy another **** !!!
Old May 11, 2008 | 04:03 PM
Kilted's Avatar
Kilted
+1 Whalen ***** are great.
Old May 11, 2008 | 07:16 PM
miniclubman's Avatar
miniclubman
ktrout - wow! If that ever happened to me, I would take it to the dealer to get it fixed, and also file a formal complaint with NHTSA. This is certainly a safety issue. Your vehicle's controls shouldn't come off in your hand while driving!
Old May 12, 2008 | 12:04 PM
mellowmcs's Avatar
mellowmcs
This is a fairly common problems in BMWs. Specially the M models, I would imagine it's because the more enthusiastic acceleration available in the M model
I find that once it comes off, it will come off again and after a few times, it becomes easier and easier...
Old May 12, 2008 | 05:02 PM
miniclubman
Gotta love that precision German engineering! They build some of the most sophisticated engines in the world, then can't get the shift ***** to stay on!
Old May 14, 2008 | 06:08 PM
MiniMedic's Avatar
MiniMedic
have the same issue with my 89 535i. or i should say had as i just sold it to pay for the cost of getting my mini into production. funny the new owner didn't even flinch when i told him about the ****..
Old Jul 15, 2008 | 07:36 PM
Bandit's Avatar
Bandit
bump!
Mine came off too, its very annoying. how would the dealer fix the problem, wouldnt it just happen again?
Old Jul 15, 2008 | 08:47 PM
mellowmcs's Avatar
mellowmcs
Originally Posted by Bandit
bump!
new **** usually solves the problem. a few people on the bmw board wrapped several layers of telfon tape but i'm not sure how well that works...
Old Jul 15, 2008 | 08:57 PM
ChiliXer's Avatar
ChiliXer
You guys must really hold on tight to it or something. I remember test driving a used honda once a long time ago with the same issue. Being aggressive with the shifter probably increases your risk of misshifting because you loose the feel.
Old Jul 16, 2008 | 12:32 PM
sk8erguyzach's Avatar
sk8erguyzach
lol i had that problem with my test drive 1st to 2nd and the **** poped off but still got one anyways hope mine dont pop off if it does gorilla glue works magic
Old Jul 16, 2008 | 08:35 PM
Ryephile's Avatar
Ryephile
Easy there He-Man, you're just trying to change gears, not arm wrestle the car! The R56 has virtually no shift effort, use an open palm and your shifts will be significantly more precise...and you won't end up yanking it off during your "red mist" moments.
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
aldito2
Sep 30, 2015 10:44 AM
