Use of non-MINI coolant
Old Dec 4, 2015 | 09:07 AM
  #26
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Originally Posted by systemshock869
Logged in to say thanks for the explanation! I recently drained my system and found green dexcool, installed by a Chevy dealership :facepalm:. All of the exposed surfaces of the cooling system that I encountered were covered with brown slime. I am sure that 'universal' coolant can be used for a long time without issue but I don't trust that it is 100% safe. Though possibly there could have been residual blue coolant that mixed and reacted with the green. I'm running straight distilled to flush it out and will be going blue from here on out.
You're very welcome. Glad that information was useful to you. Good luck with the process and if you need anything be sure to let me know.
888.280.7799 | 6am - 5pm PST
Old Dec 4, 2015 | 09:52 AM
  #27
systemshock - Flush it out several times and get it changed back to the blue coolant, mix with 50/50 distilled water. It might take a couple times to get it all out.
https://www.ecstuning.com/Search/Sit...h/82140031133/
Old Jul 24, 2019 | 06:52 AM
  #28
Zoom234450's Avatar
Zoom234450
Systemshock flush cleanse
Is this the best product to flush and clean out the cooling system? Over the last two years I’ve began to notice the brownish slime buildup in the coolant reservoir. I just hit 150k and I’m about to replace the crossover water pipe, so this will be a great time to flush as well before I refill. Also, how many gallons of distilled would you recommend I flush with before finally refilling with coolant?
Old Jul 24, 2019 | 07:05 AM
  #29
2 full bottle of MINI coolant mixed 50/50 with distilled water will do it and have some leftover. https://www.ecstuning.com/b-genuine-...82140031133kt/
Run its till you see clear distilled water if you flush it without new mixed coolant. Then flush out with mix till you see the blue coming out one end. Like doing a brake line flush.
DEI works good: https://www.ecstuning.com/b-dei-part...sh/040202~dei/
So is this stuff: https://www.ecstuning.com/b-liqui_mo...00ml/2051~liq/
Check them out and read up, go with what you prefer.
yyj3869
Jan 27, 2013 07:52 PM
yyj3869
Nov 6, 2011 11:51 AM
cobalt17
Feb 1, 2009 11:39 AM
sprp85
May 14, 2006 07:49 PM
hyperblue1
Jun 26, 2005 07:17 PM
