Cold start chatter
Old Mar 30, 2009 | 08:53 PM
  #976
yubman's Avatar
yubman
Originally Posted by oldMGguy
OK, everyone, just got word from Ann, the world's nicest SA at Portland's Rasmussen MINI, that BMW has moved on to Version 3.1 of the start-up "death rattle' repairs. BMW/MINI has just sent a directive to their dealers to now replace everything - new tensioner, guides, chain, sprockets, and Vanos unit. The job takes two shop days to accomplish. The right front inner fender liner is removed to provide access to the front of the engine. Apparently, just replacing the tensioner unit alone wasn't completely solving the problem. Ann also says she is able to get all the parts needed without significant delays.
Again, a tip of the hat to Rasmussen MINI for doing the right thing for their MINI customers!
A link to all the parts being replaced:
http://www.realoem.com/bmw/showparts...24&hg=11&fg=25
Thanks for the update. I guess that means if they're still tuning the fix that new models currently being built are still possibly affected by this glitch.
MINI's direction to replace so many parts seem like a shot gun to me. I guess with some 07 cars now slipping timing chains and needing major work or engine replacment the stakes have gotten higher to get this right. Here's hoping that it'll be just around the corner.
Old Mar 31, 2009 | 06:48 AM
  #977
DaveJ50's Avatar
DaveJ50
It covers any '07-'09 MINI with the turbo engine. And, yes, the dealer must be shown the problem exists in your car. That may change ...
I'm waiting for that to happen since my dealer is 3 hours away. Mine is as bad as any when it happens but has almost quit since the weather warmed a little and I started parking nose uphill.
I wouldn't lie about the chatter just to get a new timing chain to replace my perfectly good timing chain.
Old Mar 31, 2009 | 06:56 AM
  #978
ladhartley
What do you guys think the chances are that this latest fix will finally solve the problem? Any informed guesses will be welcomed.
Old Mar 31, 2009 | 08:34 AM
  #979
taskmaxter's Avatar
taskmaxter
So far it appears to have worked for the folks who have received this version over on the Mini2.com forum.
Old Mar 31, 2009 | 09:19 AM
  #980
tjtull's Avatar
tjtull
Any chance that they'll do a recall? If it's a design flaw, it's going to affect everyone sooner or later, right?
Old Mar 31, 2009 | 09:47 AM
  #981
MINIspud's Avatar
MINIspud
should i still assume that you have to PROVE to them that the car rattles before they replace all the parts you listed above?
Old Mar 31, 2009 | 11:29 AM
  #982
Minidrivr's Avatar
Minidrivr
That would be nice. That's what I'm waiting for. They'll recall the tailpipes for no reason but not a design flaw. Probably because the damage caused is internal and not visible.
Old Mar 31, 2009 | 11:41 AM
  #983
tjtull's Avatar
tjtull
Stick your leg in the engine compartment and burn your calf, they'll recall it then
Old Apr 3, 2009 | 05:11 AM
  #984
lawnboy's Avatar
lawnboy
So is the new tensioner part now being put into the engine for new production MINIs?
Old Apr 3, 2009 | 05:37 AM
  #985
sequence's Avatar
sequence
yes, all builds starting March 09.
Old Apr 9, 2009 | 04:36 PM
  #986
lawnboy's Avatar
lawnboy
If you go to the dealership, would they be able to pull up by your VIN or something whether a particular vehicle has the new tensioner part?
Old Apr 9, 2009 | 09:13 PM
  #987
oldMGguy's Avatar
oldMGguy
It may take a bit of digging by the service advisor, but yes. Bear in mind, the engine's assembly date will be earlier than your car's assembly date. There will be absolutely no doubt in your mind if you've got a defective timing chain tensioner - think of a bicycle chain being rapidly pulled across a metal pipe. Even folks with zero mechanical aptitude will notice it (like my wife).
Old Apr 10, 2009 | 03:39 PM
  #988
investigator's Avatar
investigator
Originally Posted by MINIdave
In the clip posted above it sounds like valves to me, from the frequency or speed of the tapping, it's much faster than a rod knock or piston slap would be. Do those cars have hydraulic valve lifters? Back in the day, Audi had a lot of problems with this on the 5000 when it first got hydraulic valve lifters. They'd come off the truck sounding like this, and after they'd run a while, all was quiet. There was no known cure at the time, other than to be sure you drove your car everyday!
The poster who mentioned updating the cyl head is on the right track - I'd say...........
I once had an '84 Audi Quattro and at start up the lifters made a lot of noise. I had close to 90K miles on it when I sold it. Never had an engine problem in seven years. My '07 Mini rattles a bit when it's cold (I live in Florida) but soon quiets down. I'm not concerned with it. If it breaks BMW will fix it.
Old Apr 12, 2009 | 05:14 AM
  #989
lawnboy's Avatar
lawnboy
So if my MINI is going into service next week (seems to be a sensor problem with the hatch and it thinks it is open), will MINI address the cold start issue or do you have to wait until it actually occurs with our vehicle?
Old Apr 12, 2009 | 11:28 PM
  #990
swflaboy's Avatar
swflaboy
Originally Posted by taskmaxter
Interesting - I've been able to reproduce this problem on my 2008 Clubman now three times. All three instances of this issue happened when I washed my car (but not due to washing it itself). Here is the sequence that causes it for my Clubman.
1) Started car first thing in morning and backed it out of garage to driveway. Did not give it much of a chance to warm up. No engine clatter at this time.
2) After washing car, started car and pulled into garage to do detail work. Again, did not get much of a chance to warm up and there was no engine clatter.
3) After detailing the car and it has been sitting in the garage for a couple of hours I go to start the car to take it on a drive and this is where the engine clatter will start. The clatter lasts for a couple of miles.............
This is pretty much the same as my experience.
I started searching the forums after having the cold start "diesel rattle" for the third time. I currently have approx 7K miles on my Oct delivery '09 MCS.
Every occurrence has been after I washed/detailed my MINI and moved it about 25 feet from the garage to the driveway.
This past Thursday I:
1. Detailed the interior in the garage (without starting it).
2. Drove it out of the garage into the driveway. Detailed the driver's Side
wheels. (driveway has a slight downward slope. MINI was with nose up.)
3. Started it and drove approx. 50' to turn around and back into the
driveway. Detailed the passenger side wheels. (MINI was nose down.)
I left it there for several hours until I needed to run an errand. When I started it I got the rattle. I let it run for about 30 sec, turned it off and restarted about 2 mins later and no rattle.
I detail my MINI often but I rarely have it nose down when working on it. I am curious if that has anything to do with the rattle. Other than washing, I never have any reason to move it a short distance and shut it off. I guess that is why I have only had this problem on detailing days. I would estimate that I have done this at least 20 times and only had the rattle on 3 occasions.
I am going to try and replicate it tomorrow.
Old Apr 13, 2009 | 08:47 AM
  #991
Sparks's Avatar
Sparks
I just had the timing chain tensioner service done on Friday.
My SA was well aware of the issues as the dealers were receiving the service bulletins about it.
Basically what he told me was that they measure the timing chain and if the chain is good, they just replace timing chain tensioner as they did with mine.
Fact or fiction who knows but it did seem to stop the chatter which was an everyday occurrence.
Old Apr 13, 2009 | 09:28 AM
  #992
sequence's Avatar
sequence
it came back this AM, but not as near as loud nor as long as the first time about 1500 miles ago. Still, it sounded like a diesel warming up. Temp 30 degrees, car sat unused and unstarted over 24 hours.
One thing tho: on sat, after washing and detailing I started the car (it'd cooled down after 3 hours) pulled it out, and reparked it, shut it off. But this time I backed in, where the car's nose sat lower than usual, in a little depression on the passenger side. Did not do the rev 3K-shut down procedure.... a much more subdued wham wham wham for about a minute. Once the motor heated up, gone. Logged as such and reported it to my SA.
It has to be something to do with the oil-on-demand delivery system and the valve lash adjusters in general.
Im not freaking out -- yet.
Old Apr 14, 2009 | 03:26 AM
  #993
rippymcs's Avatar
rippymcs
I haven't been able to replicate the rattle in my car, so if you don't mind, I'd like to ask you a favor. The last time I had the rattle, I shut off the engine almost immediately, waited about 30 sec before restarting it. When I restarted it, there wasn't any noise whatsoever. Could you try my method and let us know how it turns out?
Old Apr 14, 2009 | 05:27 AM
  #994
Tu13es's Avatar
Tu13es
Has anyone else had the service done? I'm considering contacting my SA and having it done.
Old Apr 14, 2009 | 06:42 AM
  #995
MINIspud's Avatar
MINIspud
I will next week.
Old Apr 14, 2009 | 07:24 AM
  #996
Sparks's Avatar
Sparks
Just give them a call and have it done. Mine was going in anyways since I needed a few things done.
Been 4 days and no noise... time will tell.
Old Apr 14, 2009 | 09:15 AM
  #997
swflaboy's Avatar
swflaboy
Will do. Did not have a chance to try this yesterday. Will try later after the T-storms have passed.
Old Apr 14, 2009 | 10:54 AM
  #998
sequence's Avatar
sequence
MiniDave, yes these cars have hydraulic (valve) lash adjusters.
Old Apr 14, 2009 | 04:48 PM
  #999
sbutler20's Avatar
sbutler20
New tensioner
Mine is being replaced next week. Took it in for the rough idle/cold start. I had to leave it over night for them to identify since it was getting pretty bad.
We'll see. Also had my dash rattles worked on for the 5th time.
At least they'll give me a loaner car for the tensioner fix, say it will take about 1.5 days...so hopefully they are doing more than just the tensioner.
Old Apr 15, 2009 | 12:21 PM
  #1000
torobud's Avatar
torobud
I got my car back from the dealer yesterday after having the newest tensior parts installed...
The car then proceeded to rattle right there in the dealers lot - I showed the SA but he was unsure of what they could do being that they just replaced the parts
<--- Beating head against the wall
