Dead window, no warning
Old Feb 19, 2008 | 10:15 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
My passenger window is no longer going down when I tell it to. I checked the fuses and they seem fine. If the wiper motor has dies, what kind of money would I be up for to have it replaced out of warranty, and is it something I could do myself?
Old Feb 19, 2008 | 10:31 AM
healey67's Avatar
healey67
The motor is something like 80 bucks I think depending on who you get it from. As for replacing it, If you don't know what your doing. You can actually make it worse!! Find someone who knows what they are doing. Not that hard if you have the tools and know what you're doing.
Old Feb 19, 2008 | 02:17 PM
errolandmel's Avatar
errolandmel
give your door a wrap with you fist just above the speaker then try your window again, the brushes on the motor can get a little dirty
Old Feb 19, 2008 | 08:37 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Hit the door panel between the speakers while holding the switch. Most of the time that will make them work.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Feb 19, 2008 | 09:15 PM
Tomcatta's Avatar
Tomcatta
Looking at nearly (gulp) $400 to have dealer replace out of warranty...
Old Feb 19, 2008 | 10:00 PM
daflake's Avatar
daflake
Yep, whack that bad boy just above the speaker. Those motors are prone to a flat spot that does this.
Old Feb 20, 2008 | 09:58 AM
Agro's Avatar
Agro
I pounded on it pretty hard all around the speaker area and no joy. Desert quoted me $440 for the fix. I guess it's time to dust off that extended warranty.
Old Mar 21, 2008 | 10:05 AM
ingsoc's Avatar
ingsoc
+1 for the good thump. Worked on mine. Now if only my motor will behave and never do this again .
Old Mar 21, 2008 | 03:28 PM
Agro's Avatar
Agro
I wound up getting it replaced on the extended warranty. Had a bunch of other stuff covered as well (motor mount, front control arms...) with the warranty company coughing up over $1700 total.
Old Mar 25, 2008 | 01:51 PM
LUCK219's Avatar
LUCK219
Wow, wasn't looking for this tid bit of info, but if my window ever dies - now i know what to do! =D
Old Mar 27, 2008 | 10:23 AM
hardtail15's Avatar
hardtail15
just had to punch mine the other day, been workin like a charm since
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
jennster
Sep 28, 2015 06:19 PM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
