Tire pressure light
Old Dec 26, 2007 | 09:17 AM
Kennedy's Avatar
Kennedy
Tire pressure light
About a week ago I was driving along and the low tire pressure light started flashing. I had a low tire. So, I reset the system while driving.
The next morning, I inflated the low tire. I forgot to reset the tire pressure system, so the warning light started flashing again. No biggie. I attempted to reset the system while driving. I have done this a few times before. The light stopped flashing.
Now, the low tire pressure light just stays on. I have tried resetting the system several times using the button under the e-brake. According the the manual, this indicates a fault in the system.
Is there any I can reset the light? Disconnect the battery?
Is there any way I can check for the fault?
2003 MC, no DSC, waaaaay out of warranty.
Old Dec 26, 2007 | 10:20 AM
Kennedy's Avatar
Kennedy
I just called the local BMW dealer, they won't even look at my Mini. If I can't fix this myself, time for a long road trip to the dealer :(
Old Jan 3, 2008 | 01:17 PM
RCorney17's Avatar
RCorney17
I just started a new thread not having done a search first. I had the same problem on nearly the same day. My light hasn't come back on though after having pushed the button too. My dealer is a trek away too.
Old Jan 5, 2008 | 10:43 AM
NikiMae31's Avatar
NikiMae31
I had that problem with my 02 Mini, but the ABS light came on as well. The tire pressure was a little off, and my brakes needed work. How do your brakes look? You may need some work on those, and it was just a coincidence that your tire was low. I took it to a local garage (as the closest dealer is 2.5 hours away) and they fixed my brakes and reset the lights on their computer.
Old Jan 7, 2008 | 05:53 AM
Kennedy's Avatar
Kennedy
Brakes are newer. I replaced them earlier this year.
theblackfalcon
Oct 11, 2015 09:49 AM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
