Leaking oil
Old Nov 5, 2007 | 08:46 PM
snowmassmini's Avatar
snowmassmini
Leaking oil
Hey all. My uncle just got a mini cooper s not shore what year between 02-06. anyways we noticed it had a oil leak it was comming from the passenger side form this little silver canister that looked to have a motor mount on the top. Is this the oil filter? Just had the oil changed(not shore who), could they have caused the leak. Any remideys for this soultion? We are miles away form the nearest dealer.
Thanks for you time.
kirk
Old Nov 5, 2007 | 09:06 PM
gnatster's Avatar
gnatster
That is a motor mount, very common issue. Only fix is to replace. Check with dealer to see if they will do it under warranty. Check the build date and mileage to see if even close to being covered. Some dealer may change it under a goodwill warranty since it is a known issue but that is at their discretion.
Old Nov 5, 2007 | 09:54 PM
daflake's Avatar
daflake
Just to add to Gnasters good post, you have an 04 - 06 model as that is a facelift motormount.
Old Nov 6, 2007 | 08:23 PM
snowmassmini
thanks for the replys guys
Old Nov 19, 2007 | 10:14 AM
MJM1959's Avatar
MJM1959
I have the same problem. Is the motor mount what is leaking oil? And why?
Old Nov 19, 2007 | 10:23 AM
Deviant's Avatar
Deviant
Yes, the mount is filled with fluid to help absorb vibrations and it's a poor design that seems to leak prematurely.
Old Nov 19, 2007 | 10:25 AM
MJM1959's Avatar
MJM1959
Thanks! It is off to the shop for me on Wednesday.
Old Nov 19, 2007 | 12:25 PM
daflake's Avatar
daflake
I'll be replacing mine this weekend.
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
