Clutch Fork
Old Jun 18, 2007 | 01:33 PM
AliceCooperWA's Avatar
AliceCooperWA
Clutch Fork
My clutch had been making a rubbing noise and feeling like rubber on rubber for a while. Slowly the engagement point started getting closer and closer to the floor. One day, the clutch would not disengage. It would only half way disengage causing the car to creep with the clutch all the way down...and obviously would not go into gear. After dropping the tranny, I found that the release bearing had separated from the pressure plate. The center of the pressure plate that connects to the release bearing was sheared away on half of it. Upon inspecting it, the fork that operates the clutch is bent on one side. I think this caused inconsistent pressure on different sides of the bearing causing the rubbing sound and feeling. I think it is also what caused the bearing to separate.
Now, I need help. I refuse to replace the transmission because of a bent fork! The dealerships say that they do not sell that part separately on the midlands trannys, only on the getrags...
Does anyone know where the hell I can find this part? I know there are a LOT of damaged midlands trannys out there, since they all seem to break sooner or later. I just need the fork and shaft that operates the clutch.
I'll post pictures tomorrow if I can.
Old Jun 20, 2007 | 07:26 PM
002's Avatar
002
Are you sure about the bearing, it is connected to the arm, not the plate. It sounds like a slave cylinder to me, but I have not seen what you have.
Old Jun 21, 2007 | 07:09 AM
AliceCooperWA
It is definately not the slave cylinder. I changed it already thinking it was that. I did not take the clutch apart myself, so I did not see how it was assembled. The bearing was separated and the center of the pressure plate was sheared off. Regardless, the bearing separated from where it is supposed to be, the forks are bent, and the center of the pressure plate is half sheared off. I do know that the bearing goes along the shaft which goes through the hole in the pressure plate. That is where the damage was. I'll post pictures if I can.
Old Jun 21, 2007 | 08:16 AM
chadtoolio's Avatar
chadtoolio
THe part# for the clutch fork/lever is 23 11 7 515 838. It lists for $98.91. There are 2 available in the US.
HTH,
Chad
Old Jun 21, 2007 | 10:12 AM
cristo's Avatar
cristo
Alliance Member
Looks like cheaper at Pelican Parts, if they can get one.
OEM-23117515838
LEVER - This is a special-order, non-returnable, part (availability and shipping charges may vary)
$47.10
Old Jun 21, 2007 | 10:48 AM
AliceCooperWA
hmmm. thanks!
I'm pretty sure that the dealership parts guy was lying to me. The part is connected to the bell housing right?
Old Jun 21, 2007 | 11:18 AM
chadtoolio's Avatar
chadtoolio
Yes, connects to the bellhousing and fits through it vertically to with the lever forks and bushings on each end...
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
