Car won't move... clutch issue?
Old May 11, 2007 | 03:33 AM
saxman's Avatar
saxman
So I was just out with the gf driving around(teaching her to drive a manual) in her 02 MC. Pulled up to a stop sign, put it into first, and it wouldn't go anywhere. She had been driving for a while, but is doing pretty well with the clutch, and there was no smell of a burnt clutch. Let it sit for a couple hours, came back, and still no go(in case it was an overheated clutch). Peddle feels the same, engine runs the same, shifts into gears the same. If I put it in first with the motor turned off, I can push the car. Seems the clutch is stuck in the disengaged position. Any ideas before I call and have it towed tomorrow?
Old May 11, 2007 | 04:52 AM
03BRG's Avatar
03BRG
So if you put it into 5th can you still push it? If so input shaft in the tranny or even a broken half shaft, That is if you think the peddle feel is the same on the clutch. Do you think the clutch had been slipping before? I would think it would at least feel like it wanted to go if it was just a bad clutch plate given a level road.
Old May 11, 2007 | 09:58 AM
saxman's Avatar
saxman
Just tried pushing it in 5th, and I can still push it.
The peddle feel is identical to how it was when it was working. The clutch always felt fine, no slipping.
If I put it in first, I can let the clutch complete out, and it runs as if in neutral. If I give it some gas, the car will try to roll forward an inch or two, but just barely.
Happy 3rd day of ownership to us :(
Old May 11, 2007 | 12:40 PM
saxman's Avatar
saxman
well just got back from the stealership... they seem to think it's the clutch, and quoted us at $2700 to repair it.
Old May 11, 2007 | 01:06 PM
03BRG's Avatar
03BRG
Bummer- time to give back if its only been 3 days
Old May 11, 2007 | 01:11 PM
saxman's Avatar
saxman
car was purchased used from a dealer... I was under the impression there's no buyback policy
Old May 11, 2007 | 01:13 PM
Loony2N's Avatar
Loony2N
Don't know what State you go it in, but did it have an "as-is" notice on it? In any case, the dealer is required to disclose known defects. Of course, the question is, how would you know if the dealer knew?
Old May 11, 2007 | 01:14 PM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
There might be a 30-day/3,000 mile limited warranty...do you still have all the paperwork, including the window sheet?
Old May 11, 2007 | 01:27 PM
saxman's Avatar
saxman
we have a 3 year-36,000 mile warranty, but as the clutch is a wear item, it doesn't cover it
AZMCS's Avatar
AZMCS
take it elsewhere. should be at $1000-$1400 job total. You gettin' raped.
Old May 11, 2007 | 01:34 PM
saxman's Avatar
saxman
Originally Posted by AZMCS
take it elsewhere. should be at $100-$1400 job total. You gettin' raped.
I called another place local and was quoted $1230, waiting to hear back from a few other places...
regardless, it really sucks that my 3 day old car, which a warranty tacked on to the price, is in the shop for $1000+ already.
Old May 11, 2007 | 03:09 PM
Loony2N's Avatar
Loony2N
That's true, sax, but it's probably why the original owner got rid of it. After the repair, it should be good to go (I hope).
Old May 11, 2007 | 04:08 PM
saxman's Avatar
saxman
quite frustrating as the car was inspected and all came out clear
the clutch went in such a weird way...
came down a long hill, pulled up to a stop sign, pulled away fine. Hit the next stop sign, and nothing. No smell of burnt clutch, etc. I really wish that the tranny had grenaded itself or something... would make me feel a lot better.
The mini dealer said that the way it went wouldn't really give any warning signs, so there's a chance the stealership we bought it from didn't intentionally burn us, but damn it, I want to blame someone.
Old May 11, 2007 | 05:09 PM
SNEEEZY - Erika
Rattle Can Queen!!!
"Who" inspected it? Who paid for the inspection? What kind of guarantee comes with the inspection?
Old May 11, 2007 | 05:40 PM
saxman's Avatar
saxman
It was inspected by the dealer that we purchased it from(I have the documents to show it was done, so not just taking them at their word). My stupid mistake for not having a third party inspect it at my cost. There was no guarantee of any sorts. From the sounds of it, it wouldn't have shown up anyway.
Old May 15, 2007 | 05:50 PM
saxman's Avatar
saxman
Well, after playing a lot of phone tag, I've finally got some resolution. The dealer I purchased it from said if I tow it down to them, they'll replace the clutch free of charge. Means an expensive tow job, but certainly beats the alternative.
So thumbs up to Mini of SF where the car has been sitting since friday morning and hopefully thumbs up to Steven's Creek BMW for at least backing up what they sold in the first place.
Old May 15, 2007 | 06:55 PM
Grassroots Garage's Avatar
Grassroots Garage
If the clutch pedal feels "normal", then the it most likely a broken shaft in the transmission, I have replaced literally dozens of the early Midlands 5 speeds because of this. A clutch does not just "go", it wears and gets worse gradually. There may not have been anything that even a well qualified inspection would have uncovered, so you can't really blame the inspector, however, I hope there is a drivetrain warranty that will cover it, but it is not the clutch.
It sounds like you are dealing with people unfamiliar with MINI's and their early problems. I suggest looking elsewhere for someone who knows what they are doing.
--Dan
Old May 15, 2007 | 07:41 PM
002's Avatar
002
It kinda sounds like the shift cable popped out, especially if there wasn't any obvious npise or smell when it happened.
Old May 15, 2007 | 08:35 PM
Fassbinder's Avatar
Fassbinder
have them make sure that the output flange has not popped out of the differential section of the transmission (happened to my sister)
Old May 15, 2007 | 09:12 PM
saxman's Avatar
saxman
--Dan
I have a warranty that will cover pretty much everything else, just not the wear items, so the clutch was exempt.
Old May 16, 2007 | 07:12 PM
Grassroots Garage
Really, have them get a better look at it. They will find that it is the tranny and not the clutch, and fix it for you.
Is this a MINI dealer you bought the car from? If you have an aftermarket warranty from a used car dealer, you may want to call the nearest dealer and ask if they will accept it. This is a cut and dry situation, you just need to find the people to deal with.
--Dan
Old May 16, 2007 | 11:33 PM
saxman's Avatar
saxman
I purchased the car from Steven's Creek BMW with an aftermarket warranty. When the car died on me, I had it towed up to Mini of SF. They're the ones that told me it was a clutch that needed replace. The warranty I have will cover any tranny related issues, but not wear items like the clutch. If, when they open it up, it's the tranny and not the clutch, it's covered by the warranty, etc, so I'm not too worried about it at this point.
After talking to Stevens Creek many times over the past week, they told me that they'd replace the clutch free of charge if I towed it back down to them, which I did today. I'm waiting until they actually open it up to hear what the real issue is. It certainly seems off to be a clutch going out.
Old May 17, 2007 | 02:54 PM
SRICHS's Avatar
SRICHS
Call the guys at Custom MINI shop in Fresno, CA. They know their sh*t. Sounds like the transmission went kaboom, but wouldn't know until the clutch is pulled from the transmission housing.
Old May 17, 2007 | 10:24 PM
saxman's Avatar
saxman
Fresno is way too far for me to take the car. At this point I'm just waiting to hear the results of them taking the car apart.
Old May 18, 2007 | 12:20 AM
daflake's Avatar
daflake
I agree with Dan on this. If you can still change gears and the car just revs and nothig else, it sounds like the tranny that died and not the clutch. There is a difference!
If it is the tranny, then it should be convered under warranty.
