Solo JCW now in STU
No, JCW is a Dealer installed option package. Very specific parts installed with a warrantee from MINI. It is essentially a separate model car.
While you can approximately recreate the package, with other parts, it is not legal. The classing decision says "JCW" that is all that is legal in either ASP or STU.
You can't take a WRX and drop in a 2.5 turbo and run it is STU, same with a pulleyed S.
If you want to be able to do that, write a letter to SEB@scca.org
What is UP with THAT. The man Motoring is just trying to be helpful and fully answer your question.
If you want a personal on the phone explanation, calll the SCCA in Topeka (use their 800 number ( www.scca.org ) so it will not be on your nickel) ask for the Solo 2 Technical Department. They are every bit as helpful as Motoring...but on the phone.....don't worry if you're not a member....they don't quiz ya.....
Originally Posted by Craig_N
Will the 05's with LSD be legal for STU? The rules state that "No limited slip differentials except factory viscous coupler type units". Does the MINI's LSD fit into that?
I have an 04 MC and I run in FSP. not very competyitive in Minneapolis. i was the only one. But, I moved back to Mihcigan and Idk yet. BTW the mods I have are as listed: Cold Air Intake, Magnecor Race Wires and NGK Plugs, Miltek Header and Helix13 Catback. Don't forget the Schroth Harnesses and H-Sport 22mm rear sway bar.
08-19-2015 12:51 PM
08-12-2015 01:24 PM
