WTB:: Joey Mod RH ‘05-‘08 Headlight
Category: Lights
Price: $259
Location (Region): Texas
Looking for a Joey Mod RH post-facelift headlight in VG- Excellent condition.
Alternatively, will buy a pair at $500
if none can be sourced in 3 months, I will sell my LH unit which is in excellent condition, and the RH unit which has broken internals for $400, plus shipping.
Did you see these: https://www.northamericanmotoring.co...eadlights.html
Joey Mod
Thank you for the tip. I would like to stay with OE headlights, including headlight washers. The Joey Mod lights look awesome on my triple-black '05 R53, except that the internals of one of them is busted (don't know how.)
Welcome, understand. Whats busted about it, do you have a pic?
I don't have pictures but the tabs attaching the lower rings and bulb holder to the main light body are broken, and the sub-assembly is dangling inside. I disassembled the headlight but could not remove and repair the sub-assembly. It can be a good spare for someone.
Oh ok, yes i know what you mean, there is a pivot ball joint also in there that can pop out or break, you could bake it and take it apart and gorilla glue it.
Bump
Possible fix
Bachman,
not sure if this will be helpful to you, but I had an own xenon assembly that I bought, where the bulb was facing down and was loose.
i fished some string around the front of the bulb inside the housing. I did not remove the lens. So the loop of string went in from the back and also came out the back. I then yanked up on the string to pull the assembly back on the ball socket post. I then pulled out the sting.
maybe this is helpful or maybe it is not. I either case, best of luck to you.
Cruiser77,
Thank you for the great innovation and advice. Unfortunately in my case, the plate with 4 screws that attaches the bulb housing to the frame is broken in two places and cannot be secured. Probably cracked/broken during the initial Joey Mod procedure.
I appreciate your considerate suggestion.
Bahman
Bahman
Interior/Exterior Joey Mod 03' Xenon Headlight Help!
GumbyLara
Mar 2, 2011 08:04 PM
Interior/Exterior Half Joey Mod On PW/B Mini (just headlight rings)
futureal33
Oct 21, 2008 10:29 PM
Interior/Exterior Painting Headlight Housing (aka Joey Mod)
chikmagnet
Jan 6, 2008 07:17 PM
