FS:: RECARO Focus RS Seats
Old 06-15-2019, 08:10 AM
mcaanda's Avatar
mcaanda
mcaanda is offline
Arrow Sold
Category: Interior
Price: $1100
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, F55, F56, Classic Mini
Location (Region): West
Old 06-15-2019, 08:12 AM
scubus's Avatar
scubus
scubus is offline
I am curious, how do these mount in a R53? Is this a typical install?
mcaanda's Avatar
mcaanda
mcaanda is offline
You'd have to modify the brackets to mount.
Old 06-15-2019, 08:15 AM
scubus's Avatar
scubus
scubus is offline
Other than that, is it a plug and play installation or would I have to fiddle with the airbags? I was considering reupholstering my seats or simply replacing them with something more "sporty." I saw Carbeaus today and liked them, but this would be an interesting option of the airbags function.
Old 06-15-2019, 08:16 AM
mcaanda's Avatar
mcaanda
mcaanda is offline
I'd assume that you'd have to look into the wiring of the seats OEM airbags as well as the ones w/ the Mini to see about getting them to be compatible. That was what I'd planned to do.
Old 06-15-2019, 08:47 AM
scubus's Avatar
scubus
scubus is offline
Okay, a little research is in order before I move forward
Old 06-16-2019, 04:01 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
Just a heads up for F56 owners, OMP is the only aftermarket seat company to make brackets for our Mini's
I had to have my brackets custom welded and fabricated to fit the Sparco brackets
Old 06-26-2019, 08:20 PM
mcaanda's Avatar
mcaanda
mcaanda is offline
Additional Pics added.
Old 06-26-2019, 08:31 PM
Sokol's Avatar
Sokol
Sokol is offline
Keep me posted if this works or if its doable, i have two pairs of RS seats and St seats ..... didnt think these would fit the mini.
No sure on the mini side if they have a OPDS ocupant detection sensor under the passenger seat, if they do there is no way to bypass the system as the focus uses a different Gell filled tube with a pad sensor. If Mini has just the seat airbags those are easy splice and dice or put a 2 ohm resister to bypass the system. Need to flip the passenger seat on teh mini and see if there are modules. On the older pre 2013 i think it would be easier to install, but on the 13 and higher the mini would have more sophisticated system. Unless like the focus guys did with the euro speck recaros they would strip the opds system and hide it under the seat to have their airbag light off. However Mini has tons more coding for the airbag system so i would assume you could code the seat airbags and opds out of the equation all together.
Let me know if its doable...
Old 06-26-2019, 08:38 PM
mcaanda's Avatar
mcaanda
mcaanda is offline
I'd not done it but was going to. Ended up selling the car so no way to check at this point.
Old 07-09-2019, 02:35 PM
minihooligan773's Avatar
minihooligan773
minihooligan773 is offline
Could you measure from bottom to top of seat need the height of them. Could use in my 72 mini
Old 07-10-2019, 08:06 PM
mcaanda's Avatar
mcaanda
mcaanda is offline
MiniH -
Edit - you do not have an E-mail listed on your profile. Can you please E-mail me? The PM system here sucks and I cant keep track of anything when replying.
Thanks -
Old 09-01-2019, 04:18 PM
Mereco's Avatar
Mereco
Mereco is offline
I installed the driver side on my R53 much better than stock
OSilvera (09-04-2019)
Old 07-25-2020, 04:54 AM
pauloft's Avatar
pauloft
pauloft is offline
Hi! Is the a chance you could teach me how you do it ?? Step by step
I installed the driver side on my R53 much better than stock [/[QUOTE
hi can you teach me how you do did it step by step ? My e mail is pauloft@gmail.com
And Im considering to buy a recaro seats set. Thanks for the help !
ninjamini
04-05-2012 11:22 AM
peteyd4
09-07-2010 08:58 PM
moji2006
23
05-21-2008 08:59 PM
condor27596
05-21-2008 06:48 PM
Mini Works
04-05-2006 05:29 PM
Quick Reply: FS:: RECARO Focus RS Seats
