strange window problem intermediate
Old Jan 30, 2018 | 06:48 PM
Ken Garchow's Avatar
Ken Garchow
am wanting fix the passenger side window in my 2005 R52
before tearing into it i want to confirm that i am on the right track and have needed parts as need to be ordered
the passenger side front window some times wont go back up tight after the door closes
it drops down slightly when the door opens but stays down when closed
have to wiggle the switch to get it back up
my current plan is to replace the motor or clean it up as i have read they suffer from getting gummed up
does this sound like a reasonable way to proceed?
thanks
Old Jan 31, 2018 | 07:00 AM
Need ECS to chime in here as hes the Vert goto guy.,
Old Jan 31, 2018 | 07:14 AM
Thanks for the heads up.
If its does not move up at all when the door closes then its the motor being sluggish or the point need reset again. Try the reset, if it still does not work, then its the motor.
In 6/2005 there was a part # split, so get the production date off your door jam sticker.
https://www.northamericanmotoring.co...regulator.html
Resetting post #12
https://www.northamericanmotoring.co...-problems.html
Old Jan 31, 2018 | 07:34 AM
nkfry's Avatar
nkfry
Vendor - Detroit Tuned 15 Years
This can also lead back to a door lock actuator issue, if the latch doesn't detect that the door has closed it won't trigger the window to return to it's proper location after the dip.
If the window works normally in all other aspects of life I wouldn't go right to the motor as the issue.
https://www.northamericanmotoring.com/forums/signaturepics/sigpic151635_2.gif
MINI Specialists * Parts * Performance * Service
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 31, 2018 | 08:36 AM
Ken Garchow
thanks for input
plot thickens
production date is 6/05, so is it of the first or second design
and i was told at dealer since intermittent not reset and also intermittent with switch
so is does that make motor most likely?
and which motor get?
thanks
Old Jan 31, 2018 | 10:18 AM
Welcome.
I would check the wire plug on the harness to the motor first, but my guess is the motor internally is making contact, then not.
Its always from production date when it falls on that date. So the 6/05+ is what you need. So, MINI part # 67626954276 which is linked to first link in post #3.
Old Jan 31, 2018 | 10:21 PM
Ken Garchow
update
took pass door card off and removed motor and cleaned
reinstalled and reset
working better, switch moves window up and down fine
but once in awhile window goes down small amount when opening door but doesn't go all the way back up like before
if open door again and close it goes down a little bit again but not up, so if keep opening and closing you could say it ratchets down
can put-up with switch, any ideas? its a little annoying cause if i don't check it can accidentally leave car with window slightly open and then interior gets wet
thanks
Old Feb 1, 2018 | 01:38 PM
My guess is the connection is better but it still has internal contact problems on the internal brushes via the window motor. I would test out with a new motor. Or if you have a spare one.
Old Feb 2, 2018 | 07:09 PM
Ken Garchow
ECST thanks
i did take the motor apart and clean commutator and polish with emory cloth
also cleaned brushes and lubed end bearing
i did this with out taking regulator out just removed motor from drive mechanism by reaching up
through the lower speaker hole
lizandrooo
Cooper (non S)
Jan 23, 2014 05:38 PM
kerrys914
R60/61 Cooper S Drivetrain
Jan 9, 2013 07:58 PM
donjulio
Aug 9, 2011 05:04 PM
glangford
Sep 10, 2007 10:24 AM
Yucca Patrol
19
Mar 22, 2005 11:05 PM
