D Stock Front toe-out?
Old Feb 14, 2006 | 06:29 AM
TomA's Avatar
TomA
Front toe-out?
How much toe-out on the front do you think is too much? Also, being mathematically challenged (I still count on my fingers), how many degrees (.10) equals how many inches (1/16)?
TomA
Old Feb 14, 2006 | 07:27 AM
cristo's Avatar
cristo
Alliance Member
1/16" toe out is about .075 degrees each tire (.15 degree total).
degrees toe = inverse sin(toe out in inches/tire diameter in inches)
Old Feb 14, 2006 | 07:47 AM
GRMPer's Avatar
GRMPer
We set ours at .15 total toe out in the front and .04 toe out rear (with as little neg camber as possible)
Per
Old Feb 14, 2006 | 07:57 AM
TomA's Avatar
TomA
Per,
Is that total toe or per side?
I had mine checked last week and RF was -.22 and LF-.19; total toe -.41!!
TomA
Old Feb 14, 2006 | 08:13 AM
TomA's Avatar
TomA
Per
Whoops. I should have read your post with my eye-glasses on. That last post (question) was the blind me.
Old Feb 14, 2006 | 08:15 AM
nygaard's Avatar
nygaard
Or if using the longacre toe plates: degrees toe = inverse sin(toe out in inches/~21.5)
Old Feb 14, 2006 | 11:11 AM
GRMPer's Avatar
GRMPer
I typically don't run a lot of toe on the front and with so little rear camber, I don't need that much in the rear to make the car rotate.
See you in Ft. Myers.
Old Feb 16, 2006 | 02:38 PM
minifinn's Avatar
minifinn
Per,
Nice write up in the new GRM on the MINI set up. I found about the same settings after about 2 1/2 seasons screwing with it. I then added camber plates and started over. Funny thing is, I ended up back to the same settings again. Go figure. My MINI just likes them, I guess.
Good Luck this season. I'll see you if you come through Peru. I'm one of the slower STX guys, but having fun anyway.
...Mark
Old Jun 19, 2006 | 06:33 PM
Hammer's Avatar
Hammer
Stupid question - I run a 17" wheel on the street, but I AX with 16's. If I were to get the alignment with my 17's on, would it change the settings when I run the 16's?
Old Dec 18, 2006 | 09:45 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
No, your toe settings will be the same no matter which wheel you use.
Old Dec 19, 2006 | 03:49 AM
GRMPer's Avatar
GRMPer
As long as the diameter of the tire is approximately the same...
Old Dec 19, 2006 | 09:47 AM
minihune's Avatar
minihune
As the diameter of the tire changes what happens?
Say I have two wheels-
One for street use 17x7 with 215/45-17 outer tire diameter 24.6"
and one for autocross
15x7" rim 205/50-15 tire with outer tire diameter 22.9"
If I align with 15" wheel on then that is fine for autocross but what happens to the alignment when I change to street tires?
Or what if I align with the 17" wheels on then go to autocross and run the 15" wheels? What happens to alignment in the reverse?
Anyone have trouble with 1/8" toe out instead of 1/16" out?
Old Dec 19, 2006 | 03:17 PM
georgetd's Avatar
georgetd
oh, that's just a math porblem, I can usually do those
if you set the toe to 1/16" out with the 15" wheels on, then the toe out with the 17" wheels on would be about 1/15" out, just ever so slightly larger (less than 1/64" different). you can do this yourself for various wheel outer diameters
new toe =~ old toe (new wheel diameter / old wheel diameter)
=~ 1/16 * (24.6 / 22.9) in this specific case.
this is simplified for small angles, but who wants more than 5 degrees of toe?
basically, if your wheel diameters change by 5%, your toes settings will change by 5%.
Old Dec 20, 2006 | 10:03 PM
minihune's Avatar
minihune
OK, but does camber change relative to wheel size?
Old Dec 21, 2006 | 03:50 AM
cristo's Avatar
cristo
Alliance Member
No
Mini7
Feb 2, 2016 07:52 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
