D Stock GS class
Old Aug 25, 2005 | 11:53 AM
qweewq12's Avatar
qweewq12
GS class
Just to get this right...as I am about to order magnetic numbers for my car...
A Stock MCS with absolutely no mods is GS class...???
Thanks!
Old Aug 25, 2005 | 12:38 PM
petecrosby's Avatar
petecrosby
Correct.
Old Aug 26, 2005 | 04:58 AM
BGarfield's Avatar
BGarfield
If you're going to spend any significant money, I'd hang on. There is a possibility of the car going to D Stock next year. I'm not sure I'd spend money on letters right now.
Especially since the letters are supposed to be smaller, print them out on a computer and cut them out of magnetic material or something, so you don't spend but a few pennies...
Brian
Old Aug 27, 2005 | 09:48 AM
qweewq12's Avatar
qweewq12
good idea....
or if I did get them, I could just get a little sheet of white and slap a D on it from the same company...
ACtually, I just want a piece of grey magentic with some black so I can do the numbers and class... nothing fancy
Old Aug 27, 2005 | 10:17 AM
qweewq12's Avatar
qweewq12
I read where any mods after the cat are allowed, by a change in air intake is not...
I was thinking about getting this seat belt lock..
http://mossmini.com/Shop/ViewProduct...35&SortOrder=1
Any other mods, beside the exhaust, that help performance and doesn't kick me out of GS?
Old Aug 27, 2005 | 11:04 AM
Mineon's Avatar
Mineon
Unfortunately not much. You can change the fluids, plugs, wires, coil, and air filter (has to be a drop-in replacement in the stock airbox), but none of those are likely to get you much more than a hp or two.
-Keith
Old Aug 27, 2005 | 11:20 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Because the MCS comes from the factory with 16 or 17 inch wheels you can run either size and be within the rules. You may also use any type tire that fits the rims in G stock and that is an advantage.
Old Aug 27, 2005 | 11:41 AM
Mineon's Avatar
Mineon
Going beyond just modifications to the engine/exhaust, in addition to being able to run different wheels (must be stock size, +/- 1/4" in offset), whateer DOT legal tires will fit, you can change the front sway bar to a bigger or smaller one, and replace the struts. Brake pads are also free to be changed. There are some smaller things as well, but those are most of the main ones.
It's a good idea to read the complete Stock ruleset which can be downloaded at SCCA.com in pdf format.
-Keith
Old Aug 27, 2005 | 11:50 AM
qweewq12's Avatar
qweewq12
Excellent Idea... will do
Old Aug 27, 2005 | 11:58 AM
sndwave's Avatar
sndwave
Look at the sticky at the top of this G Stock forum.
Old Sep 13, 2005 | 05:40 PM
squid2's Avatar
squid2
Pro Solo Finale results
The MINI S did very well in the Pro Solo Finale results, and a good
showing in HS.
PDF: http://www.scca.com/_Filelibrary/File/solo-05finale.pdf
Old Sep 13, 2005 | 08:04 PM
Rich.Wolfson's Avatar
Rich.Wolfson
showing in HS.
Top 8 in G Stock. Yee Ha!
Old Sep 14, 2005 | 04:28 AM
petecrosby's Avatar
petecrosby
Well, to be honest, it looks like the only cars entered in GS were MCSs so
that's no big surprise.
Old Sep 14, 2005 | 04:52 PM
MINI_xs's Avatar
MINI_xs
Not good news. I haven't looked at the specifics of the results, but the top people probably got those scores running the newer LSD model Cooper S. Finishing orders like this will be used as justification by the Solo classification people to place all Cooper S cars (even those like me without limited slip) into D-Stock where everyone else has AWD or LSD, and lots bigger engines. In my estimation, our cars will be disadvantaged big time.
Old Sep 14, 2005 | 06:54 PM
JustGo4It_'s Avatar
JustGo4It_
The 2002-2004 cars will not move in class this year. Only the 2005+ is under review. It is listed under a seperate line in the rule book.
Old Sep 14, 2005 | 08:09 PM
OasisT's Avatar
OasisT
That post got me laughing, the only car entered into the Pro in GS were 05 MCS's with LSD. We got beat by DS by .8 seconds! But, the SEB doesn't even consider pro results anyway. Just so you guys know, at the town hall meeting here in Topeka, they said the 05 IS going to DS next year as well as a possible move of the 02-04 to DS in 07.
Craig Wilcox
Old Sep 15, 2005 | 09:20 PM
JustGo4It_'s Avatar
JustGo4It_
Looking over the results between DS and GS there is a big difference in times. GS has DS by 4.2 seconds. Did the 3rd run group catch rain or was the course wet? I count 26 MINI's in front of top DS time.
Old Sep 16, 2005 | 04:14 AM
BGarfield's Avatar
BGarfield
It was raining during 3rd heat and drying while we ran. So yes, that's why you see that.
Brian
Old Sep 16, 2005 | 05:54 PM
OasisT's Avatar
OasisT
GS results
Chiles
Garfield
Savinni
Burns
Jensen
Wilcox
Nygaard
Pilson (Celica)
another Celica
DS beat Chiles by 1.1-1.2 seconds with identical conditions. Start writing your letters to the SEB now before its too late. Top dirty time for Pilson was within .1-.2 seconds of Chiles and his top clean time was within .3 or so, so, the Celica and Mini are a good match for GS. Also, they are moving the Celica GTS down to GS, which, will be quicker than the GT on some courses.
Old Sep 18, 2005 | 05:34 AM
Mark Hirt's Avatar
Mark Hirt
Originally Posted by OasisT
GS results
Notes: The results will never show if Marks cone was a "nick" of the last slalom cone or a license plate hit. The Celica GTS has no torque, tops out at the same speed in second gear and has a lovely "wheelspin" switch at 6k. On 99% of courses the GT will have it for lunch.
Congrats to the all the drivers at Nationals. I need to learn NOT to spin on my last run of day 1
After spending a week in Kansas I'm off to Ohio for a little relaxation.
Old Sep 18, 2005 | 04:42 PM
OasisT's Avatar
OasisT
If it wasn't drying conditions, it wouldn't have been that big of a deal, but, unfortunately, I know exactly how you feel with my cone on day 1 run 3. :-((
Old Sep 18, 2005 | 05:00 PM
BGarfield's Avatar
BGarfield
IF I was faster, I would've won...
Brian
Old Sep 18, 2005 | 09:25 PM
MattMan's Avatar
MattMan
Coordinator :: Minis Under the Arches (Oct 25-28)
I'm a bit confused....Craig, I think you're going to have to explain what I'm missing. I think in the results I'm looking at, Mark's combined time was around 118 and DS's top time was 122, which would mean that GS beat out DS by almost 4 seconds combined. Could I be looking at the wrong results??
Old Sep 18, 2005 | 09:31 PM
BGarfield's Avatar
BGarfield
Craig is referring to the only thing you CAN compare, Friday's runs. On Thursday, D Stock ran in the driving rain whereas G Stock ran in drying conditions.
In other words, to compare the two classes on any day other than Friday is pointless. Just look at the lower line of times, not the upper or the total.
Brian
Old Sep 18, 2005 | 09:58 PM
OasisT's Avatar
OasisT
Brian
Yep, Thats what I meant. I know at the town hall meeting they said they were going to bump us to DS, but, now that the results have shown that we belong in GS, I'm hoping they stick to their plan of making GS quicker, instead of going back to the old GS with Celica's as the only car to have.
