H Stock Daily Driver/H-Street Build II
Old Nov 1, 2013 | 02:41 PM
  #26
honda93's Avatar
honda93
Originally Posted by kyoo
All of this makes me wonder: how did the person who got documentation for the JCW suspension being legal in stock class get it? This literally falls under the same category
Ask him...
https://www.northamericanmotoring.co...vers-rock.html
Last post in this thread is by a person named Craig Wilcox. His online name is OasisT. Send him a PM.
Old Nov 1, 2013 | 07:14 PM
  #27
Btwyx's Avatar
Btwyx
Any thoughts out there on running a 225/45 vs a 205/50 on a 16x7 wheel for street tires?
Now I've got 225/45-15s (Rivals), I'm thinking of testing them against the current 205/45-16s (RE-11), which have about 1 event left in them, just as a sanity check.
Of course that won't be a test of just 225 vs 205, but it'll be interesting.
I was surprised at how little difference there was between 225 and 205, here's a (bad) picture of them. Particularly as the rival is quite rounded.
Old Nov 1, 2013 | 08:22 PM
  #28
kyoo's Avatar
kyoo
Originally Posted by honda93
Ask him...
haha thanks - i'm pretty sure i've got the documentation i need now, or at least, as much as i could possibly get from MINI. (https://www.northamericanmotoring.co...99-post25.html) If this isn't good enough, I don't know what is... in retrospect, kinda silly all what i had to do to basically prove innocence, but I've got it now. should hold up in a case of (unlikely) protest.
Interesting - yeah I have no doubt both tires will fit. Kinda different also in that the rivals are on 15s, overall diameter is shorter, etc. but definitely still work exploring at least. if enkeis had a 15x6.5, i'd definitely rock that, but 16x7 looks like the more readily available, affordable, and light option for now, unless you have different ideas? cant afford volks..
Old Nov 1, 2013 | 08:31 PM
  #29
kyoo's Avatar
kyoo
11/1/2013 - Clear Bra
This will probably be one of my most invisible mods lol. I had this done for my evo, and liked it a lot. Looks like it'll look just as clear on black as it did on white. Went to a local shop here, and the film they used was XPEL Ultimate. This film has a 10 year warranty that covers parts AND labor, even better than 3M's 5yr parts and labor warranty. According to these guys, its the top clear bra film on the market right now, with great protection and also "heals" its scratches.
Areas done:
- Front bumper, front hood up to 3-5" past the headlight
- Headlights themselves
- Some small door protection
- Rear bumper tailgate area (don't know what it's exactly called)
Also, something interesting I found:
Looks like the car came with some wax covering some of the bolts to prevent corrosion. I actually have sourced this stuff from a friend of mine, and I've used it on a few of my cars just for extra protection in some high risk areas. He said Lexus and Mercedes have been using this stuff, glad to see it's made it onto the MINI as well.
Old Nov 2, 2013 | 01:44 PM
  #30
kyoo's Avatar
kyoo
Anyone know exactly how you're supposed to use this stuff? It looks like they want you to dilute it in water, but the temperature range for antifreeze isn't exactly great.. can I just pour some into the windshield washer reservoir?
Old Nov 4, 2013 | 10:48 AM
  #31
kyoo's Avatar
kyoo
bump for anyone who's used this stuff
Old Nov 4, 2013 | 06:24 PM
  #32
kyoo's Avatar
kyoo
Differences in the sealant between 08 and 13 (forgive the terrible editing out of vins)
'08
'13
Old Nov 5, 2013 | 06:09 PM
  #33
kyoo's Avatar
kyoo
Waiting for the second coat of plastidip to dry!
Old Nov 5, 2013 | 07:01 PM
  #34
Eddie07S's Avatar
Eddie07S
I will just note that the 225s are a tight fit, at least with the Toyos I am running for track tires. I have the 225-45x17 R888s on Enkei 7" wide wheels with a 38 mm offset and they rub on the inside of the rear wheel wells. But, they only have about 3/8 inch clearance on the front strut. So you can't bring them inboard too far as they will then rub on the strut. I am figuring that a wheel with a 42 or 43 mm offset will be about as good as you can do, but it still may rub on the rear wheel well. The 225 Rivels have a little less width according to TireRack so they may fit ok. Just something to watch for.
Old Nov 5, 2013 | 07:57 PM
  #35
kyoo's Avatar
kyoo
keep in mind 225/45-17s are a full inch taller than 225/45-16s (obviously) which is what I'm planning on running. the wheels I'm planning on have an offset of 43mm, so hopefully it will be a perfect fit
Old Nov 5, 2013 | 08:21 PM
  #36
Btwyx's Avatar
Btwyx
Mine are a full 2" shorter, at 225/45-15. I didn't notice any rubbing anywhere. Even with the 40 offset, I can fit my fingers between the tires and the strut.
Old Nov 5, 2013 | 10:12 PM
  #37
kyoo's Avatar
kyoo
good to know. hopefully with jcw springs and shorter dampers the 225/45-16s will still fit.. im sure they will
Old Nov 6, 2013 | 05:50 PM
  #38
kyoo's Avatar
kyoo
can anyone answer for sure whether the jcw front sway bar is 24mm or 24.5mm, and what the part # is for base cooper hardtops?
Old Nov 6, 2013 | 06:58 PM
  #39
Eddie07S's Avatar
Eddie07S
How about 24mm...see the front suspension listing and pick the JCW sport option:
http://www.penskeparts.com/DiagramsM...3&rnd=03192010
The Sport suspension is 23.5; base S is 22.5; base Cooper is 21.5
I think the part numbers listed are the MINI #s, so you can look up what you want.
Old Nov 6, 2013 | 07:11 PM
  #40
kyoo's Avatar
kyoo
ok, that's what i thought - just i've had a few people practically swearing it was 24.5..
Originally Posted by archdukeferdinand
JCW FSB is 24.5mm and it has its own part number.
The holies are just not wide enough since its been shown how street tires don't like being pinched like Hoosiers. I've had some success on the Rivals after nationals but they feel just horrible on the holies. I'm really thinking the extra inch on the 15x6.5s will make a huge difference since its a nearly 20% increase in width. Still, I wouldn't be surprised if a 225 isn't any faster than a 205.
https://www.northamericanmotoring.co...classes-5.html
just want to be sure to get it right
Old Nov 6, 2013 | 07:42 PM
  #41
kyoo's Avatar
kyoo
Another '08 vs '13 Difference
Noticed this today - the '13 seems to have some kind of chrome splitter-ish type of deal in the front bumper grill that the '08 didn't.. not sure what it is or what it's purpose is - any ideas?
'08:
'13:
Old Nov 6, 2013 | 07:48 PM
  #42
kyoo's Avatar
kyoo
A Few Other Random Pics
Missed parking the car, and happy the 13's came with holies as stock wheels:
Before and After of plasti dip drying on the dipstick - amazing how smoothly it dries, hope I didn't go too low on with the dip:
Don't know when I'm gonna drive this guy again...
Old Nov 6, 2013 | 09:58 PM
  #43
Btwyx's Avatar
Btwyx
I'd noticed that to. I assumed it was just cosmetic.
Old Nov 7, 2013 | 07:08 AM
  #44
kyoo's Avatar
kyoo
probably is, just kinda random
Old Nov 10, 2013 | 02:32 PM
  #45
kyoo's Avatar
kyoo
11/10/2013 - Under the Car
Some under the car pics. Struggling to put miles on the car - I think I'm right around 360 miles, so haven't changed the oil or filled the tank yet even. Doing a moderate break-in, been WOT a few times, and went to 5k rpms recently. Will continue that until 1000mi, then do somewhat of a hard "break in" then.
Old Nov 11, 2013 | 08:33 AM
  #46
kyoo's Avatar
kyoo
Getting there...
Old Nov 11, 2013 | 05:24 PM
  #47
kyoo's Avatar
kyoo
11/11/2013 - JCW Strut Tower Brace
After a small debacle of not getting my JCW strut tower brace on time, I finally received and installed my JCW STB today! As luck would have it, it started drizzling as I was installing this piece, so I've been pretty crabby about everything getting wet (and how it wouldn't have had I received it on Friday like I was supposed to).
Regardless, it was a straightforward install, especially since MINI USA provided the install instructions as a PDF somewhere on the Internet - thought I'd post up my own personal steps with pictures.
Step 1: Unscrew the 6 top bolts (13mm) holding the strut towers:
Step 2: Test fit the brace. This is where I started having to make adjustments. The brace wasn't long enough as it was provided to me, so I had to undo the locking nuts (17mm) and basically turn the arms to lengthen the brace.
Step 3: Start tightening the brace down. Again, as my brace was shipped, the bit that holds the bar to the clamps wasn't tightened down, so I had to do that once I started tightening everything down (17mm & not sure about the hex key):
Step 4: Tighten everything down (6 13mm bolts)!
Still annoyed that I had to do this in the drizzling rain, but happy it's in. I basically torque'd everything down by hand, and I'll probably have to re-do everything this weekend to make sure it's perfect. Right now I think the left (pass side) "arm" of it is overextended, but I didn't have much slack on the right (driver's side). Probably fine. Everything clears and the hood clears as well, but haven't been able to test drive the car with it yet. I'm expecting no difference in handling. Regardless, I'm confident that I have the necessary documentation for this to be a legally "port-installed" piece.
One thing I'm concerned about is the piece closest to the center digging into the strut tower top. I'm sure it'll be fine though
Old Nov 11, 2013 | 06:25 PM
  #48
hsautocrosser's Avatar
hsautocrosser
That "wax" in post #29 is cosmolene which is going to melt and run next summer. There are many threads on the mess it causes. The dealer cleaned the majority of it off of the underbonnet bolts on my '14 Roaster S. They didn't do that on my 2010 HT and it stained the fender trim.
Old Nov 11, 2013 | 06:27 PM
  #49
kyoo's Avatar
kyoo
oh weird.. i'm going to be using similar stuff for all the underbody bolts...
Old Nov 11, 2013 | 06:45 PM
  #50
Eddie07S's Avatar
Eddie07S
kyoo - I have the same bar. I just tightened it by hand. As long as the bolts and nut are comfortably tight you shouldn't have any problems. I like the way it keeps the front end "tight".
I couldn't see if you have pulled the plastic pins and pushed the struts in to get the extra camber. If you do, you know you will have to reset the toe-in. I found about a 1/2 turn on the tie rods worked well.
