Is it me or something else
Old Jun 12, 2012 | 05:05 AM
mrluckypa's Avatar
mrluckypa
Question Is it me or something else
I have a 2012 CM non S without comfort access and am having a couple of spooky issues. The first one has the dealer baffled and the second happened yesterday.
1. I have the HK Radio upgrade and every once in awhile, I lose my radio settings. Satellite radio defaults to channel 1 and I can't change it unless I stop the car and then switch fobs and then put the first fob back in and then it's ok. I understand that other people are experiencing this as well. If you haven't done so already, you need to let your service advisor know.
2. Yesterday, I went out parked the CM with the windows up and locked. Came out three hours later and all four windows were partially down and all doors were unlocked.
Any help or ideas would be greatly appreciated.
Thanks.
Old Jun 12, 2012 | 06:14 AM
LittleWing's Avatar
LittleWing
Congratulations on the new CM!
#1 - I have no idea.
#2 - Do you keep your keys on your back pocket?
Is there any chance that you sat on them?
Maybe you activated the remote and unlocked the doors, rolled down the windows?
PS -Love the name "Brown Betty." It reminds me of my British aunt's little teapot. It made the best tea and we had such cozy chats at her kitchen table over a cuppa!
Old Jun 12, 2012 | 06:24 AM
yetti96's Avatar
yetti96
I have heard on here before that #1 has happened before, but I don't recall the reason or the fix.
#2, how close to the car were you? You could have accidentally held the unlock button and began to roll the windows down.
Old Jun 12, 2012 | 06:30 AM
mrluckypa's Avatar
mrluckypa
Thanks for your responses. I don't have the Comfort Access so having the windows go down by key fob is not possible. (or is it???)
Old Jun 12, 2012 | 06:51 AM
LittleWing's Avatar
LittleWing
I don't have Comfort Access, but I can roll down my windows and pop my sunroof with the key fob.
Try it out.
Just hold the unlock button down and keep holding it down until something happens.
Old Jun 12, 2012 | 08:09 AM
mrluckypa's Avatar
mrluckypa
Littlewing,
Thanks for your input. I tried it (new to me) and it worked. Now to get the radio resolved. We were at a MINI run on Sunday and someone else with a CM had the same issue. Interesting to find out why.
Old Jun 12, 2012 | 08:43 AM
kconner5's Avatar
kconner5
Happens in my car... The reason is because each fob stores information regarding personal preference... Therefore if you program your stations and settings on only one fob then the other one will be blank, so if you program them the same then you'll be set
Kyle
Also, to roll up the windows and close the sunroof just insert the physical key into the driver door slot and twist to the right and hold it there until the windows roll up. They wont go up by holding lock unless you've coded your car.
Old Jun 12, 2012 | 09:04 AM
mrluckypa's Avatar
mrluckypa
Kconner5.
Thanks for the input on the windows and door. But I disagree on the radio settings. I only use one key fog. and for it to lose its settings and not allow you to change anything on the radio by locking it up (similar to a pc crash) is totally strange. To get the settings back, I have to cut the car off put my wife's key fob in start her up and then cut the engine and swap keys and then my settings return. So this is not the case of one fob not having the same settings.
Old Jun 12, 2012 | 07:54 PM
MMM's Avatar
MMM
Had something similar happen to my radio the other day. I've got an MC, not a CM, with the HK radio. I was driving along just the other day, switching between various programmed satellite stations. Suddenly it went to the Hits channel or something like that and wouldn't switch. No matter which pre-programmed button I pressed, it stayed on that channel. Trying to use the up or down button didn't do anything either. It was fixed after I turned the car off and then back on. Did not need to use the other fob to fix it. Was weird, but only happened once so far.
Old Jun 12, 2012 | 08:53 PM
LittleWing's Avatar
LittleWing
Littlewing,
This is a first! I knew the answer!!!
Glad it worked out.
It is a really convenient feature, once you know not to sit on your keys.
I use it all the time while on my way to the car when it's been sitting in the Florida sun. It's so nice to be able to air it out before I get to it.
I just learned the part about rolling the windows up and closing the sun roof with the physical key.
It's fun to find out these little MINI secrets.
As far as your problem with your radio settings, I don't have a clue.
I hope you get it figured out soon.
Old Jun 13, 2012 | 06:17 AM
mrluckypa's Avatar
mrluckypa
I have one favor to ask of everyone that has this radio problem. Please let your MINI Service Department know about this. I thought the problem was me but I guess not. The more people that let them know the quicker it will be fixed.
Thanks again,
Old Jun 13, 2012 | 09:29 AM
GigglesMcMini's Avatar
GigglesMcMini
Glad it worked out.
Curious, I knew about when you double hit the unlock on the fob the windows roll down, ets, but how does the physical key roll them up? Just remove from fob and insert in lock??
Old Jun 13, 2012 | 09:33 AM
kconner5's Avatar
kconner5
Hold down unlock - Roll down windows and pop sunroof (or for R57 people hold down unlock until all windows are down, and hold it down again and the roof will detract)
Put the key into the physical lock and twist to the right and hold it there - Windows + sunroof + convertible top (R57 only) will go up
Hold down trunk button - Alarm will sound, if you have that option.
I still cant figure out why they give us a trunk button... It just pops it open on the countryman and to lift it up you need to grab the MINI logo to open it anyways
Kyle
Old Jun 13, 2012 | 09:46 AM
shark715's Avatar
shark715
Kyle, I think it's so you can unlock the trunk with unlocking the rest of the car. My Mercedes SLK is similar.
Old Jun 13, 2012 | 09:57 AM
patdarat78's Avatar
patdarat78
This just made my day. Finding out that I can roll my windows down with my fob!
kconner5's Avatar
kconner5
Yup, it is I'm just not sure why they would need that, but the more features the merrier
Kyle
Old Jun 13, 2012 | 10:35 AM
Mini-b10's Avatar
Mini-b10
Yeah see I like the way my wife's Passat's trunk button is...hold down the button to open the trunk and it pops completely open, you don't have to open it on your own. Wish ours did that. Although it would need the addition of heavier duty actuators to lift the boot.
Old Jun 13, 2012 | 10:54 AM
GigglesMcMini
Thanks again,
Mark, sorry, I think your thread got hijacked. Back to the original issue, people!!!!
Old Jun 13, 2012 | 12:12 PM
LittleWing's Avatar
LittleWing
Thanks again,
Just a suggestion, but you might try posting about this radio/key fob issue again under a title that names the problem.
That might better reach your target audience of people experiencing the same issue who otherwise won't see your post.
Good luck!
I hope it's solved for you soon.
Old Jun 14, 2012 | 03:54 PM
GigglesMcMini
Kyle
Put the key in my Clubman (R55) turned to the right, and, lo and behold, my windows went up and my sunroofs closed YAY!!! already knew about opening windows and sunroof with double open on the fob....soooo coooool! A year and half later and I'm still discovering!
Old Jun 14, 2012 | 10:30 PM
Bakerbrdz's Avatar
Bakerbrdz
Just bought my wife the same car!!! Weak!!
Old Jul 29, 2013 | 01:00 PM
SchHDogs's Avatar
SchHDogs
My car is in today for another problem and since I don't like additional trips, I added this issue to my ticket since it happens to me a lot on short trips --- and I can't stand Hits 100!!!!
