R58 Picking up R58 JCW and no boost
Old Nov 1, 2025 | 02:21 PM
  #76
yyj3869's Avatar
yyj3869
Originally Posted by njaremka
Yup, if wastegate isn’t moving or is stuck, you’ll get the boost plausibility error
if wastegate stuck open then does it really cause misfire at idling?? It had little misfire before but it's getting worse after I did all the stuffs above.
Old Nov 1, 2025 | 02:45 PM
  #77
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
They could be unrelated. Since you have an N14 engine, it’s possible that valves need cleaning, or are starting to wear out. I would change plugs and coils to address the misfires.
Old Nov 1, 2025 | 02:49 PM
  #78
yyj3869's Avatar
yyj3869
I have replaced only ignition coils a week ago and haven't changed the spark plugs. I posted the pics of spark plugs before. I also tested by switching cyl #2 spark plug to cyl #1 and still misfire on cyl #1. no idea. It wasn't like that few days ago..did I mess up something.?? I cleaned MAF sensor before and let it dry at least 10 mins and put that back on last time.
Old Nov 1, 2025 | 04:21 PM
  #79
MCS02's Avatar
MCS02
MINI Alliance Ambassador
@yyj3869 Excellent! I am glad you found it. Absolutely get the Detroit Tuned oil lines. Lastly from your video your valves have got to be cleaned! @njareka is correct dirty valves can and will cause a miss fire. On a N14 motor they need to be walnut blasted any time after 35k or 40k. Like I said I just get mine done, I don't wait for the problem to start.
You can buy all the stuff to do a walnut blasting yourself.
Keep us up on how it goes.
Old Nov 1, 2025 | 04:38 PM
  #80
yyj3869's Avatar
yyj3869
I purchased these spark plugs from amazon. I believe these are for stage 1 or 2 tuned mini but I wonder if It's okay to install on mine even if it wasn't tuned.
Amazon Amazon
Old Nov 2, 2025 | 04:09 AM
  #81
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Sorry, but I would never buy spark plugs from Amazon. Too many counterfeit products on there. Buy from one of the forum sponsors, or from any reputable supplier like NAPA. Same with coils. I’ve heard too many horror stories that started from replacement parts bought off Amazon.
Old Nov 2, 2025 | 05:45 AM
  #82
MCS02's Avatar
MCS02
@yyj3869 A tune advances the timing and will richen up the AFR, a cooler plug is used to help with preignition, knock. knock is the engine killer even more than momentary lean conditions. So long answer, it won't hurt but it would be best to use the normal heat range plugs if you don't have a tune. Plugs are the least of your worries right now, but I would go head and change them while your at it. The ones in the picture are fine. They are the correct color. If the misfire goes away when the motor gets to running tempter your valves are causing it. Sorry I sound like a broken record but......
Old Nov 2, 2025 | 06:30 AM
  #83
MCS02's Avatar
MCS02
@yyj3869 Long story that may help. I have an 2006 Exige. The first owner put a supercharger kit on it. The kit came with a tune. The second owner put a TVS900 SC on it and the shop said they retuned it. I am sure they did not. It went to a third owner then to me. Man the car ran great. Till I did a track day. I melted the number 1 plug. Everyone said it must be running lean. So I added an AFR gage to the car. It was not running lean, it was running rich during WOT, as it should, maybe a little too rich. At the time the car still had the stock ECU with a tune and the narrow band O2. It took some time to figure out what was up. What I found was the tuner was know for advancing the timing too much to add more power, then he would go very rich to try and stop knock. What I had was knock problem. You can have knock without hearing it.
Knock disturbs the bound layer in a cylinder allowing the flame to touch things it shouldn't like my plug. I don't believe in bolt on power anymore. Will it work, maybe. Your ECU with a stock tune, narrow band O2 can only adjust so much. I say this because I see you may get a bigger turbo. If you do I would take it to a tuner that can make sure no adjustments are need to be made.
I am over simplifying here but I want you to understand every thing is interconnected. The Manufacture designed the car in a very narrow band on performance and it will only scale so far.
Old Nov 2, 2025 | 11:48 AM
  #84
yyj3869's Avatar
yyj3869
I just did vacuum tester on wastegate with camera through o2 sensor hole and the wastegate is stuck opened even I give a pressure on them and I don't see any movement at all. It's time to change turbo then?
I also pulled out spark plugs and put camera inside of all cylinders and let me know what you guys think.
Old Nov 2, 2025 | 02:54 PM
  #85
MCS02's Avatar
MCS02
@yyj3869 If the wastegate is stuck open like yours is then as others have said yes you need a new turbo. Even the mini dealer said it needed a new turbo. I think your cylinders are fine. But as I have said a few times the intake valves need walnut blasting.
Time to order a new turbo. As far as the Ebay turbo, I cant advise. Maybe some of the other guys hear can help with that.
Do you usually work on your cars or is this the first one?
Old Nov 2, 2025 | 03:04 PM
  #86
yyj3869's Avatar
yyj3869
@MCS02 Thanks for your quick response! Yeah the dealership was right. I mean I kinda wish that It could be easy fix like exhaust leak like last time (3 bolts were loose) and I didn't want to spend much money on this problem and that's why I tried to figure it out myself and I really appreciate you guys for help and explain all the details. Yeah I'm going to do intake valve clean after figuring this problem out first. I'm going to order new turbo on ebay that @MiniManAdam suggested me. I usually work on my car only for like simple maintenance stuffs (oil change, spark plugs, ignition coils). I was pretty scared of what I was doing because I feel like I'm going to mess up something and more however, I learned a lot while I was doing this stuffs.
Old Nov 2, 2025 | 03:07 PM
  #87
yyj3869's Avatar
yyj3869
@MCS02 I just watched video few times back and forth and saw one drip onto cylinder 4. I don't know if it's oil or coolant.
https://youtube.com/clip/UgkxWbJOTw_...UFAffVMACDcm1A
Old Nov 2, 2025 | 03:35 PM
  #88
MCS02's Avatar
MCS02
@yyj3869 how long had the car been off. Perhaps that was an injector dripping. Does the oil and antifreeze look ok?
Old Nov 2, 2025 | 03:38 PM
  #89
yyj3869's Avatar
yyj3869
@MCS02 Yes oil & coolant is good for sure. car was off only for 24 hours. I didn't go for a drive like 3 days though.
Old Nov 2, 2025 | 04:30 PM
  #90
MCS02's Avatar
MCS02
@yyj3869 Well it could be a sticky fuel injector. Just add a bottle of injector cleaner to a tank of gas. Use 93 obtain, if you can get it out there or as high as you can get. Always use a top tear fuel. They have the most cleaners added to their fuel
https://www.toptiergas.com/gasoline-brands/
If the car were Mine this is what I would do. Install the new turbo then get the valves cleaned. I bet that will take care of all the problems.
You have done well for this being your first time to dig this deep into a problem.
Old Nov 4, 2025 | 07:24 PM
  #91
yyj3869's Avatar
yyj3869
I have a quick question. I ordered a k04 turbo below. Does the stock intake hose boot fit on it?
https://www.ebay.com/itm/365191068252
Old Nov 5, 2025 | 05:35 AM
  #92
MCS02's Avatar
MCS02
I don't know for sure. Maybe one of the other guys will know.
Old Nov 5, 2025 | 04:32 PM
  #93
yyj3869's Avatar
yyj3869
Finally got the turbo today!!!
Old Nov 5, 2025 | 04:51 PM
  #94
yyj3869's Avatar
yyj3869
I just test fitted turbo gasket and It fits but It's little bit loose as you can see. would it work? it will expand itself once it attaches to exhaust manifold and heats on it?
Old Nov 6, 2025 | 03:13 AM
  #95
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Nice. As long as the gasket sits proudly of the flange face, it will seal when bolted up. It looks fine to me.
Old Nov 6, 2025 | 06:35 AM
  #96
MCS02's Avatar
MCS02
Looks good! Kant wate to see how it works.
Old Nov 8, 2025 | 04:10 PM
  #97
yyj3869's Avatar
yyj3869
update: I took my jcw to my friend who fixes minis and he took front end off since we will work on oil filter housing gaskets & oil lines for turbo. Once we remove the turbo and exhaust manifold, guess what... I didn't see this coming but exhaust manifold has little bit of crack and it gone through little bit more inside of it. glad that we found it before we put them back on. another problem was that 3 studs on turbo won't come off and the other 4 or 5 studs connects to exhaust manifold won't come off either so unfortunately, I had to leave the car at his place. He said he will drop the exhaust manifold at the machine shop to weld and make sure there is no crack anymore. We tried to pick up studs for those turbo and exhaust manifold at the dealership but they don't seem to wanna answer the phone lol so I just decided to go for studs from amazon since we can get them by tomorrow.
#studs I'm getting.
Amazon Amazon
Old Nov 8, 2025 | 07:57 PM
  #98
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Good luck! Sounds like good progress.
Old Nov 9, 2025 | 06:18 AM
  #99
MCS02's Avatar
MCS02
Nice I, it will be good to have it running.
Old Nov 10, 2025 | 02:59 PM
  #100
yyj3869's Avatar
yyj3869
Just picked up the brand new K&N intake.
