R56 Things you didn't know about your R56 MINI
Old Nov 11, 2013 | 07:59 PM
  #2726
Summons's Avatar
Summons
After 2 years/40,000KM with my '12 MCSm, I discovered the burble and pop is deactivated when in reverse. I wonder why...
E
Old Nov 11, 2013 | 09:03 PM
  #2727
MiniErik's Avatar
MiniErik
Originally Posted by vetsvette
Installing a new factory Mini car cover is about as easy as putting a condom on a cantaloupe! Just had that fun experience a few minutes ago.
lmao its much easier with two people I just put mine on
Old Nov 11, 2013 | 11:55 PM
  #2728
Mudnut's Avatar
Mudnut
I hope you are talking about the car cover
Old Nov 12, 2013 | 09:00 AM
  #2729
jhull413's Avatar
jhull413
E
Maybe they thought nobody would be foolish enough to think they needed it in reverse . Seriously, do you know it is actually deactivated or is it that you haven't reached enough RPMs to make it pop and burble when you back off in reverse?
Old Nov 12, 2013 | 08:53 PM
  #2730
pw4's Avatar
pw4
E
R56s have 3 engine maps: standard, sport and reverse. The engine map that's used when reverse is engaged has softer throttle response for easier, smoother reversing. Not sure if it has any other differences.
Only the MCS & JCW sport maps have the burble & pop (sport button is an option on the Cooper but without the burble and pop).
Old Nov 12, 2013 | 09:54 PM
  #2731
Summons's Avatar
Summons
And now I know!
TKS!
Can't say that I like how utterly inter-related everything is on these (and seemingly all) modern machines, but save buying a relic, I suspect I'm stuck!
E
Old Nov 17, 2013 | 05:38 AM
  #2732
linak's Avatar
linak
I found out that if you leave your sunroof tilted when locking your car - and setting the alarm - you can walk about 50 ft. away before it sets the alarm off. I ran back, couldn't imagine why the alarm went off, relocked the car, walked away and it went off again. Ran back again (calling myself some choice names), closed the sunroof . . . all was well!
Old Nov 17, 2013 | 07:03 AM
  #2733
Beachnmini's Avatar
Beachnmini
The cooper loaner I had burbled in sport, it just wasn't as pronounced.
Old Nov 18, 2013 | 08:10 AM
  #2734
Ishihara's Avatar
Ishihara
the number one thing I didn't know was that THIS thread should have been required reading on day one of ownership... from intermittent wipers to sport mode... seriously, I taught myself manual in regular mode, afraid to put it into sport... and when I finally felt comfortable enough and did it, good lord was it easier to drive - who knew? oh, wait... you guys did...
Old Nov 24, 2013 | 08:33 PM
  #2735
Lifecycles's Avatar
Lifecycles
Manual Rear Hatch Release under rear seat
While Dynamatting for my Seat Delete kit I found this cable under the rear seat that manually releases the latch to the rear boot door. It's located in the center and you have to pull up the seat to see it. I don't remember reading about this in my manual.
Old Nov 24, 2013 | 09:23 PM
  #2736
yesti's Avatar
yesti
I have the ipod connected via factory usb and 1/8" connectors. standard boost radio, no NAV. If i increase the 'level' setting on the radio then the ipod gets louder AND each volume click on the **** makes a bigger adjustment. With it set to the default '3' you have to crank it a few clicks for it to make a difference. On 4 or 5 the difference is much better.
Old Nov 25, 2013 | 01:40 PM
  #2737
pw4's Avatar
pw4
good to know about that - thanks! In case the electrical release fails.
Old Nov 26, 2013 | 12:36 AM
  #2738
pw4's Avatar
pw4
You can turn on the radio by just pressing the Mode button, at least on the LCI. Can't believe I'm finding new stuff after 6 years!
Old Nov 26, 2013 | 07:15 PM
  #2739
yesti's Avatar
yesti
Or the power button
Old Nov 27, 2013 | 03:22 AM
  #2740
pw4's Avatar
pw4
Originally Posted by yesti
Or the power button
Well, yes, that too.
Old Nov 27, 2013 | 06:48 AM
  #2741
Big Knight's Avatar
Big Knight
I had a wierd one happen twice this past week. I hit the up window button and the window went part way up (~1/2 way and ~1/4 way) than went fully back down. I remember reading this happening to someone else on here.
I did not hit the button a second time. I did not "hold" the button. My finger was off the button both times. Any idea why this happens sometimes?
Old Nov 27, 2013 | 07:48 AM
  #2742
jhull413's Avatar
jhull413
MINI gremlins?
Old Nov 27, 2013 | 08:07 AM
  #2743
Big Knight's Avatar
Big Knight
My old car had the occasional gremlins. Would do weird things sometimes that would be gone on the next restart. Maybe they changed cars with me?
Old Nov 27, 2013 | 10:08 AM
  #2744
MINI4LYF's Avatar
MINI4LYF
That's happened to me as well. No idea on the cause
Old Nov 27, 2013 | 12:44 PM
  #2745
bendari500's Avatar
bendari500
Lol, this happens to me as well, anyone searched the forum for it?
Old Nov 27, 2013 | 01:31 PM
  #2746
daddyandmadi's Avatar
daddyandmadi
To fix it, hold the window switch down for 20 seconds after the window bottoms out. Then it works. It's to reset the safety closure mechanism. Mine was stuck after a cold snap.
Old Nov 27, 2013 | 01:38 PM
  #2747
bendari500's Avatar
bendari500
wow! heading out right now to try it! just so happens its been quite cold last few nights...
Old Nov 28, 2013 | 12:45 AM
  #2748
pw4's Avatar
pw4
it can also happen with a bump in the road. The entry yo my office has a speed bump just after the boom gate and often stops it closing. I assume it mistakes the bump for someone's head or limb interrupting the window.
Old Nov 28, 2013 | 04:33 AM
  #2749
jagxkr00's Avatar
jagxkr00
The 2011 up base model r56 LCI has the same upper dimensions on the core-support as any r56 Mini Cooper S. Hence you could put a Mini S front bumper and or hood on a base Mini (2011-up) with no modifications. If you have a 2007-2010 Mini Base R56 the core-support configurations are different and without changing core support no way to slap on a MINI 'S' Front end. Check out my website! www.gousedmini.com
Old Dec 22, 2013 | 07:15 PM
  #2750
komet155's Avatar
komet155
I've learned that I miss not having illuminated folding mirror and headlight switches. Having to feel around to un-fold the mirrors is annoying, and I keep forgetting which direction I need to twist the headlamp stalk to turn the lights on. Other times I forget to turn them off before I shut down the car...because it's not illuminated and I'm in the dark!
