R56 noise/moonroof closed: quality control?
Old Mar 15, 2007 | 09:59 AM
  #51
Lightfoot's Avatar
Lightfoot
I tried the antenna suggestion. It didn't help.
Old Mar 15, 2007 | 10:24 AM
  #52
MiniMoMir's Avatar
MiniMoMir
Same here. The release test drive car had noise at 35-40 on... Mine is quiet till about 70-75. Do you think MINI will attempt to fix it, or will it just be more trouble than it's worth?
Originally Posted by BritBoy
Mines certainly quieter than the release cars, but there is definitely a noise at 70 - 75mph
Old Mar 15, 2007 | 10:39 AM
  #53
dchautin's Avatar
dchautin
I was the first one to buy here in Louisiana and I have the noise. It's pretty distracting. I am hoping for a fix soon. Also, my windows lower when the door is open, but sometimes they do not rise when closed leaving a 1/2" opening. Have to remember to raise the windows with the switch.
another complaint I have is the sunshade. not dark enough for those really sunny days that you choose not to have the sunroof open.
need an aftermarket solution.
Old Mar 15, 2007 | 02:01 PM
  #54
daffodildeb's Avatar
daffodildeb
I just had my sunroof tinted--I can really tell the difference!
Old Mar 15, 2007 | 03:29 PM
  #55
radiospace's Avatar
radiospace
So it was the light that was making the noise?
What would Einstein say?!
Old Mar 15, 2007 | 03:37 PM
  #56
daffodildeb
No, I was answering dchautin's comment in the second paragraph of his post. Silly boy!
Old Mar 15, 2007 | 03:40 PM
  #57
radiospace's Avatar
radiospace
heh
Old Mar 15, 2007 | 04:32 PM
  #58
BritBoy's Avatar
BritBoy
I just asked my MA if I could bring my car in to have the sunroof fixed. He spoke to the service dept. who advised him....'There is no fix'.....Don't know where that leaves us.
Old Mar 16, 2007 | 03:30 AM
  #59
Mini Me GB's Avatar
Mini Me GB
My sunroof has gone in to be 'fixed' today - will report back this afternoon..
Old Mar 16, 2007 | 06:54 AM
  #60
BritBoy's Avatar
BritBoy
If they do fix it, maybe you could ask what they did. Was the noise from the front or back pane, too high, too low etc.
Old Mar 16, 2007 | 07:33 AM
  #61
marksmith's Avatar
marksmith
my car is not so bad..NOW..
I have several hunderd miles on my R56 and the sunroof noise has become something of a non-issue. The nice folks Mortiz Mini did some adjustments but the roof still makes some noise. What has changed is my brain: just got used to it & it simply does not bother me. My other car is a Z4 roadster so maybe I have a higher threshold for road noise.
-There is likely an airflow "turbulence" issue where the mid & rear roof unit meets the sheetmetal. If the car had a more substantial interior sun-screen (opaque, solid material) the noise would be much less noticable.
-I did have mine tinted w/ Huber-optic 30% and the temp/glare is perfectly controlled. Expensive stuff but great heat rejection!!!!
Old Mar 16, 2007 | 09:46 AM
  #62
Golsco's Avatar
Golsco
It is strange that in the UK I've read that there are bulletins on the sunroof noise and a fix for them. I've spoke to several dealerships in my area that have all said there is no fix and that's the way it is. When was yours built?
Old Mar 16, 2007 | 10:16 AM
  #63
Mini Me GB's Avatar
Mini Me GB
Ok my MINI has been in today for this problem to be fixed and to my surprise they have fixed it!
It sounded like a hurricane at anything above 20mph before but now it's completely silent up to 70mph.. There is a slight wind noise at 70mph+ but it's just as a gust of wind goes over roof, not a constant noise.
So to the dealers that say there is no fix, you can now tell them there is! If it helps the main thing they did was to replace all the rubber seals..
Good job MINI, it's now 100% perfect
Old Mar 16, 2007 | 05:05 PM
  #64
BritBoy's Avatar
BritBoy
It was built in early feb, but reading the comment from MiniMeGB, it may be that the noise I'm hearing is the same as his, since hes had it fixed....Mines going back to the dealer on Tuesday, so I'll report in when I get it back.
Old Mar 17, 2007 | 07:10 AM
  #65
always wanted a mini's Avatar
I took my mini in yesterday to get my sunroof noise issue fixed and i really dont think they knew how to fix it properly (it took them 7 hours )they claim mini is aware of the problem and the dealer technician had recently been to the maintenance trianing and it was adressed as how to fix the problem.As of right now it seems to be corrected but im afraid to open and close my sunroof I guess i better test it out and check to see that in fact the issue has been resolved btw i love my mini and the noise isnt keeping me from getting rid of it
Old Mar 17, 2007 | 07:23 AM
  #66
RhinoBob's Avatar
RhinoBob
Test drove one a few days ago and it had too much wind noise from the sun roof to be acceptable for any sort of distance cruising at 70 mph. You would think that if Mini had a bona fide fix that the demo car would have it. I'm not sure which way to order, or if the issue is a deal breaker. I'd like the open top.
Old Mar 17, 2007 | 08:29 AM
  #67
MY4thMINI's Avatar
MY4thMINI
is it comming from the front panel ? or the back panel?
Old Mar 17, 2007 | 09:07 AM
  #68
BritBoy's Avatar
BritBoy
I've tried removing the antenna, which didn't work. I also stuffed rags into the gap around the front panel and that too made no difference. I think I'll try putting tape around all the joints, where the glass meets the roof, and see if that works.
Old Mar 18, 2007 | 03:26 PM
  #69
Lightfoot's Avatar
Lightfoot
Does the fix persist?
Pleased that your wind noise is fixed. Since several posts report that the problem is "fixed" and then comes back, please let us know if the fix works over a longer period. If your lasts, I will take my noisy roof in with your posts as ammo.
Old Mar 18, 2007 | 06:28 PM
  #70
marksmith's Avatar
marksmith
completely baffled......
Short version. Thought my worries were over:
A. Car was worked on at dealer before delivery, sound lessened.
B. Post delivery noise started coming back. Eventually as loud as the test-drive.
C.Had tint installed, roof opened & closed several times, noise gets better (go figure.)
D. After a week drivng noise comes back, loud as ever.
E. With a slight tail wind, nosie goes away, 99%. Even a modest tail wind & it's fine?
What the hell is going on? This must be a seal OR it's the crank/tensioner loosing it grip OR it's a basic aerodynamic flaw OR.......
-I can't wait until it rains hard, this might be interesting.
We should ALL call Mini USA and let them know we are not pleased & want an official explanation ASAP.
Old Mar 19, 2007 | 08:25 AM
  #71
BritBoy's Avatar
BritBoy
MiniMeGb had the seals replaced and that completely cured the problem. Have you asked your MA if they would do that?
Old Mar 19, 2007 | 08:31 AM
  #72
daffodildeb
I was dipping into the 2002-2006 chatline, and apparently they had this problem with the 2006 models. Perhaps the dealers are tired of trying?
I'm just glad mine is quiet. And no, you can't tear it apart to find out why!
Old Mar 19, 2007 | 04:01 PM
  #73
MY4thMINI's Avatar
MY4thMINI
I HAD AN 06 TINTOP WITH THE SUNROOF BUT NEVER HAD A PROBLEM WITH THE SUNROOF MAKING ANY NOISE
I AM GUESSUNG MUCH LIKE THE 07 ISSUE IT WAS A SPOTTY ISSUE IN PRIOR YEARS AS WELL
Old Mar 20, 2007 | 07:38 PM
  #74
BritBoy's Avatar
BritBoy
Well my car went in today to have the sunroof fixed. The service guy said they'll have a look at it but they don't expect to be able to fix it......I noticed on the journey to the dealers, that if I ever so slightly open the roof the noise goes away. I guess that is my answer to the problem:impatient
Old Mar 22, 2007 | 10:51 AM
  #75
Lightfoot's Avatar
Lightfoot
Not there yet
At my MA's urging I took my car into the dealer to have the moonroof adjusted. I was told the problem was solved. Driving back to work from the dealership the sound was identical to before. The dealer says he will file a PuMA report. Evidently this lets MINI engineering know that a customer has an issue.
All my avowals that it appears that replacing the seals worked were pushed aside as "internet chatter".
