R56 Rebuilt engine but misfires on all cylinders.
Old Jan 18, 2026 | 02:09 PM
  #26
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Also, have you double checked the camshaft timing using the special cam tool with the flywheel locked?
Old Jan 18, 2026 | 02:23 PM
  #27
killerbishn67's Avatar
killerbishn67
Originally Posted by Frank_Repair
Larger bore alone shouldn’t cause that, sounds more like a vacuum leak, sensor issue (MAF/MAP, coolant temp), or ignition under load. I’d start there before blaming the ECU.
I've replaced the MAF sensor and I've done a leak down check on the intake and there are no leaks.
Old Jan 18, 2026 | 02:26 PM
  #28
killerbishn67
Yep, I have the BMW cam locking tool and I have checked it 3 different times over the 3 months I've been working on this.
Old Jan 18, 2026 | 02:32 PM
  #29
killerbishn67
I just did a cylinder leak down test to make sure nothing is leaking from the valves or pistons and in the process of doing that I heard a click come from the piston on cylinder 1 and cylinder 4 when i had it at 20 psi. Which makes me think the piston might be rocking back and forth. The click noise from the piston will only happen once, in order for it to happen again I have to rotate the piston up and down a little bit then the click will happen again. From my experience I think the rods wrist pin bearing might to too lose and letting the piston rock in the cylinder. In any case here are the leak down results if your curious.
Cylinder 1: 93psi/100psi
Cylinder 2: 98psi/100psi
Cylinder 3: 97psi/100psi
Cylinder 4: 92psi/100psi
Old Jan 19, 2026 | 04:56 AM
  #30
Maybe, maybe not
Community Builder
Click noise could potentially point to a hydraulic lifter issue.
Addco
Aug 5, 2025 04:35 PM
traildog
Feb 18, 2024 10:09 AM
TacoEngineer
Jun 17, 2020 03:18 AM
SWAgoat
R55 :: Clubman Talk (2008+)
Jan 20, 2017 08:51 AM
chevycoop
Jan 23, 2013 05:38 PM
